Aller au contenu principal
Remplacement de la carte mère de l'iPhone 7
Ce dont vous avez besoin
Vidéo d'introduction
  1. Remplacement de la carte mère de l'iPhone 7, Vis Pentalobe: étape 1, image 1 de 1
    • Avant de commencer, déchargez la batterie de votre iPhone au dessous de 25%. Une batterie au lithium peut prendre feu et/ou exploser si elle est accidentellement percée.
    • Éteignez votre iPhone avant de commencer le démontage.
    • Retirez les deux vis Pentalobe de 3,4 mm qui se situent sur le bord inférieur de l'iPhone.
    • Ouvrir l'iPhone fera perdre son étanchéité à l'appareil. Procurez-vous de nouveaux joints d'étanchéité avant de passer à l'étape suivante ou veillez à ne pas exposer votre iPhone à des liquides si vous ne remplacez pas les joints.
    Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
    Cooper Chase - Réponse
    Confirmed, the screws have a black ring seal around the head.
    rcheing - Réponse
    Can’t get the display front
    Bernadette Pfeifer - Réponse
    From personal experience, I highly recommend before doing this procedure or any other, that you do a backup of your phone (preferably local) in case your procedure goes south.
    ballina5ny - Réponse
    I purchased the repair tools with the replacement battery from iFixit. The tools include a screw driver and three heads none were labeled 3.4 mm. I think the one that fit the pentalobe screws was labeled Y000. The guide should identify the screw driver head supplied by the kit not 3.4mm.
    Mark Lieberman - Réponse
    in the iphone 7 replacement battery kit from iFixit, the screwdriver that fits the 3.4 mm pentalobe screws is labeled P2 (and not Y000)
    Jan-Tijn Oppermann -
    3.4 mm is the height of the screw and is not related to the screw driver code.
    Ahmad Vaziri -
    the screwdriver PH000 does not work i wasted two screws and now they dont have the 4 cross mark they are now a circle, i buyed it all from Paraguay and it doesnt work, had to assembly back the parts because i got stuck like i mention with some screws, well im just going to send to a professional to install, thanks
    Martin Frutos, Nuñez - Réponse
    The bottom screws are Pentalobe, not Phillips.
    Bram Driesen -
    Before starting, I would recommend backing up your Iphone’s data just in case.
    Jon Moylan - Réponse
    If you managed to make it to this section, just send the phone into apple for 50 + 6 dollars shipping. The ribbon cables on the screen are designed to break. I can literally twist on the rest of the cable and it won’t fall apart but there is a diagonal section where it snaps. This is the fault of apple and the fault of ifixit for misrepresenting the fragility of the cables.
    Ryan Huebert - Réponse
    Had to reheat it a few times for a minute each with a hairdryer to get the seal to break after pulling and rocking the suction
    Cynthia Lamb - Réponse
    I’m technically challenged. Is there a premier national service who can professionally install a replacement battery got my 7 +?
    Richard - Réponse
    Do the screws come out in total?
    YVES THEUGELS - Réponse
    They may come out or may not. If you loosen as much as you can and they don't come out you should still be able to pry open the bottom. Once you get the screen off you can then push the screws out from the inside.
    Anthony Falabella -
    Is it the P2 you should use for the bottom??
    I heated the bottom of the phone with a hairdryer and then used a syringe to put a couple of drops of acetone directly into the bottom two screw holes. I GENTLY pulled on the screen with the suction cup and used the pry tool to GENTLY separate the screen. The sealant is applied around the entire display so be very careful pulling it off so you don’t break the fragile display cables.
    Anthony Scaminaci - Réponse
    At first it was very difficult to open, per instructions. I used a heat/ice pack and nuked it for 1 minute. The pry tool wasn’t working so I carefully used my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, place the taptic engine before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit. Good job on hosting the video, Gwendyl.
    Klaus Preiss - Réponse
    I love the fact that the screw bit and shaft are magnetic! I almost lost a screw and found it attached to the magnet.
    I used a heat/ice pack and nuked it for 1 minute. At first the display cover was very difficult to open with the pry tool, per instructions. The pry tool wasn’t working so I carefully used the blade of my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, see the taptic engine in place before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit because I placed it almost too low.
    I replaced the lightning connector assembly and reassembled. The old one did not 'click' into the cable and had corrosion inside, it needed the cable to be placed in a specific way to charge. The new part - does not recognize that a charger is plugged in at all.
    I backtracked the assembly - took it apart, put it back again - and find that every thing on the part works - the mic, speakers, taptic engine.
    The original problem with the cable still persists. Any ideas?
    H K - Réponse
  2. Remplacement de la carte mère de l'iPhone 7, Procédure d'ouverture de l'iPhone 7: étape 2, image 1 de 1
    • Faire chauffer la partie inférieure de l'iPhone aide à ramollir la colle qui maintient l'écran et rend plus facile d'ouvrir l'appareil.
    • Utilisez un sèche-cheveux, ou bien préparez un iOpener et posez-le sur la partie inférieure de l'iPhone. Patientez environ une minute, ceci fera ramollir l'adhésif en dessous.
    ¿Cuántos segundos son los recomendados?
    joscarlos91 - Réponse
    Sesenta segundos
    Krutav Shah -
    It is a process. I heated the lower area of the phone with a hair dryer on and off (1min each) about 3-4 times before I was able to get the provided tool in.
    Dan - Réponse
    I suggest using a hairdryer. I used the iOpener for maybe 30 mins to no avail. However, when I used the hairdryer the screen came of much quicker.
    Michael - Réponse
    I totally Mr. Myagi’ed it, by rubbing my hands together until they burned, then held the phone un my hot hands. I did this 5-6 times over a couple of minutes. It was a good zen way to get started!
    Ark - Réponse
    Can a heat gun be used?
    Lee - Réponse
    Absolutely. Just don’t overdo it—the adhesive usually softens up pretty easily. If you are experienced with a heat gun, you’ll have no problem. (If you are inexperienced, it’s easy to cook the display or cause other damage.)
    Jeff Suovanen -
    If i use this process, will iphone 7 still be sealed, water/ splash resist after that?
    Marius Serban - Réponse
    Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Angel Hermida -
    Can I use a cpb heating pad to soften the adhesive ? If yes how much time and temperature ?
    davidecongiu - Réponse
    Will doing this compromise the screen protector (Zagg) that I have on my phone?
    Eric Nance - Réponse
    Hairdryer worked for me but I needed to use a razor to pry it open at the bottom then used the spudger
    Gina Torres - Réponse
    Is there a reason why you wouldn’t put the iopener over the entire length of the phone, instead of just the bottom corner?
    BPX - Réponse
    The motherboard is extremely sensitive to heat.
    Neal Reasland -
    Hello can the head damage the id touch bottom?
    After heating opening it stoped working.
    Qrizmasex @ gmail . Com
    aratovski - Réponse
    It definitely can. That happened to me.
    Steve Naylor -
    mine didnt come with a heat pack do i use a hair dryer
    Shy Rose - Réponse
    I just threw a hand towel in hot water, and then stuck it into a plastic bag. Dryers work fine, too.
    hiroo yamagata -
    Thanks for this, the other instructions make it seem SOOOOO simple to open up the case with the suction cup! It actually is hellish. The instruction here about the pre-heating and the required patience really helped!
    hiroo yamagata - Réponse
    For those of you who don’t have an iOpener or a girlfriend, I used a ziplock bag with some instant mashed potato inside. It worked perfectly first time and you can fold the bag around the ID button in order to prevent damage to it.
    You also get to celebrate by eating the mash afterwards, HUZZAH!
    Adrian - Réponse
    🤣 You made my day Adrian, thank you!
    Jicey -
    I found this to be completely useless. It didn’t help at all. I had to use a heat gun instead. Waste of money.
    David Gordon - Réponse
    I’ll experiment with leaving the phone in the sun until the Temperature Warning comes up so the phone tells me when it’s too hot to be safe.
