Aller au contenu principal
Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s, Caméra frontale et nappe de capteur: étape 1, image 1 de 1
    • Cette étape nécessite le déplacement de la caméra frontale et de la nappe de capteur de votre écran.
    • La caméra frontale et la nappe de capteur sont collées à l'écran avec de l'adhésif mou.
    • L'utilisation d'un iOpener pour ramollir l'adhésif facilitera à l'enlever en toute sécurité. Suivez notre guide d'utilisation du iOpener.
    If you just want to get underneath the LCD plate, e.g. to clean water/drinks that got in there, skip to step 34. There's no need to peel off those connectors or use the iOpener heat. Here's a photo: http://imgur.com/AKlFWed
    Dan Dascalescu - Réponse
    In my case, my front facing camera was just foggy, and I suspected dust had got in there (was correct in the end). In this step I had to remove the shield (which you can see still attached in Step 16), which is over the camera itself. It was then possible to gently lift the camera out of it's socket and clean.
    Robert Colvin - Réponse
    Robert -You were able to lift the camera just by itself? I would think the cable doesn't have any extra slack to allow the camera to move without detaching the cable on one end.
    Paul Astrachan -
    I had a foggy front camera too due to lots of dust ingress into the front camera housing. This was clearly visible in the front camera lens above the earpiece aperture - it was white instead of the pinpoint of blue lens. The best way to lift without the tricky lifting of the entire camera assembly is to peel back the large black sticky pad attached to the back of the metal display shield. Then you can roll the camera lens and proximity sensor out of the way and carbon fibre brush or air blast the dust out.
    Simon -
    Quick tip: if you can't afford/wait for/don't want the iOpener, filling a small portion of an ankle cut cotton sock with rice (to about the size of a golf ball), tying it closed, and putting it in the microwave for about 25-30 seconds can work just as well!
    ndauphin583 - Réponse
    I used a cherry stone pillow to heat up the display. I though it could be nearly the same as the iOpener one. It worked out very well
    Denis Kiesel - Réponse
    Do not skip this step. The proximity sensor is very easy to peel off the flexible circuit board if the adhesive isn't loosened.
    Cedric - Réponse
    I always use UNDU adhesive remover instead of heat. Works great for all adhesively mounted parts. I have used on numerous iphones and an iPad. If the glue stays stuck to the right part, then it is reusable still sticky when the UNDU dries out. When used on Home/TouchID button, it made the rubber membrane soft and misshapen, but it returned to normal shape when it dried out.
    3M thin VHB tape 5908 can be used to replace any needed little sticky bits.
    B Louis - Réponse
    If you don’t have a heating pad, a hair dryer or heatgun on a low setting also works well for heating up this area.
    markfiorentino - Réponse
    Here an important tip no one thought to include: Opposed to other connectors, this one happens to be Paper Thin!
    Yes! Do consider that, prior to prying the entire lens out of the housing!
    Srsly iFixit?? why do i always need to destroy one model every device repair attempted (here)??!
    c0BRA - Réponse
  2. Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 2, image 1 de 2 Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 2, image 2 de 2
    • En utilisant le bord d'une pince ou d'un spudger en métal, tirez délicatement sur le câble du haut parleur interne pour séparer cette partie de la caméra et de la nappe de capteur de l'adhésif en dessous.
    • Tirez uniquement sous le contact du haut parleur interne, il y a ici des capteurs et des micro puces qui pourraient être endommagés en tirant ailleurs.
    People, we carefull while removing, IFIXIT guys are not being aware of putting in the guide about the really easy way you can brick the cable. from the contacts down there is a sensor that will come loose easily from the cable if not pryed up! i dont know why they didnt put this HUGE in the guide.
    Alma - Réponse
    Hernan,
    I have bricked two of these cables now. Can you give me a step by step approach to removing the proximity sensor cable....I don't know what I'm doing wrong. I insert a flathead screwdriver underneath the part of the cable that doubles back and lift from there. What do you recommend?
    Thank you,
    sachock - Réponse
    I got stuck on this step for a while. The cable itself is really thin and I thought it had a piece of plastic underneath it but this is actually part of the display assembly and not the cable.
    warren5236 - Réponse
    Yeah, I kept applying more heat only to realize the same thing. The gold contacts are sitting on a very thin flexible plastic strip that you need to peel up.
    jonl -
    I also kept trying to remove the plastic too… so thin film to remove only.
    turo - Réponse
    The trick is to place the tool more to the left than it is shown in the picture, and then work slowly towards the right.
    Julia Niksen - Réponse
  3. Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 3, image 1 de 2 Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 3, image 2 de 2
    • Utilisez le bout d'un spudger pour séparer le capteur de luminosité interne et le capteur de proximité en dehors de leur cavité dans l'écran.
    • Il existe un petit plastique carré et un support en métal pour le capteur de proximité. Ce support est essentiel au capteur de proximité pour fonctionner correctement.
    • En remplaçant le capteur de proximité, faites en sorte que le support reste attaché à l'arrière de l'écran. S'il se détache avec l'ancien détecteur de proximité, enlevez le de l'ancien capteur proximité et utilisez un peu d'adhésif pour le recoller à l'arrière de l'écran.
