Aller au contenu principal
Remplacement de la carte mère du Google Pixel 3
Ce dont vous avez besoin
  1. Remplacement de la carte mère du Google Pixel 3, Ramollir l'adhésif de la coque arrière: étape 1, image 1 de 1
    Older devices may require 2 or more minutes with a very hot iOpener. Also note, the photo shows the opener on the FRONT of the phone. The heat needs to be applied to the back of the device!
    Rick Johnson - Réponse
    I just realized that I was trying to pry apart the front of my Pixel 3… and have separated the class from the display. ??‍♂️ Even though the rest of the directions show the back, it would be nice for the first picture to also show the back, just to be safe.
    JR Raith -
    Agreed, I’ve done exactly the same and completely broken my display. I probably should’ve paid more attention to the initial steps before diving in but the step could do with a new picture for sure.
    Daniel Fryer -
    Thanks for the comments! I’ll add a note in the step warning people to make sure to pry the back cover, not the screen.
    Arthur Shi -
    I prefer my favorite opening method with something like this. Dental floss. So thin it can slide in the gap. A little sawing to get it far enough past the edge to lift and get the first pick in.
    John Hoffstetter - Réponse
    I found another wonderful tool. I used something like medicine packaging which is aluminum foil with plastic. It’s thin and strong enough!
    Christie Lin - Réponse
    I also went for the hairdryer, dental floss, and then the provided picks and this worked. Not easy to get that initial seal broken but once that's done the rest is pretty easy.
    James - Réponse
    I needed 20 nerve wracking minutes with a hairdryer
    Amy schneider - Réponse
    My battery had bulged and opened the case for me!
    Warmed it up a bit with hairdryer
    Floss helped also.
    David Lincer - Réponse
    I found I wasn't able to get the edges hot enough. I ended up using my heat gun (for shrink tubing) instead.
    Kurt Nowak - Réponse
  2. Remplacement de la carte mère du Google Pixel 3, Créer un espace: étape 2, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Créer un espace: étape 2, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Créer un espace: étape 2, image 3 de 3
    • Posez une ventouse sur la partie inférieure de la coque arrière, que vous aurez chauffée.
    • Vérifiez que vous ne confondez pas le côté écran avec le côté coque arrière.
    • Si votre coque arrière est méchamment fissurée, recouvrez-la d'une couche de ruban adhésif d'emballage transparent pour que la ventouse puisse adhérer.
    • Tirez fermement et constamment sur la ventouse pour ouvrir un espace.
    • Vous devrez faire un certain effort selon l'âge de votre téléphone. Si vous avez du mal, faites chauffer plus et recommencez.
    • Insérez un médiator dans l'espace.
    • N'utilisez pas d'outil métallique pour faire levier, au risque de briser la coque arrière en verre. Si le panneau ne bouge pas, faites chauffer un peu plus, avec un sèche-cheveux ou un pistolet à air chaud.
    The initial opening/insert is the hardest part of this repair, and if you end up having to use a flat-head screwdriver (etc) to get the first gap opened, you’ll scratch the phone. But it works.
    William Kew - Réponse
    I don’t recommend using a screwdriver. I tried this and it shattered the glass in that area. I replaced the battery on my Pixel 1 recently and noted that heating the FRONT glass on that phone enough to get a gap for one of the pics takes a considerable amount of time AND patience. I was one of the few who didn’t break or otherwise damage the glass in that process. I would say the same rule applies here. Allow for significant time and patiences to heat the old adhesive enough to get a pick inside the cover.
    kevlion88 - Réponse
    Definitely, this opening/insert is the hardest part of the procedure. I was unable to open even a slight separation with a suction cup and even with tons of heat from a hair dryer. What worked really well, and what I would highly recommend to others who experience really strong adhesive, is to use a small X-acto knife with a #16 blade. Make sure it’s a #16 (find on Amazon) because it differs greatly in angle and rigidity from the usual #11 blade. The sharpness of the blade makes it really easy to find the crack and open a gap, where you can then insert a pick with no problem.