    Maybe it will be hot enough, maybe it won’t—
    edmk5000 - Réponse
    I use a rice pack in the microwave. White dry rice in a sock sown or tied, then microwave (1 minute +/-). The dry rice heats and retains heat for a long time. My kids loved them in in bed during cold winter nights.
    Todd Oeftger - Réponse
    I have changed now Iphone 5 Battery, IPhone 7 front camera & another iPhone 7 rear camera. The instructions along with the comments are really important. Be patient & read them several times. By using your heated gel pack 3-4 times for 2 mins or so on the bottom end near the touch button you will be able to pry with your razor & then you can use your spudger. Thanks for this great guide.
    Kala - Réponse
    I would DEFINITELY recommend to NOT use direct heat (hair drier, etc.) on the phone. I used a hair drier to help heat the phone and ended up damaging the home button (would not work after the replacement and I did not touch or take apart the home button). Note that a damaged home button cannot be replaced so I will end up using the alternative “screen” home button going forward with my phone. Instead I would recommend preheating something else (example - metal / coins / ceramic / beads / glass stones / cookware / etc..) to a warm-to hot (but not burning hot) touch and place the heated items on the IPHONE (or visa versa) to heat and soften the adhesive.
    Ed Scannell - Réponse
    I used 1-gallon Ziploc back and poured 1qt of boiling water into it. I placed my iPhone on a corkboard and the bag on top for 120 sec.
    It worked like magic. I just pooled the screen with the suction cup, and it got loose from the case. No heat damage. Everything works.
    it500 - Réponse
    I placed the iOpener heat bag over the bottom of the phone, disregarding the home button. Now it doesn’t work. All subsequent procedures went well as I was very careful. I should have read all the posts! Protect the home button from direct heat. Fortunately, now using the Assistive Touch feature is better than buying a new phone or replacing the home button.
    Kurt Bee - Réponse
    It’s better to choose an iPhone back case to cover and protect your phone from bumps and scratches. Choosing premium cases is the best option for long-term safety. If you need ***iPhone 7 phone cases*** then you can check them out!
    FLAUNT - Réponse
  3. Remplacement de la carte mère de l'iPhone 7: étape 3, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 3, image 2 de 2
    • Posez une ventouse sur la partie basse de l'écran, juste au-dessus du bouton home.
    • Assurez-vous de ne pas poser la ventouse sur le bouton home, ceci empêcherait la ventouse d'adhérer à la vitre.
    • Si votre écran est méchamment fissuré, le couvrir de ruban adhésif transparent pourra aider la ventouse à adhérer. Sinon, une bande à fort pouvoir adhésif peut être utilisée à la place de la ventouse. Si rien ne fonctionne, vous pouvez coller la ventouse à la superglue sur l'écran cassé.
    The glass is completely cracked and the suction cup doesn't work because it gets air in between. any tip?
    Display is glued and doesn't come off.
    support - Réponse
    A wide, single strip of packing tape, well placed, will solve this for you. :)
    Mimic44444 - Réponse
    Last comment works well. Thank you !
    Using packing tape for a cracked screen should be included in the description in Step 3.
    Cracked screen is most probably the reason you are replacing it.
    Arni Benediktsson - Réponse
    I agree that using packing tape for a cracked screen should be included in this steps description. I don’t have wide but turned mine horizontal and that worked great.
    Mary Knapp - Réponse
    Bekomme die Oberschale einfach nicht runter! Trotz mehrmaligem erwärmen durch den iOpener und seitlichen bewegen! Weiß nicht mehr weiter!
    Stephan Lienhard - Réponse
    Wouldn’t that screw up the Touch ID?
    Rexx Havok - Réponse
    The suction cup that is. supplied with the essentials kit doesn’t work that well.
    Laurence - Réponse
    Agreed, the iFixit suction cup was useless. I borrowed one from the sponge holder in my kitchen sink. It lacked a grip so I held it with needle-nose pliers, resting them on a bit of wood to keep pressure off the phone.
    ephraim -
    I am not getting this open at all! Why an I provided with tools that can't help me ??‍♀️
    Bray Joseph - Réponse
    I couldn’t get the bottom to lift first, but the left side did, so I started there and worked my way around the horn.
    selimnairb - Réponse
    Hold the suction cup provided in almost boiling water with tongs for about 30 seconds, then it will actually work :-)
    AKA - Réponse
  4. Remplacement de la carte mère de l'iPhone 7: étape 4, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 4, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 4, image 3 de 3
    • Tirez sur la ventouse pour créer un petit espace entre l'ensemble de l'écran et le boîtier arrière.
    • Insérez l'extrémité plate d'une spatule (spudger) dans l'espace créé.
    • L'adhésif étanche maintenant l'écran en place est très résistant, et créer ce premier espace demande de la force. Si vous avez des difficultés à ouvrir un interstice, bougez l'écran de bas en haut pour décoller l'adhésif jusqu'à ce que vous puissiez insérer une spatule (spudger).
    This was SO hard for me to do with the spudger. I couldn’t get a gap to insert it because my phone was so cracked (even though I used tape on the front) to get a solid seal with the suction cup. I ended up taking a VERY thin knife and inserting it straight down to make the initial break that allowed me to insert the spudger.
    jessica harlow - Réponse
    I’ve given up using a plastic spudger to try to open any of these phones. I use a metal one with a flat base and a very sharp end…close to a razor. As long as I’m careful, it won’t slip and scratch the base. It’s much easier than using these plastic spudgers.
    mcr4u2 -
    I confirm that the plastic spudger it’s not the best tool for this operation. I suggest to use a larger metal tool like a “Jimmy” or “iSesamo open tool” (I used the first one)
    Cristef -
    Im trying to get the screen off right now and my phone is not cracked and its still a pain
    Jordon Johnson - Réponse
    Using a blow dryer was extremely helpful and using the suction cup towards one of the lower edges was also helpful
    This is not working for me. How long does the heat need to be applied? Still trying right now…. =/
    Chris Gallego - Réponse
    Apply hair dryer for at least 1 minute. I inserted the tip end of a thin mini screwdriver and with some force, pryed it open and inserted my plastic spudger to continue the separation process. It worked, just be patient.
    Please wear protective glasses! My iPhone glass was severely cracked, when separating the glass a corner area of broken glass exploded in my face. Apply transparent tape over the broken glass to contain the shards.
    amberron - Réponse
    I second Jessica’s January 8 comment.  I just finished a battery replacement on my iPhone 7 and this step was the most nerve-wracking part.  I ended up using a sharper (but not razor-sharp) metal object to get this done with confidence (tried the spudger and guitar pick but not thin enough).  The tool I used was the exact duplicate of what iFixIt calls “iSesamo Opening Tool” in their tool selection.  I did the heat up with a hair dryer (after attempts with an iOpener hot pad) and the secret (as Jessica also noted)  was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup.  From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture).  I actually used the metal tool for most of the perimeter as well, just don’t go deep (you don’t need to).  Notes: my display was intact, and I was able to pull up fairly hard with a glass screen protector still on it.
    Ted - Réponse
    This is frustrating. I heated the lower edge with a hair dryer for 1 min on high about 3-4 times. In between each heat cycle, I rocked the suction cup back and forth. I was eventually able to create significant space for the provided tool. This takes a lot of patience. Once the space was created, it was very easy to remove the screen.
    Dan - Réponse
    use a fingernail, then the blue tool, then the spudger
    Therese Peffer - Réponse
    The iOpener worked just fine for me. Had to keep it on for a few minutes. I also was able to get the suction cup seal right close to the edge, over top of the home button for added leverage. Used the blue tool and transitioned to the spudger. Slow, steady pressure…and patience. ;)
    johnhall918 - Réponse
    Unable to open an iPhone 7 display assembly. Used gell pack at 150 degrees F. The phone wouldn’t budge when I used the iFixit suction cut. Part of the problem is that the cup doesn’t adhere for long before it looses suction. I suspect it would work better on unbroken glass, but that doesn’t help me now. After spending a lot of time at this, I changed heating methods to a hot air heater. I raised the temp of the bottom end of the phone to, ultimately, 175 degrees, and used a variety of tools to try to pry the glass apart enough to get a spudger (or anything) in, but it didn’t even lift enough for a double-edged razor blade to get in. I’ve been trying this for hours now, and about to give up and throw a lot more money at this to have a service perform the work. I figured that 175 was as high as I should need to go to soften the adhesive without damaging the electronics. Should I have gone higher? I see no mention of measured temps in any instructions or comments.
    ted - Réponse
    Have you tried applying tape to the broken screen? This will help a lot with keeping the suction cup on it.