    This step doesn't give complete information.
    The proximity sensor is adhered to the frame and must be loosened CAREFULLY and SEPARATELY before applying any pressure to the ribbon itself. It is extremely easy to tear the sensor from the ribbon, meaning when you're on a call with the phone next to your face, any touch will "press" an on-screen button. Look up images of these components to see exactly where they are placed and what they look like.
    mikemckinnon - Réponse
    Hello! I dont know why but I cant make the proximity sensor work. My front camera is working... I don't know what i'm doing wrong, can you help me with that?
    jesusbe -
    Under the proximity sensor, there is an little white sticker.
    You have to put this on to the new screen,
    otherwise the proximity sensor will not work properly.
    To get it off, try to heat the spot (for example with the iOpener).
    FaKlein - Réponse
    Yep, brilliant piece of advice. I would have missed the white diffusing paper if not for this comment. Thanks!
    jonl -
    Thanks, I would have miss that one !
    K8L -
    thank you! this is a HUUUUGE note.
    palatucci -
    proximity sensor holder, the one with the half metal square should be centered on the two small translucent openings of the front panel otherwise it doesn't work. Mine was misaligned I had to remove and glue it again to make it work.
    osmanalpay - Réponse
    The bracket for the proximity sensor is critical. some more detailed pictures and guidance would be helpful here. After attempting to replace the screen with a new screen that did not come with the proximity sensor, buying a new proximity sensor bracket, etc. I finally gave up and bought another screen that included the front-facing camera and proximity sensor pre-installed.
    Jay Seaman - Réponse
    also, make sure you get the tiny rubber gasket that the prox sensor fits into snugly against the display. when i popped the sensor off, the gasket stayed behind, and i couldn't get the sensor to fit properly in the new display. i checked the old one again and saw the little rubber gasket that contours to the front camera lens opening on the display assembly. pulled it off with tweezers, and used it to get the prox sensor properly seated on the new display. i wish i'd taken a picture of it, but, well, my phone was in pieces in front of me.
    palatucci - Réponse
    I recently replaced a broken screen. The screen had shattered in the earphone area, and since the phone was new to me I didn't know about the camera clip and proximity sensor holder. These parts are just a few dollars online. I believe they are essential. My front camera has visible drift and the proximity sensor doesn't work.
    saifalgianfar - Réponse
    I also had to remove the tiny black rubber gasket and move it to the new display. This was not easy. I also had lots of trouble getting the proximity sensor back in place during reassembly. I seemed to have another connector near the camera that had to be reconnected, but isn’t mentioned in this guide. More pictures on a white phone might make it easier to see all the tiny parts in this area.
    smacdvm - Réponse
    Make sure your new screen does not have the plastic bit that holds the proximity sensor before you try to put the one from your old screen in. Mine came off with the proximity sensor, and I had a devil of a time figuring out why the proximity sensor wouldn’t seat.
    Calion - Réponse
    The pictures and the text for this step are simply not adequate to properly illustrate the delicacy of the task - much more detailed pictures showing the removal of the light and proximity sensors is needed and also a very clear warning in the main text (like this) - it is very easy to unintentionally tear the proximity sensor off the cable assembly, destroying the proximity function and thus requiring a complete new front camera / light sensor / proximity sensor cable assembly !
    Jesper Nielsen - Réponse
  4. Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 4, image 1 de 2 Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 4, image 2 de 2
    • Utilisez le bout plat d'un spudger pour retirer délicatement la partie du câble de la caméra frontale de l'ensemble de l'écran.
    When reassembling, I found an unknown, small black plastic piece on my work surface. It wasn't anything that I'd removed in any step. It had a curved section and a small tab, the whole thing was less that 1/4". Nothing in any of the instructions mentions it.
    I finally figured out it was supposed to go just to the right (while looking at the open back of the screen unit) of the hole where the camera fits. The semi circle hugs the side of the camera when you reinstall.
    This had me going nuts for about 30 minutes. Hopefully this info can help you avoid that.
    Mike Yagi - Réponse
    That rubber piece should be put back on the ambient light sensor (pink, purple). Like you said, it hugs against the front camera.
    Didier Daniel -
    I gotta say, reassembling this assembly it very fiddly and painstaking. There are lots of little parts that need to fit into other little parts while engaging yet other little parts. Seriously, and exploded diagram of all these little parts would be helpful! I took my time, used a very bright light and a magnifying hood while disassembling and reassembling and it really helped.
    Sheldon Carpenter - Réponse
    The small black piece is part of the front facing camera housing, can I also point out to make sure that you remove the clear plastic camera lens housing from the old screen too, and make sure that this and the small rubber housing are placed onto the new screen as these are what hold the lens, the microphone and the ambient light in place. There maybe a small amount of glue around the lens housing which needs to be removed with a sharp blade, please take care when doing this.