    Andris Vizulis - Réponse
    I used a typical razor blade (like Matt and Rick and Greg) pressing the whole of the blade against the edge (blade parallel and flush against the back cover). The razor slipped under enough that I could get a pick in. (No damage, but when I first tried the corner of the razor, a small cut was immediately evident. Only use the whole blade.) Then, I used blue picks exclusively.
    I'm very curious about the dental floss method. I'll try that if I need to get back inside.
    pandam3ch4 -
    I gave up with the iOpener and pick, I tried >5 times for over an hour… After heating with theiOpener, I used and X-acto knife instead and that worked like a charm, except it did leave a few scuff marks unfortunatly. I used a size 22 blade.
    Manny - Réponse
    I really wanted to level off the back of the phone when pulling on the suction cup in this step, but found it was actually pretty easy once I used the opening tool to push down on the edge of the bezel, at the crack, barely putting any force on the back of the phone at all (just to keep it steady).
    Eugene Creswick - Réponse
    I have about a 2 year old Pixel 3. iOpener didn’t work at all on this step, but once I broke out the hair dryer, I was able to get the phone hot enough to insert the pick (no screwdriver or xacto knife needed)
    sliverdragon37 - Réponse
    I’m having trouble with the iOpener too. It is frustrating because I practiced on a bricked iPhone earlier this week and it was effortless. My Pixel 3 is also about 2 years old. Out of curiosity, were you replacing the charging assembly because of the charging cables fitting too loosely on the phone or for some other reason?
    Edwin -
    I used a stanley knive to get started and then a combo of opener and plektrums.
    All went well till I used to much force on the camera corner and broke the back into lots of small pieces. Be careful on that corner, people.
    But the new camera does focus, so for a first attempt at fixing a phone I am happy.
    clas ebeling - Réponse
    I heated the bottom up with the Iopener and then used a rectangular razor blade and the suction cup to lift the bottom. Place the entire blade edge into the crack and push/pry while lifting with the suction cup. As soon as you have a gap start to open, have a second person insert a pick into the corner. It was actually really easy. I had given up after a couple of tries without a blade. My Pixel 3 is 2 years old.
    Jeremy Stewart - Réponse
    Agreed with many other comments here. My Pixel 3 is two years old and neither the iopener nor a blow dryer were capable of loosening it enough. I ended up using a VERY hot iopener for a couple of minutes, the suction cup, and then a wide-bladed razer blade (about 80% width of bottom edge to spread out the stress and prevent risk of fracturing the rear glass panel). Once adding the razer blade I was able to get the pick in and follow the rest of the instructions as written.
    Matt Johnson - Réponse
    I also had to follow this process but resorted to a heat gun on its lowest setting as I couldn’t get the iOpener hot enough (I was afraid of overheating and bursting it). Other how-to videos also show using a thin piece of plastic or metal to slide into the corner, saving substantial time.
    Rick Johnson -
    So I didn’t use a blade, but I did get my fingernail in before the plectrum haha. Happened by accident as I was trying to push down on the bezel to counter the suction cup force.
    I also heated the sides and corners as well as the bottom, which may have helped it budge.
    Dmitriy - Réponse
    Helped me to notice that the focus here is to lift in the center (like right over the USB C connector). Was able to get it with just the iOpener and pushing down on the rest of the phone with the pry tool. My phone is over 2 years old though and it took about 50 minutes of working / reheating / repeating
    Tim Noack - Réponse
    Destroyed the glass back trying to take it off. This is not an easy phone to take apart.
    Andrew Richie - Réponse
    It would be nice if there was a heads up that the rear of the phone is glass….. Phone piping hot glass shattered and splintered
    John Gates - Réponse
    Hi John!
    Good suggestion! I'll add that into the step.
    Arthur Shi -
    The Jimmy tool from the iFixit toolkit worked like a freakin’ charm. Took me 10 mins to open the phone and it came out unscathed.
    adrianpauly - Réponse
    I used dental floss to cut the adhesive and slide it open. Just wiggle it back and forth from the corners until you cut enough that you can switch to a pick. Helps to have a extra hand to hold the phone.