    Christian Groothuis -
    It doesn’t need to get very hot; pulling up on the display is mainly what does the trick. Make sure the two pentalobe screws have been removed and then try the tricks in this step. If all else fails, superglue the suction cup to your display and let it cure, and then pull. Keep in mind you only need a tiny gap to insert a plastic pick and start cutting the adhesive. Good luck!
    Jeff Suovanen -
    Just a question. After this operation the impermeability function was compromitted?
    bentek86 - Réponse
    The trick I found, was to add packing tape right across the bottom over the home button then use hairdryer on the end, then suction cup on the very bottom and it lifted enough to get a gap. No one mentioned how it would be impossible to handle the phone after the hairdryer ;)
    Andrew Lansdowne - Réponse
    Didn’t have an iOpener and 60 seconds on a hairdryer wasn’t doing it for me. Still wouldn’t budge. I had to take a very sharp razor along the seam at the bottom between the speakers. It took about 20 passes for it to separate enough to get the spudger in. Make sure you keep the razor at a 90-45˚ angle and that it goes no more than 1-2mm into the phone. The bottom of the phone is metal, but the casing for the screen is plastic. So if you cut lower than a 45˚ (flat with the phone) you risk cutting into the casing. Apply light pressure when making the passes. I would just do the razor on the flat part on the bottom.
    minimalist - Réponse
    I used a hair drier while lifting up at the same time until I could get the too inside. The seal is pretty finicky. Just take your time and you should be fine. Work the hair drier and the tool all the way around before lifting the screen up and off. There will likely be sealant stuck between the screen and phone. You can just break it with the tool.
    Ray Bieze - Réponse
    This step was impossible for me despite using a blow dryer and having no cracks on the screen. I finally took it to a local repair place and had them do battery replacements for two iPhone 7’s. The girl let me watch her do it. She used a razor blade (just until she had a small opening that she could hold open with her fingernail) and confirmed that she too would have difficulty opening it with a plastic tool and suction cup. The plastic tool was great for prying the rest of it open once a crack was there, but she said she would never try to use that as the tool to initially open it. The tools provided for initially prying open the screen are inadequate.
    Chad Twedt - Réponse
    Hopeless - no chance to get the screen off without any damage. No matter what tools, heat etc.
    Anatole Beams - Réponse
    I second what others have said, definitely use a razor blade to break the seal! Heat helps some, but too much direct heat is bad for the screen. Would have been impossible if I hadn’t read the comments, thanks everybody!
    Kit - Réponse
    Use extreme caution on this step. I was just replacing my battery and now i’m buying a new screen. The screen was very stuck, I pulled to hard and it popped off suddenly, completely destroying the screen.
    moose - Réponse
    When the right heat is reached, the easiest way is to use a metal iFlex to create the initial gap, then insert the Jimmy or iSesamo next to it so the gap gets bigger, at this point you can get in with the flat edge of a plastic spudger and slowly slide it in the borders to cut the adhesive. You will still need to force a bit the upper end to separate the screen by pulling it down while keeping up the screen, and twist to the right. I hope this is clear enough. Never apply too much strength too quickly anyway.
    Stefano Restuccia - Réponse
    I used the short blade of my swiss knife to make an initial opening. Using the sharp edge, inserting about 1 mm straight down and twisting down into a 45° angle. Then I was able to insert the spudger.
    John van de Loo - Réponse
    This is a difficult step. Fortunately, I had another suction cup from an earlier repair available, so I applied one to each side of the phone. After warming with a hair dryer, I was able to pull the two suction cups far enough away that another person could easily insert the spudger.
    The third hand was essential.
    Mark - Réponse
    I found this tactic to be the best solution for us. I used two suction cups, one on each side of the phone, and another set of hands to get a pry tool under the display. We still had to take our time prior while heating the adhesive, but were able to pry the display fairly easily using the two suction cup method.
    Lucas -
    It was a really excruciating process of heating, lifting with the suction cup, trying to slide in the spudger/pick, and repeating the process for 20 times or so. But in the end, my patience paid off!
    I used a hair dryer, then used a safety razor blade parallel to the bottom edge to push straight down (from the glass side, towards the back) while lifting with the suction cup. I wiggled the blade (top to bottom) while pressing down gently, until I saw a gap that would accept the spudger. It did not take much force on the blade or much wiggling, just patience.
    Gene Merritt - Réponse
    Followed Gene’s approach with heat and a razor blade. I was nervous, but went slow; it was very easy and effective. Great tip. Just be patient and don’t rush yourself.
    Michael J - Réponse
    I would skip right to using a single edge razor blade and a hair dryer to create the gap needed for the spudger.
    Logan Brown - Réponse
    Think plunging the toilet - it did not work for me for a long time. the suction cup would not stay held on a long pull. I found that tiny push-pull repeated motions, reseating the suction cup with each push slowly overcame the adhesive, and contributed heat :). I had it after about 50-70 cycles
    Andrew Balanda - Réponse
    seconding this comment from Ted ~~~ “the secret (as Jessica also noted)  was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup.  From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture).”
    natjpollard - Réponse
    I echo what everyone is saying here, the spudger just isn’t good enough for this and neither is a pick. The razor is the best way to go. I tried using a very sharp penknife blade and managed to damage my LCD (somehow!) and the bezel so I ended up having to buy a new screen display as well as a new battery. Think twice before doing this. Be prepared to shell out for a new screen just in case it goes wrong. You’ll also need the heat gun (the iopener was useless). If you do need to buy a new screen, make your life easier and get one with the speaker, forward-facing camera, home button, etc., already attached (you can then replace the home button) or you’ll end up having to transfer all these from your old display.
    I finally got the screen up but shattered it in the process. I was replacing it anyway but if the screen is not what you’re replacing, take EXTEME caution. The suction cup and spudger were not working for me to get it started. Thanks to the comments, I used a razor blade and a heating pad and went back and forth, back and forth, between heat and pressure from the blade. Once you get a gap, the spudger works great and the screen comes up easy.
    Nick Nave - Réponse
    The suction cups that iFixit sells are crap. They don’t stick at all. Glass on the phone is pristine.
    Nick - Réponse
    More feedback on this “guide”:
    “Pull up on the suction cup.” What does this mean? If I just pull up on the suction cup (with a real one that actually sticks) it just lifts the phone off the table. You need a description of what you are pulling against. Do I try to hold the frame of the phone? Do I try to stick something in the lightning port to pull against? Do I try and get something against the edge of the rounded metal on the edge of the phone (this usually just slips off). What am I pulling against???
    Nick - Réponse
    I found a combination of iOpener, suction cup and razor blade, all applied at the same time, worked for me and I didn't need to use a hairdryer.
    Peter Gray - Réponse
    Dumbly, I thought that with the Spudger I'd had to hold the phone from the charging hole while pulling the screen. .. In the end I inserted the two ends of the tweezers(bends the tweezers and may damage it) in the screwdriver holes and pushed the screen out upwards so that I could insert the sharp side of a knife.
    Claudiu Cezar - Réponse
    This was my first iPhone battery replacement and I can say this was the hardest part.
    Be wise, go for a hair dryer and heat up the phone bottom (long enough). iOpener did not work at all for me. Heat up, use the suction cup and push the opening pick under the frame as soon as you see movement along the frame.
    Then use the spudger to wander around the whole frame (leaving the pick where it is). Done!