    Roberto Enrieu - Réponse
    Thanks Mike and Didier, great help !
    tahiruysal - Réponse
    What is that thing for? I replaced the section for my brother and his cheap repair part came without that thing to stick on and it seems to work…
    Jokl92 - Réponse
  5. Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 5, image 1 de 3 Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 5, image 2 de 3 Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone 5s: étape 5, image 3 de 3
    • Si vous rattachez le même protecteur plat sur votre nouvel écran, vous n'avez pas besoin de retirer l'ensemble de câble de la plaque LCD. Sautez cette étape.
    • Retirez délicatement le câble de la plaque LCD pour l'enlever de l'écran.
    • Faites attention à ne pas agripper le câble numériseur pendant que vous retiriez la caméra frontale et la nappe de capteur.
    I would skip Step 24. Why would you remove the very delicate cable assembly from the LCD shield plate only to reattach it to the same shield plate after fastening the shield plate to your new display assembly...
    kevindfrye - Réponse
    Indeed. I just did one today and realized it would have been fine to leave it. Better even.
    Paul Jerome -
    Only minor thing: It's step 25 you should skip. I replaced my wife's last night and skipped it. Skipping Step 25 was definitely a wise thing to do, since you're simply putting it right back on the same piece once you put the phone back together.
    pbpope -
    Does anyone know what the copper sticker is for? I accidentally ripped mine apart trying to get it off, it tore easier than paper, being that I didn't even notice I did it until I noticed it was ripped. I also thought to myself, why the heck did I remove this thing when I didn't need to. I've been trying to google it. it might be "iPhone 5S Rear Camera Cooling Copper Adhesive Sticker" but there is no reference as to how big that is. Anyway, I assembled it as normal and the phone works perfectly fine. So any help would be appreciated.
    aaron - Réponse
    I got the same problem with the copper sticker,it has been tore! Is anybody can explain what does it for and where can i get it?!! Because the phone not working properly. Any help would be appreciated.
    Mark - Réponse
    Didn`t tear it , but there is no use in removing it since reusing LCD protector later, !@#$%^ me off. :-)
    eriwolde - Réponse
    Why remove the copper sticker? Why not leave it attached since your are going to reuse LCD protector. Remove the home button before the camera and light sensor and save the LCD protector for last with everything attached to it.
    Marshall - Réponse
    I thirdly will ask for what the copper sticker is for!? I thought some kind of grounding?? I tore mine and the front facing camera is fuzzy now. It looks grainy. Almost like it isn't grounded good. ANY advice here would be appreciated.
    Thanks
    Kent - Réponse
    Agreed. Skip step 25. I can't fathom why it's in these otherwise excellent instructions.
    leanit - Réponse
    Agreed - you don't need to do this step
    kevinhay - Réponse
    Also skipped this step.
    jonl - Réponse
    I tore mine also...wish I would have come here and read these helpful tips first.
    Michael Huber - Réponse
    The copper sticker is some kind of ground connection, and is therefore probably very important given the frequencies present inside the phone, and that the phone is itself a radio transmitter and receiver. I too followed the instructions and removed it but I was super careful and didn't tear it, and was able to reattach it. I used the spudger to smooth it and ensure that it makes good contact with the shield. It didn't even occur to me to skip the removal step! But I agree with that advice.
    Mark Cousins - Réponse
    Replacement Front Camera and Sensor Cable didn't have such sticker. Where this sticker should be reattached?
    fedor -
    step 32:while removing that piece on the LCD shield plate , I sheared that cable which is connected to the shield plate, so I skiped it and completed fixing, after that I found out that my iphone is not working .. I don't understand the problem from this cable or from the new screen ..
    please help ..
    email: maamoon95@hotmail.com
    maamoon95 - Réponse
    I phone 5s. During peeling off the shield plate from the LCD plate i damage it. What parts should i buy to replace this shield plate? lsanevich@gmail.com
    Sanevich - Réponse
    I did the same as the above to people what part do i need to replace to fix this. I think this is causing my touch portion to not work. My email is camgoins23@gmail.com
    Cameron Goins - Réponse
    I also ripped the copper cable. However when I booted the repaired phone without it, it wouldn’t boot. It was stuck in a loop. To fix this and it worked for me, hold the home button and power button until the phone display turns on again
    Josh Nugent - Réponse
    What is the sticky plastic that I am peeling off called I tore that. Can I replace it?
    Tabatha Hurley - Réponse
    If you stuck as me with attaching copper to back of the camera try:
    1. put camera into the slot
    2. move cables in that way to see metal back of the camera
    3. copper should be able to stick into the camera in ‘natural’ way
    Bartosz Kolada - Réponse
    In Mine,it is attached to the head of the can.like it was connected to it.
    cesar-kramer - Réponse
Pour remonter votre appareil, suivez ces instructions dans le sens inverse.
9 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sam Goldheart
Membre depuis le 10/18/12
465 741 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 767 tutoriels rédigés
2 commentaires
Be great if someone could put together some *reassembly* instructions for this. Particularly the section on the camera and sensors area.
Phil Thomas - Réponse
It seems like a lot of steps have gone missing from this guide. The related guide (5SE) has much more explicit instructions for the same activity and should be used instead of this one. Remplacement de la caméra frontale et de la nappe de capteur de l'iPhone SE
Jeannie Crowley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 6,308