    Javier Sullivan - Réponse
    Brother, dental floss was an absolute godsend!!! After 4 hours with the IOpener and attempting to use a heat gun which I balked from out of fear I came across this comment. Teased it around a corner and was then able to saw away at the adhesive. A lot of patience but no heat or potentially damaging tools needed. Thanks!
    Elijah Wilcox -
    With the floss, I wasn't getting enough "sawing" motion as it just slipped through my fingers too easily (my phone is about 4-5 years old I think, I bought it used). So I tied a few knots around a pen (the kind with a gripper, so the floss won't slide off) and it was a lifesaver. After about 3 hours trying other ways, the floss/pen saw got it open enough to stick the picks in and eventually open it up!! Thank you to everyone who commented these tips!!
    Rachel DeGouff -
    I have a 2-3 year old phone. The “heating pad” and blue picks did not work. I tried for two hours. Two weeks later I tried again using a hair dryer on high heat and low fan, and a rectangular utility razor blade. Start at the bottom of the phone, heat, and insert the razor blade into the gap and use it to cut the adhesive back a little at a time. Do not insert it more than about a 1/4 to 3/8 of an inch. Once you start getting a separation, use the blue picks to hold it open. Go up both sides an inch or two on both sides at a time. Do not pry the back open more than an 1/8 of an inch or so until you get it separated all the way around. Be patient. Work slowly. This took about 30 minutes once I got the hang of it. Do NOT pull the cover away from the phone after you separate it all the way around!! Read the instructions several times. There is a cable to the finger print sensor attached to the cover!
    Re-read these entire set of instructions and ALL of the comments TWICE before you start.
    Greg B - Réponse
    I used and iOpener and the iFixit tool (the one with the metal spatula). Ended up inserting about 10 picks, but it worked.
    Kevin Dick - Réponse
    I couldn’t get the pick in so I tried the sharper pry tool. Got it in and slid it sideways towards the corner —- BLAM, the back shattered. Not a good home repair experience.
    Roy Feague - Réponse
    Similar experience with others, iOpener would not heat up the phone enough to separate the adhesive. Had to use a hair dryer to finally insert the blue pick. After sliding the pick past the corner, the back glass scattered… Time to get a new phone and give up on this battery replacement i guess.
    John Wu - Réponse
    On a 3 years old Pixel 3 phone, after unsuccessfully trying iOpener and the suction cup, I used a piece of dental floss, and it worked perfectly.
    To make the process easier - tie little loops on both ends of the floss, put a finger or a screwdriver through the loop to help pulling the floss. Pull it through to one side and then to another, continue until you’re 1/2 inch in. At this point it should be possible to insert a pick
    Sergey Kiselev - Réponse
    This was the hardest step. I could not get the pick in at all. I tried dental floss and it slid in no problem. I eventually stuck the very tip of a razor blade in which allowed me to slide in a pick. Also be very careful when sliding the picks around as my wife broke the back glass of her phone, try to keep pressure as even as possible without bending the glass much.
    Adam Simmons - Réponse
    I like the dental floss idea. I set edges of the phone-back and also the blunt metal tool on an electric cooktop on low heat, and the adhesive softened enough to be workable. SAFETY TIP: the tool and phone were hot to touch, I wore cotton gloves throughout this task.
    Student4Life - Réponse
    Can confirm, with a 4-year-old Pixel 3, it was not possible to get the back cover off with any amount of force, heat, and the blue picks. I managed to get started by using single-edge box cutter razor blades and a hair dryer on high--got in just a bit under the left corner, then added a second blade along the bottom edge, and a third near the right corner, and that gave me enough space to get a blue pick in and start replacing the razors with blue picks one by one, and then proceeded as per the instructions. Dental floss is a neat idea; I wish I'd tried that--the razors didn't do any damage, but I was worried about the possibility.
    Adiv Paradise - Réponse
    Agreed; a 4cm section of utility knife was required along with heat/alcohol/patience to break the initial seal.
    Managed to do it without cracking anything, but sweated through this step quite prolifically.