    Guenter - Réponse
    True about sputter i cracked my screen trying to lift it up while using this device back in 2021
    DJSan - Réponse
    One little corner at a time. Don't try to do the whole bottom at once. I heated with a hair dryer. Applied the suction cup to one side and worked the corner till it started to give. Took a minute or two. Use a magnifying glass to help see when it's starting to come loose. It's not hard to do.
    Some Idiot - Réponse
  5. Remplacement de la carte mère de l'iPhone 7: étape 5, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 5, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 5, image 3 de 3
    • Glissez le spudger vers la gauche le long du bord inférieur de l'iPhone.
    • Tournez le spudger pour agrandir l'espace entre le boîtier arrière et l'écran.
    I used a hairdryer and a razor
    The photos are a con. You cannot get a spudger in unless you can lift the screen. You cannot lift the screen because of the adhesive. Using a anything metal will damage the paintwork or the glass edge.
    I agree, these guides are half imaginary idealism it seems. A thin metal edge pushed vertically down just a fraction of a mm will cause the adhesive to weaken better than any amount of heat, but affects the final appearance sadly.
    Jesse de Vries - Réponse
  6. Remplacement de la carte mère de l'iPhone 7: étape 6, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 6, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 6, image 3 de 3
    • Faites glisser la spatule le long du côté gauche en commençant par le bord inférieur et en travaillant vers les boutons de contrôle du volume et le commutateur du silencieux.
    • Ne faites pas levier le long du bord supérieur de l'écran, vous risqueriez d'endommager les clips en plastique qui fixent l'écran.
    Be VERY careful on this next step going up the right side of the phone. There is a ribbon cable 1/3 of the way up from the bottom that is very close to the edge. Do NOT use the blue triangle!!!! Just lightly rotate the spudger to get separation on the edge.
    Timothy Varvais - Réponse
  7. Remplacement de la carte mère de l'iPhone 7: étape 7, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 7, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 7, image 3 de 3
    • Insérez l'extrémité plate d'une spatule (spudger) dans le coin inférieur droit de l'appareil.
    • Bougez la spatule pour agrandir l'espace entre l'écran et le boîtier arrière.
    • Faites glisser la spatule le long du bord droit du téléphone tout en défaisant l'adhésif qui maintient l'écran.
    • Surtout, n'insérez pas la spatule plus profondément que la bande adhésive, pour éviter d'endommager les nappes très fragiles du côté droit.
    Shoot. I broke the sensitive ribbon cable because I didn’t quite understand what the instructions meant with not to insert the spudger further than the adhesive. It means depth wise, not up the side. Sigh.
    Leo Hwang - Réponse
  8. Remplacement de la carte mère de l'iPhone 7: étape 8, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 8, image 2 de 2
    • Tirez sur la ventouse pour soulever l'écran et ouvrir l'iPhone.
    • Evitez de soulever l'écran à plus de 10°, des nappes relient l'écran à la carte mère le long du bord droit de l'appareil.
    do not pull up pull sideways it will brake
    Riley Patterson - Réponse
    Made this mistake
    rachael.grime - Réponse
    Somehow my phone turned itself back on during the opening. Scared me a little, like a patient coming out of anesthesia during the operation. I was able to turn it back off. Gotta be more careful where you grab this thing.
    Bryant Larsen - Réponse
  9. Remplacement de la carte mère de l'iPhone 7: étape 9, image 1 de 1
    • Tirez vers le haut la petite bosse de la ventouse afin de la séparer du panneau frontal.
    very nice
    iPhone 7 back cover
    http://WHITEWINGS.IN/
    Vikash Kumar - Réponse
  10. Remplacement de la carte mère de l'iPhone 7: étape 10, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 10, image 2 de 2
    • Faites glisser un médiator le long du bord supérieur de l'iPhone, entre le boîtier arrière et le panneau frontal pour briser l'adhésif restant qui maintient l'écran en place.
    • Veillez à ne pas endommager les clips en plastique sur le bord supérieur du téléphone.
    The plastic clips mentioned are on the top of the screen being replaced… so not sure why it matters not to break them. Trick here was to pull the screen downwards to open a gap at the top and then insert as shown and raise to break the seal.
    This is relevant for other guides than the display replacement guide.
    jvalaamo -
    プラスチックのクリップという
    表現に混乱しました。
    上部に食い込んでいる
    差し込みのことだったんですね。
    下に引っ張ったら抜けました。
    情報ありがとうございました。
    MARU - Réponse
    The opening pick is packaged with the battery, not the tools, so I didn’t find it until I was past this step. Made do with careful use of the spudger and a lot of wiggling the display to break the glue.
    ephraim - Réponse
  11. Remplacement de la carte mère de l'iPhone 7: étape 11, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 11, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 11, image 3 de 3
    • Eloignez légèrement l'écran complet du bord supérieur du téléphone pour dégager les clips le maintenant au boîtier arrière.
    • Ouvrez l'iPhone en pivotant l'écran vers le haut en partant du côté gauche comme la couverture d'un livre.
    • N'essayez pas encore de séparer l'écran complètement, car il y restent plusieurs nappes fragiles qui le relient à la carte mère de l'iPhone.
    I just broke the cable to the battery!
    No Bama - Réponse
    same dude im such a freak lol omg haha
    Aiden Polaski - Réponse
    Are there replacements ribbons?
    Blax Bently - Réponse
    Has anyone else noticed very small squares of rubber with a circle cut through it (I think they fall off into the phone when dismantling)?
    I just replaced my screen and worked out that these are actually a wee pocket that slips over the pentalobe screw holes on the replacement screen. I’m not sure if it’s an additional water resisting mechanism or if it’s to add additional traction for the screws
    richarddillon - Réponse
    Thanks, I was wondering where those were from!
    Albert -
    Same, I only had one fall out and I had no idea if important, and didn’t re-add - because I wasn’t sure where it fell from - but it was definitely from the home screen button….watch it be important. -__-
    Nicole Crome -
    I just broke cable connecting camera and earpiece speaker to logic board. Be careful with it.
    Natan Haładyn - Réponse
    This section is missing a critical step - to lay some Post-It notes or something below the right half of the phone when you swing it open, so the ribbon cables don’t get sliced by the sharp edge of the phone case. I broke the Home Button ribbon cable because there was no strain relief when I laid it open.
    neila - Réponse
    I also broke the home button cable and now I have to use assistive touch.
    Laurencio Gonzalez - Réponse
    Keep the suction cup on the display to keep it propped up while you disconnect the ribbon cables.
    I broke the short ribbon cable that attaches underneath the lower connector bracket. Be SURE when you lift the display, you do it from left to right. I thought I had the phone oriented correctly in my hand, but I was mistaken.
    John Murray - Réponse
    Put the suction cup on the right side of the middle of the screen when you rotate it up and out. It serves as a nice stand to take the pressure off the connectors.
    Ray Bieze - Réponse
    no mention of what you do once u open the book. are the ribbons long enough to lie flat  or do we have to keep screen raised while removing screws,, like when we hold screen up 45 degrees while removing 5 screw plat when at top of phone. I only realised how fragile the ribbons are and how important it is to use suction  cup to rest screen on an angle so ribbons don't stretch or cut on frame.
    thanks for the above comments and probably the most important section. I just hope I closed t before I fdid any damage. its lke the fragility of iPhone 3’s all over again.
    scallyteacher - Réponse
    I just broke one of the cables… yeah, it is not nice… I’m lucky in the sense the screen is still working, but the button is not.
    Trying a cheap screen on Ebay (that contains the cable) do 20$, after that, it’s a new cellphone…
    Vincent Poirier - Réponse
    Be EXTREMELY careful when you lift up the screen. I broke 3D touch cable, and the home button stopped working. Had to replace the whole display.
    Sizun Cho - Réponse
    Attention ! J’ai cassé la nappe de la caméra avant !
    arnauldjouanny - Réponse
  12. Remplacement de la carte mère de l'iPhone 7, Déconnexion de la batterie: étape 12, image 1 de 1
    Outil utilisé dans cette étape :
    Tri-point Y000 Screwdriver
    $5.99
    J'achète
    • Enlevez du support du connecteur inférieur les quatre vis tri-point Y000 de longueurs suivantes :
    • Trois vis de 1,2 mm
    • Une vis de 2,4 mm
    • Tout au long de la réparation, gardez la trace de chaque vis et assurez-vous de la revisser exactement là où elle était pour éviter d'endommager votre iPhone.
