Aller au contenu principal
Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058
Ce dont vous avez besoin
  1. Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058, Panneau arrière: étape 1, image 1 de 1
    • Posez l'iMac, côté écran, sur une surface plane et propre.
    • Desserrez les trois vis cruciformes qui fixent le panneau arrière à l'iMac.
    • Ces vis sont captives dans l'iMac. La vis centrale s'arrête de tourner après environ 3,5 tours et les vis extérieures après environ 5,5 tours. N'essayez pas de retirer ces vis de votre iMac.
    My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
    In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
    paulfrancoeur - Réponse
    The two outer screws each drive a locking bar that engage tabs on the rear panel.
    They definitely need to be unscrewed.
    Dale Stanbrough -
    That chick MJ is sexy!!!!!
    djmadcracker - Réponse
    Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
    Terry Mullane - Réponse
    Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
    James Janota - Réponse
    Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
    mary nicolazzo - Réponse
    These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
    Geek Squad - Réponse
  2. Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058: étape 2, image 1 de 3 Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058: étape 2, image 2 de 3 Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058: étape 2, image 3 de 3
    • Soulevez légèrement le panneau arrière depuis le bord inférieur de l'iMac.
    • Tirez le panneau arrière vers vous et retirez-le de l'iMac.
  3. Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058, Carte Bluetooth: étape 3, image 1 de 1
    • Retirez les deux vis Torx T6 de 5,5 mm qui fixent la carte Bluetooth à la carte mère.
  4. Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058: étape 4, image 1 de 2 Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058: étape 4, image 2 de 2
    • Pliez un trombone en forme de crochet et utilisez-le pour retirer la carte Bluetooth de son socle sur la carte mère.
    • Vous pouvez utiliser une spatule (spudger) pour retirer la carte Bluetooth, mais veillez à n'exercer qu'une force vers le haut, car toute force latérale peut entraîner le cisaillement du connecteur de la carte Bluetooth.
  5. Remplacement de la carte Bluetooth de l'iMac G5 17" Modèle A1058: étape 5, image 1 de 1
    • Utilisez une spatule pour détacher le connecteur de l'antenne Bluetooth de la carte Bluetooth.
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
10 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
WARNING: The last iMac G5 17" ALS (no isight) to be made does NOT have a dedicated bluetooth board.
I followed this guide and ended up removing the fax/data modem which is above the bluetooth board in this guide.
The last iMac G5's (17" no isight) to be made have a Airport Extreme/Bluetooth combo board:
http://www.applemacparts.co.uk/store/pow...
This is located to the right of the battery.
Ben Goodman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 15,938