    Ahhh shoot! accidentally ordered tri-wing vs tri-point (must have just looked for y000).. It seems they only did this to annoy repair folks because not everything is tri-point on the phone...
    Steve - Réponse
    These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
    Jeff Hurst - Réponse
    The Y000 took out one of the screws but not the other 3. I even tried the PH000 as suggested but nothing.
    dbright - Réponse
    What driver do I need to remove these screws i’m stuck
    Nasser Nader - Réponse
    i cant use, the Y000 it isnt working.
    What if I stripped a screw what do I do??
    Jacob Ramos - Réponse
    Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
    Stephen Babbage - Réponse
    It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
    Jim Staples - Réponse
    Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
    Magne Eivindson - Réponse
    For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
    Erik Fredriksen - Réponse
    What do I do if I Stripped one of them?
    Adam Corral - Réponse
    Can’t get them removed what to do ?
    cowling_luke - Réponse
    Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
    jimpoolio - Réponse
    You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
    Kyle Webb -
    The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
    Harmony - Réponse
    Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
    Chris Bennett - Réponse
    If you can’t get the bit to grip the screw properly, you can use a little bit of the water-proof sealing between the bit and the screw. That worked for me. Hope this helps anyone.
    jvalaamo - Réponse
    Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
    I used a bunch of medicine cups to track my screws. You need like 12 if you want them all in cups. I ran out. There are so many different sizes that literally vary by 1mm. The tolerances on these things are tight.
    Ray Bieze - Réponse
    I use a 28 day pill box and keep every screw separate and reburn to exact slot because they all vary in length, width and can really damage u phone if too long and nt secure if to small.  use a magnetised screwdriver,  or make the cheap freebees magnetic for a short period by rubbing it up an a magnet. lol
    Absolutely ridiculous had to go get a different one just stupid
    mark golling - Réponse
    I couldn’t get the lowest one out and just turned the metal bracket out of the way and replaced battery.
    qwerty77x - Réponse
    Was able to get the outer bracket screws out using fine needle nose pliers 90 degrees straight down for the outer ones by pressing down a little and using medium gripping force. Had to take these out first before i could use tweezers on the middle one, for which I had to use tweezers to hold the screw, then rotating the bracket (not the screw) counter clockwise a few mm many times over to slowly unscrew it 1/32th of a turn at a time, repeat. (this loosened middle screw). Think ‘rotating bracket 3minutes/degrees counterclockwise at a time while holding screw in place.) You are gonna need really small/fine pliers and tweezers for this because the heads are countersunk into the bracket.
    Galen Wollenberg - Réponse
    The top screw in the step was much longer than 1.2mm. It has the same head as the 1.2mm, but different than the 2.4mm. It’s good to keep track of where they came from.
    All are so small that I thought I’d lost one, when it was still sitting in the phone.
    Mark - Réponse
    To help tell if the screw is turning, put a small dot from a marker on the head of the screws.  This helped me to know I wasn't just stripping the head.
    Darren Thibodaux - Réponse
    try heating the iPhone with a hairdryer or a bag of rice or about 60 degrees in an oven for 3 minutes . It has worked for me. If the screws don’t come out while hot the will come out as the iPhone cools.
    David Howard - Réponse
    A small tapered triangle file using moderate pressure did the trick for me.
    Jack - Réponse
  13. Remplacement de la carte mère de l'iPhone 7: étape 13, image 1 de 1
    • Retirez le support du connecteur inférieur.
    my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
    Josh Martin - Réponse
    This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
    Oscar Moreno - Réponse
    So…I forgot to put this bracket back on when reassembling. Now I’ve adhered the display to the case and don’t have another adhesive strip…so I’m wondering: what purpose does this bracket serve? The phone is powering on and seems to work okay.
    Am I going to run into trouble with this bracket missing?
    Ian Fritz - Réponse
    Well, that didn’t last long. The phone shuts down without warning. So I guess that plate is important…
    Ian Fritz -
    I also forgot to put the battery shield in, and adhered the display. I’m tempted to leave it like that. However, your negative experience is a good data point telling me to not be cheap.
    Ordered a new adhesive , under $2 shipped from eBay.
    Yishai Sered -
    Thanks, Josh Martin! Mine was stuck too, so I lifted carefully.
  14. Remplacement de la carte mère de l'iPhone 7: étape 14, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 14, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 14, image 3 de 3
    • Utilisez la pointe d'une spatule (spudger) pour détacher le connecteur de la batterie de sa prise sur la carte mère.
    • Pliez légèrement la nappe du connecteur vers le haut pour éviter de faire contact avec la prise, ce qui risquerait d'alimenter le téléphone.
    Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
    Julian Eltrich - Réponse
    Reconnecting the battery poorly can cause the iPhone to appear to be properly powered and functional, but then suffer a reboot loop.
    I had difficulty after a screen replacement, and the Console app on my Mac showed that the ‘thermalmonitord’ process was throwing lots of errors from not getting any sensor readings from the battery. It would never charge past 1% and just kept rebooting.
    The contacts on this conector looked fine so even though I had reseated this connector several times already, I reconnected it very firmly using my thumb and a spudger to really press all the corners and middle and really gave it a good massage and then finally it showed the normal dead battery screen and started properly charging and eventually booted back up to normal functionality.
    It seems the battery has to be able to transmit data to the phone to say it’s not overheating or iOS will not allow any current into the battery to recharge it, and the kernel will panic from the null readings and just reboot over and over again.
    jason - Réponse
    In my case, the battery connector was attached to the bracket. We just left it connected bracket when we pryed it up.
    Dave Miller - Réponse
    Reconnecting the battery connector was a bit difficult in my case. The cable that comes out of the battery was a tiny bit too long, or that I placed the battery a bit too high (i.e., too close to the top of the phone). It took me several frustrating minutes of fiddling with the connector for it to sit right into the socket. I was not sure if that was connected correctly but, alas, the phone came back to life when it was turned back on.
    Tomoharu Eguchi - Réponse
    VERY IMPORTANT NOTE: Please READ the reply here by jason.
    It is very easy to knock off or nudge the little pins near the battery socket, see https://guide-images.cdn.ifixit.com/igi/... and https://guide-images.cdn.ifixit.com/igi/....
    Those pins are the data lines to extract battery info: temperature, charge, etc. If you accidentally nudge/knock off them the phone could appear to work normally, even for a few days. But then you will start getting wrong battery reads and then after that it may suffer a reboot loop. If you enter settings > privacy > analytics & improvements and you scroll down you will find panic errors from thermalmonitord that there are missing sensors (TG0B or TGXXX) and you will have to micro solder them. DO NOT NUDGE THEM and double check the socket connector when reconnecting the battery.
    PJM - Réponse
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all! Careful removing the lower bracket - mine was stuck to this battery connector, which came up with the bracket. Luckily no cable or connector damage. Be careful. Thank you all!
    dantegd - Réponse
    after installing new ifixit battery kit, note the foam on the new battery is thicker than old apple one, managed to remove the old foam and swap to new battery connector, sheild plate now level
    Neil Mills - Réponse
  15. Remplacement de la carte mère de l'iPhone 7, Écran complet: étape 15, image 1 de 3 Remplacement de la carte mère de l'iPhone 7, Écran complet: étape 15, image 2 de 3 Remplacement de la carte mère de l'iPhone 7, Écran complet: étape 15, image 3 de 3
    • Assurez-vous que la batterie est débranchée avant de déconnecter ou reconnecter les nappes de cette étape.
    • Utilisez l'extrémité plate d'un spudger ou un ongle pour débrancher les deux connecteurs inférieurs de l'écran en les tirant tout droit hors de leur prise sur la carte mère.
    • Pour reconnecter ces nappes, appuyez sur une extrémité jusqu'à ce qu'elle s'enclenche, puis répétez avec l'autre extrémité. Ne pas appuyer sur le milieu. Si le connecteur est même légèrement en désalignement, le connecteur peut se plier, causant des dommages permanents.
    • Si l'écran reste noir, des lignes blanches apparaissent ou que le retour tactile manque complètement ou partiellement après que vous ayez remonté votre téléphone, essayez de déconnecter et reconnecter ces deux nappes, puis vérifiez qu'elles sont bien enclenchées.
    To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
    Remplacement des bandes adhésives fixant l'écran d'un iPhone
    MAKE SURE you hold the top screen when dislodging the cable connections. I let the screen lie flat down and ended up tearing one of the cable connections, now my touch ID does not work at all! I’m going to have to order a whole new screen.
    Arjun Nagarajan - Réponse
    Don’t miss that SECOND CONNECTOR like I did. It will break very easily if not disconnected :(
    garrett peek - Réponse
    An earlier comment said to re-apply the suction cup to the right side of the display so that it acts as a stand when the phone is partially opened. That’s a great idea, and helps a lot for this step and the next.
    Mark - Réponse
    Hey – I broke one of these flex cables and I cant find them to purchase anywhere. Can somebody help me? It’s the LCD connector first and what is the second flex cable for? Thanks!
    Chan Ty - Réponse
    I broke the second (smaller) display connector flex cable.
    1) Is it replaceable or repairable?
    2) Where can I get the replacement?
    Ben Blom - Réponse
    Same happened to me. What solution did you find? Could you replace a part to make it work? Thank you!
    Viktoria -
    I replaced the screen and have ended up with a blank screen. Touch control seem to work (touch button works and I can shut down the phone by pressing power button for some seconds and then swipe left to right in the upper part of the screen). But the screen is blank. I’ve tried to disconnect and connect the two connectors in step 16 but with the same result (blank screen). What do I need to do?
    Thanks for advice!
    Bjorn - Réponse
    this point is the most important in the whole manual.
    Please pay attention not to strain the flex cables or they will end up breaking
    Jose Joaquín Sanz Iniesta - Réponse
    I should have been more careful - the second cable tore off.
    My own fault after having done this replacement about four times previously without any issues, I clearly got cocky and didn’t pay enough attention.
    Be VERY CAREFUL and remember to unplug those cables. Don’t skip steps.
    I’ve now had to order a replacement screen.
    Stuart - Réponse
    Echo minimalist’s comment here. Prop the display up and skip to step 19 to save time and remove risk.
    .A. - Réponse
    If you replace the screen and there is no display apply io propyl alcohol 99.9 & purse to both connectors on the screen and on the iPhone with a clean toothbrush and let them dry for 45 minutes and then fit the screen and reassemble the iPhone..
    It works for me . when I get a new screen I do t5his before fitting it.
    I tried to save time by not removing the screen during battery replacement as some comment here, HOWEVER, I ended up having to use a little force to remove the battery and in the process broke the second, lower smaller cable, resulting in loss of home button function and needing to get a new screen. Next time I will follow these steps and completely remove the screen during a battery replacement
    chrislacey - Réponse
    I removed the screen and cable still got ripped during reassembling :(
    Viktoria -
    There is a critical fact missing from the steps here, for reassembly: That bottom (underlying) cable is longer than it should be. Loads of people are reporting that the Home button is dead after this repair, but the cables aren't torn. I'm pretty sure this is why. Here is a picture of the problem.
    When reassembling the phone, you must poke this cable back into the body of the phone while you bring the halves together, or you will crush, crimp, and destroy the cable.
    Gavin Stokes - Réponse
    I’m only reading your very useful comment now, after the exact thing happened to me and my cable got ripped during reassembling phone. Would you be able helping me naming this part, so I can look for a new one? Thank you very much!
    Viktoria -
    thanks gavin. ifixit should have included this piece of info.
    soupamanx -
    Can somebody help me with the name of the part that these cables belong to? The bottom one got ripped during my battery replacement, I need a new one but unsure what to look for.
    Viktoria - Réponse
  16. Remplacement de la carte mère de l'iPhone 7: étape 16, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 16, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 16, image 3 de 3
    • Retirez les deux vis cruciformes #000 de 1,3 mm fixant le support sur le connecteur de l'ensemble capteur du panneau avant.
    • Certains téléphones peuvent avoir des vis Y000. Apple a commencé à les utiliser au milieu du cycle de vie du produit.
    Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
    It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
    Makana Sylva - Réponse
    If you’re having trouble removing these screws;
    the screw on the right goes into a standoff screw that is screwed into the frame.The left one goes into the logicboard.
    If your phone is used most likely it has been repaired in the past and the person that repaired it put the screws in way too tight.
    If your phone is brand new And you know 100% it is then the problem is your screwdriver.Stop before you strip it completely and buy a better screwdriver (EBAY).
    If you already stripped the screw head take the phone to a shop before you break it.
    there are ways to get them out but truthfully it’s extremely dangerous and sometimes your better off quitting while you are ahead.
    Vegeta Barrett -
    The right screw kept spinning, tried different levels of force but didn’t work. I left the screw on and bent the shield to get to the cable.
    s h - Réponse
    I used a #1 flat head tip to loosen.
    Peter Pearson - Réponse
    I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
    Use the PH000 and apply a little more force before spinning, should come right out!
    Sierra Scolaro - Réponse
    ^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
    Jeff Suovanen -
    the two screw i have are stripped and i have n way of getting either screws off whats my next bet
    Alexis Marie Colon - Réponse
    The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
    Ryan Welborn - Réponse
    Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
    Jeff Suovanen -
    I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
    rcarswell - Réponse
    Use the J00 bit. Worked perfectly
    efazio588 - Réponse
    PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
    I’d do this step before removing the ribbon cables by the battery connector. That way you can disconnect all of them at the same time.
    Ray Bieze - Réponse
    i used the little +-shape 30 mm screwdriver (not the Y…but the + shape).
    mason - Réponse
    the cable tore. is that it i need a new phone?
    patricia loving - Réponse
    You don’t need a new phone, but your selfie camera and phone speaker will not work. You can get replacements for that about $10.
    jack jones - Réponse
    Reconnecting this cable and coverplate took a good 20 minutes. O_O
    Nicole Crome - Réponse
    What can I do to remove the screw (I stripped it)
    Alex Vu - Réponse
    I also had issues to loosen up the screws, in two parts the right side up and the left side down, i think the PH000 is to pointy or something or its too hard for the srews of the iphone, i cannot take it off and know im regreting i bought i order all the way from Paraguay in south america and know so angry it doesnt work
    I skipped this step. Just be really careful not to pull on the screen.
    Takumi Arai - Réponse
    The guide says they changed these to the Y000 “at some point in the t middle of the product’s lifecycle”…
    That can’t be true, I have a *day one*, preordered iPhone 7, and mine had, unmistakably, Y000 screws!
    and also, I’m just faithfully following the guide here, but can anyone clarify *why* is is necessary to entirely remove the display AND the Taptic Engine at all? The battery seems accessible just fine… oh well
    PS- I’m doing this on an older backup iPhone 7. My iPhone 12 Pro just went berserk and stopped working completely a little over a year after I got it day one of its release… since the iPhone X I’ve only had easily breakable, overly sensitive phones. I’ve had every numbered iPhone except for the 8 (I got the X released at the same date) and the 11, and man, are these newer iPhones post X fragile!
    Cam F - Réponse
    This worked for me! As mentioned use PH000 and apply pressure and then unscrew the screws. They are tiny, adhere to a piece of tape so you don't lose them.
    Rosie J - Réponse
  17. Remplacement de la carte mère de l'iPhone 7: étape 17, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 17, image 2 de 2
    • Débranchez le connecteur de l'ensemble capteur du panneau avant, de sa prise sur la carte mère.
    • Ce connecteur à pression devrait également être reconnecté une extrémité à la fois pour minimiser le risque de flexion.
    Das ist sehr mutig, das Kabel dort so zu strapazieren.
    Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
    Detlef Menninger - Réponse
    Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
    Victor Bui - Réponse
    @victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
    Jeff Suovanen -
    This is the only connector that is quite easily possible to put back in the wrong way. If you do so, the phone will just get into a continuous loop where it shows the boot screen, goes blank and then shows the boot screen again and again. If this happens, do not despair-just put it back in the right way.
    Roy Mathew - Réponse
    After putting together, I had a continuous loop boot up (as noted above). I saw articles where this (front panel sensor connection) was the reason. I disconnected this connection and the boot up loop stopped. I tried reconnecting several times but had the same problem (boot up loop). However, it turns out that I needed to apply extra pressure when installing until a heard a (faint) second click when pressing down. Note - before I was using the spudger to press the connection together, which didn’t do the job. I ended up using my finger to press harder to get it to click in. Solved that issue.
    The ribbon cable on this step is torn. Is this something that can be replaced? Is this only to the earpiece?
    John Daily - Réponse
    Sarah Valencia - Réponse
  18. Remplacement de la carte mère de l'iPhone 7: étape 18, image 1 de 1
    When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
    Guy Cooley - Réponse
    Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
    @victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
    Jeff Suovanen -
    This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
    trent bost - Réponse
    @trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
    Jeff Suovanen -
    If the instructions are followed step by step, then adding the adhesive comes before changing the battery.
    If I had to do it all over again, I'd skip adding the adhesive, because you have to disconnect the battery, plus the two lower display connecters and the front panel sensor assembly connector. It was a nightmare trying to marry the components back together without disturbing the wire prongs, and I don't even want to talk about reinserting the tiny screws that kept twirling around on the tip of the screwdriver as well. It wasn't worth the time or aggravation!!
    If you decide to skip this step, just avoid using your iPhone near water.
    Rosie J - Réponse
  19. Remplacement de la carte mère de l'iPhone 7, Carte SIM: étape 19, image 1 de 3 Remplacement de la carte mère de l'iPhone 7, Carte SIM: étape 19, image 2 de 3 Remplacement de la carte mère de l'iPhone 7, Carte SIM: étape 19, image 3 de 3
    • Insérez un outil éjecteur de carte SIM ou un trombone dans le petit trou dans le tiroir de la carte SIM.
    • Appuyez dessus pour éjecter le tiroir.
    • Cela peut nécessiter de forcer un peu. Cependant, assurez vous que l'outil éjecteur est correctement aligné au préalable afin de ne pas endommager le mécanisme d'éjection à l'intérieur du smartphone.
    • Retirez l'ensemble du tiroir de la carte SIM de l'iPhone.
    • Lors de la réinsertion de la carte SIM, assurez-vous qu'elle est bien orientée par rapport au tiroir.
    Received a sim card tray from IFIXIT for my iphone 7. I can’t seem to get it to close flush no matter how hard I try. Any suggestions?
    AJ Dereume - Réponse
    Why would it require a significant amount of force? Is it because the iPhone 7 is water resistant? When I removed my tray it was like it was stuck in goop inside the phone and the tray had a glue like sticky substance on it? It did not ‘click’ back in smoothly like my other iPhones, I had to push it against the ‘goop’. Is this normal for iPhone 7??
    Rebecca Diakun - Réponse
    I used the tip of the super pointy tweezers, and it worked well.
    Cynthia Lamb - Réponse
  20. Remplacement de la carte mère de l'iPhone 7, Connecteurs de la carte mère: étape 20, image 1 de 2 Remplacement de la carte mère de l'iPhone 7, Connecteurs de la carte mère: étape 20, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour débrancher le connecteur de la caméra arrière.
  21. Remplacement de la carte mère de l'iPhone 7: étape 21, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 21, image 2 de 2
    • Retirez les vis cruciformes suivantes fixant le cache de la caméra arrière à la coque arrière :
    • Une vis de 1,3 mm
    • Une vis de 2,5 mm
    I couldn’t get my 1.3mm screw out. It’s not required thankfully as you can just bend the cover up and out of the way to complete the rest of the steps.
    Ray Bieze - Réponse
    i removed them with PH000
    Flavien - Réponse
  22. Remplacement de la carte mère de l'iPhone 7: étape 22, image 1 de 1
    • Retirez le support.
  23. Remplacement de la carte mère de l'iPhone 7: étape 23, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 23, image 2 de 2
    • Utilisez l'extrémité pointue d'un spudger pour soulever et déconnecter le connecteur de l'antenne, juste à gauche du module de la caméra arrière.
    There is one Step missing before removing the flash light cable: Remove Camera cable, right?
    Achim Breidenbach - Réponse
    I broke this and can’t find it on amazon. Is it part of the volume control flash connector? If not, can you send me a link on where to find this connector,…and possible instructions on how to replace?
    Daniel Buhler - Réponse
  24. Remplacement de la carte mère de l'iPhone 7: étape 24, image 1 de 1
    • Retirez les deux vis tri-point de 1,2 mm fixant le cache de la nappe supérieure.
    these are too tight cant get rid off them from y000
    Narendra Mane - Réponse
    ok with Y000 from pro tool kit
    Flavien - Réponse
    Had to push down to get the Y000 in place
  25. Remplacement de la carte mère de l'iPhone 7: étape 25, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 25, image 2 de 2
    • Retirez le cache de la nappe supérieure.
  26. Remplacement de la carte mère de l'iPhone 7: étape 26, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 26, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour débrancher le connecteur de la nappe supérieure.
    Este cable q funciona tiene porfavor lo desconecte y funciona normal
    Johnny Bolaños - Réponse
  27. Remplacement de la carte mère de l'iPhone 7: étape 27, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 27, image 2 de 2
    • Retirez les quatre vis cruciformes fixant l'antenne Wi-Fi :
    • Une vis de 1,7 mm
    I lost one of these 1.2 mm screws. Will that affect the signal reception?
    Bethany Knaebel - Réponse
    There is another screw connecting the antenna to the case.
    tbaiello - Réponse
    How do you open the 1.7mm screw? LOL
    Kyle Victor - Réponse
    The screws are not threading in for some reason. I measured the screws to be exactly 1.2mm with a caliper.
    Loopy75 - Réponse
    Yes there are 4 x screw 3 x 1.2mm and 1x 1.7mm securing the antenna to the case
    ANDREW - Réponse
    Yes : 4 screws and not 3 !!
    sirthomasnardin -
  28. Remplacement de la carte mère de l'iPhone 7: étape 28, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 28, image 2 de 2
    • Retirez l'antenne supérieure gauche.
    ** also remove the small Phillips screw fastening the WiFi antenna to the top rear casing of the phone
    iBroke - Réponse
  29. Remplacement de la carte mère de l'iPhone 7: étape 29, image 1 de 1
    • Enlevez les vis cruciformes suivantes :
    • Une vis de 1,3 mm
    • Une vis de 2,2 mm
    Möglicherweise muss man den Kleber zuerst entfernen!
    Evan Winter - Réponse
  30. Remplacement de la carte mère de l'iPhone 7: étape 30, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 30, image 2 de 2
    What's this bracket called
    Cris Velasquez - Réponse
    %#*@, lost that part during the job, thought it’d be alright without it. Couple days later figured out NFC doesn’t work anymore. Any ideas on where to get this part from, colleagues?
    azowux - Réponse
  31. Remplacement de la carte mère de l'iPhone 7: étape 31, image 1 de 1
    Standoff Screwdriver for iPhones
    $5.49
    J'achète
    • Retirez la vis d'entretoise de 2,2 mm du support de mise à la terre.
    • Le mieux est de dévisser les vis d'entretoise à l'aide d'un tournevis pour vis d'entretoise ou d'un embout pour vis d'entretoise.
    • Un petit tournevis plat peut aussi faire l'affaire, mais veillez à ce qu'il ne glisse pas et n'endommage pas les composants qui se trouvent autour.
    What bit is this? The link doesn’t use the same name.
    Mike Moran - Réponse
    I didn’t even have an eyeglass repair kit flathead, so I hit the end of a paperclip with a hammer to make a flathead, and it works!
    Ark - Réponse
    I hate getting the deep into a repair to find there’s a tool missing. This bit should be part of the toolkit!
    Ark - Réponse
    Its in the toolkit now. Looks like a Philips head but up close the end is squared off with a point in the middle.
    Jesse de Vries -
    I received two boxes - one box contained the repair part, the other was the tool kit. I only opened the tool kit before disassembling the phone. The standoff screwdriver bit was not in there. Neither was the guitar pick. I used a real guitar pick and a small standard screwdriver from my toolbox. When I was ready to reassemble, I opened the repair part box and guess what was in there - the standoff screwdriver bit and guitar pick. So, I guess if you just order the part it will come with (at least) those two tools. The tool kit contains tweezers, suction cup, three screwdriver bits (tri-point, pentalobe, and phillips) and screwdriver handle, a long black spudger with a flat end and a pointy end, and a smaller, thicker spudger with a wide, flat ends.
    bronyaur - Réponse
    The flat end of the spudger works a treat too.
    Robert Trammel - Réponse
    Thank you, bronyar. Since there is a box labeled “Repair Tools”, I never would have looked in the parts box for tools. I was able to use the standoff tool to takie the phone apart, not just to put it back together.
    Mike Ruzicka - Réponse
    I used standoff bit for iPhone from my pro tool kit
    Flavien - Réponse
  32. Remplacement de la carte mère de l'iPhone 7: étape 32, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 32, image 2 de 2
    • Utilisez une pincette pour replier délicatement de côté le support de mise à la terre de la carte mère.
    I accidentally broke the grounding bracket, is it very important to get a new one to replace? as I can't seem to find them for sale anywhere
    Mustifa shah - Réponse
    I also broke it. Did your phone work after?
    Did you find a replacement?
    Ben Schorr - Réponse
    Did your phone work ?
    Emin -
    also broken does it work without?
    Emin - Réponse
    I broke mine while doing this step. A bit confusing. You’re just supposed to bend it out the way, not pull on it entirely. Will the phone still work without this?
    Chandler Forrest - Réponse
    $@$*, i broke the grounding bracket
    Z1xus - Réponse
    I just didnt bend this one.. Ill tell you how it went
    Lauren Campbell - Réponse
  33. Remplacement de la carte mère de l'iPhone 7, Carte mère: étape 33, image 1 de 3 Remplacement de la carte mère de l'iPhone 7, Carte mère: étape 33, image 2 de 3 Remplacement de la carte mère de l'iPhone 7, Carte mère: étape 33, image 3 de 3
    • Utilisez la pointe d'un spudger pour soulever les deux connecteurs de câble d'antenne hors de leur prise sur la carte mère.
  34. Remplacement de la carte mère de l'iPhone 7: étape 34, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 34, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 34, image 3 de 3
    • Utilisez une pincette pour dégager délicatement les câbles d'antenne du support métallique sur la carte mère.
  35. Remplacement de la carte mère de l'iPhone 7: étape 35, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 35, image 2 de 2
    • Utilisez la pointe d'un spudger pour débrancher le connecteur de la nappe inférieure.
    Wat voor kabel is dit? Deze is beschadigd bij mijn IPhone 8 Plus
    Maarten - Réponse
  36. Remplacement de la carte mère de l'iPhone 7: étape 36, image 1 de 1
    $5.49
    J'achète
    • Retirez les vis suivantes :
    • Une vis cruciforme de 1,4 mm
    • Trois vis d'entretoise de 2,2 mm
    • Les vis d'entretoise sont plus faciles à retirer avec un tournevis pour entretoise (standoff).
    Link may be missing or broken!
    Standoff screws are best removed using an [linked product missing or disabled: IF145-343-1] and driver handle.
    Phrase Neither - Réponse
  37. Remplacement de la carte mère de l'iPhone 7: étape 37, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 37, image 2 de 2
    • Utilisez la pointe d'un spudger pour déplacer l'éjecteur de la carte SIM hors de la carte mère.
  38. Remplacement de la carte mère de l'iPhone 7: étape 38, image 1 de 2 Remplacement de la carte mère de l'iPhone 7: étape 38, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour soulever délicatement la carte mère du côté du connecteur de la batterie.
    • Assurez-vous de ne tirer sur aucune nappe. Si vous ressentez de la résistance, vérifiez que ni les nappes, ni les connecteurs, ni les composants ne sont en contact avec la carte mère.
  39. Remplacement de la carte mère de l'iPhone 7: étape 39, image 1 de 3 Remplacement de la carte mère de l'iPhone 7: étape 39, image 2 de 3 Remplacement de la carte mère de l'iPhone 7: étape 39, image 3 de 3
    • Soulevez la carte mère du côté du connecteur de la batterie, tirez-la et sortez-la de la coque arrière.
    • Veillez à ce que la carte mère ne reste accrochée à aucune nappe.
    Très bien pour ces étapes
    Théophile Bita - Réponse
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
158 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Evan Noronha
Membre depuis le 02/05/15
223 466 Réputation
168 tutoriels rédigés
13 commentaires
I had an accident where my iphone has got some damage (cracked screen, metal frame slightly bent).. I can see a lot of iCloud locked devices for sale, some of them for a cheap price. Would replacing the logic board and home button give me a non-damaged working phone? Or what parts would need to be moved for this? Sure I can buy a brand new phone but I like a bit of a challenge :)
Steve - Réponse
the logic board holds the OS, so yes if you were to replace the mother board of the iPhone it should work like a new phone but without touch id
Vegas Uprising -
I have the same idea and i found to buy this one
https://www.aliexpress.com/item/For-iPho...
You think it will work?
alexandros papadopoulos -
Hi,
I’ve got a problem with my iphone7. I just took some videos under the water using my iphone. But later it’s finger id has gone and it’s fully damaged. Now the phone is not working. Is there any option to repair this ….?
muhammed faisal - Réponse
Hi Muhammed, sounds like some water got inside your phone. Check out our iPhone liquid damage guide for some basic troubleshooting you can do on your own. When you have the phone open check connectors and pins on the board for any corrosion. If the damage is serious enough that cleaning won’t fix it, you can take your phone to a local repair shop for more extensive repairs.
Adam O'Camb -
Will the board in my iPhone 6 work in an iPhone 7 I have?
Neal Payne - Réponse
Hello people my i phone 7 working only with headset. How can i solved? or what can i do?.
when i calling, on the screen not appears the speaker logo. Can you me help please.
Avedis
avi avi -
Hi. I want to buy a new logic board for iPhone 7 plus without touch id. I already have the home button with my screen attached. My question is if that home button works? I don’t need touch id i just want that the home button physically works. Does it work.
Faizan TAhir - Réponse
Nope, sorry—a non-paired button won’t work at all last time I checked. It worked until the 6s, but iPhone 7 and later have a solid-state “button” that gets disabled completely.
Jeff Suovanen -
Ottima guida molto chiara, ho sostituito la sceda madre ad un iphone 7 senza alcuna difficoltà.
labruzzopaolo - Réponse
I have recently lost all service in my iPhone 7. In the top left corner of my screen it says ‘No service’ and I cannot use 4G, receive or send messages and call others. My WIFI and Bluetooth work perfectly fine so does this mean that if I replace my logic board it will fix ‘No service’ issue ?
Adrian Cacaj - Réponse
I have an iPhone7 A1778 purchased in Canada.
If the only logic boards available (above) are the AT&T and T-Mobile, which should I choose or does it not matter?
Alex Campbell - Réponse
Hello .
There are 4 strews on motherboard but one of them are a little bit taller . with hole it fit that taller screw , and it have an importance ?
Ive replace my motherboard with other but after it keep restarting , it apear the apple for few seconds then it restart again and it keep doing this action . Any tips for solvind that problem ?
muthafackaa - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 142
30 derniers jours : 796
Total : 272,254