    Mike -
    3.5 year old phone. Just wanted to confirm that dental floss, combined with the iOpener, does the trick to get the first pick in.
    I was able to slide the floss under the bottom right corner if you are looking at the phone. I alternated between sawing with the floss and applying heat with the iOpener. Eventually I was able to get a pick in that corner and was able to remove the rest of the adhesive by applying heat with the iOpener and sawing with additional picks around the perimeter of the phone.
    Matt Dubois - Réponse
    My Pixel 3 is 4 years old. I tried using the iOpener heat pad for 2 minutes. Didn't work. Then I tried using a heat gun on low for about 30 seconds. Didn't work. Then I used the heat gun on high for about a minute, then the suction pulled it off. I used the picks to peel the rest off. I thought about using the floss which would have work well. I also though about letting the phone sit in the car when it's hot outside. The key is to be patient and try not to use something besides the plastic tools. If I can do it then anyone can. Heat guns are very cheap and a good tool to have.
    Alex Schultz - Réponse
    After unsuccessfully trying all prying tools including metal ones - I finally hit the motherlode with the most inane thing possible-a stiff plastic collarbone-it has a slight angle at one end that gives it the required amount of rigidity and prying power.
    Yes, a heat gun is an absolute must!
    Jatinder Singh - Réponse
    I've ordered the battery replacement kit, it will arrive next week. I keep my house cool in fall/winter, so I'm a bit concerned about how well I'll be able to heat the adhesive. I'm considering heating the whole phone in my convection oven's "warm" function. Its thermostat compares well with a meat thermometer, I might try my lab grade thermometer too.
    I see "The phone is designed to work best in ambient temperatures between 32° and 95° F (0° and 35° C), and should be stored between ambient temperatures of -4° and 113° F (-20° and 45° C)." 113° F seems pretty low, perhaps that's when the adhesive begins to soften appreciably. I was considering starting at 120F. (And trying "toast" if it defeats me.)
    Experience, suggestions, good luck wishes welcome.
    reg - Réponse
    Hi reg!
    The temperatures you listed are operating temperatures—once the Pixel exceeds those temperatures, it will shut down and show a heat warning symbol. Ideally, you want to heat just the adhesive perimeter. The back cover should be slightly too hot to the touch—aim for about 80°C.
    Arthur Shi -
    3.5 year old phone. Thank the gods you guys recommended floss. I broke 2 nails trying the picks. Unfortunately I used extra slippy floss so I couldn't even tie it into loops to help. Even with the floss I couldn't saw my way through or get a pick in so I ended up just adding more and more floss (and more and more hairdryer) until I could get the pick in. After that it was just careful muscle.
    Despite several frustrating tries across several days, I had zero success creating a molecule of seam gap to begin to remove back cover without breaking it! Suction cup ineffective (needs 3rd? hand to pull-and-insert pick); heated iOpener doesn't U-fold to cover perimeter (soon cools off in 63F room); hair dryer likewise too-brief heat; Exacto or utility knife blades useless. Dental floss no luck. But only! once I tried keeping the Px3 on my electric 1980s food warming tray (Lo heat ..hands resting on insulating hot pads ..it also! keeps iOpener hot) ..would dental floss fit into corners (No chance midpoint at charge port per foto); then blue pick. But! floss was too slippery to pull/grip strongly ..one must tie loops at each end, then use old-style 'peg' clothespins (or pen with clip) to roll-up floss length to enable pulling right at insertion point. With fingers/hands preoccupied manipulating floss, it was awkward to simultaneously tug suction cup upward effectively at all. Didn't break rear cover ;-)
    AdahS - Réponse
    I had no luck with just a suction cup and heat. Heat and a razor blade as others commented worked well; HOWEVER, while working the blue opening picks around the bottom I cracked the glass. The back glass is more delicate than I anticipated. :-( Be very careful/gentle with the back glass! If I attempt this with another glass-backed phone I will plan to work on an actively heated pad for this step.
    Jeff Selfa - Réponse
    The plastic opening pick was to thick to get into the (almost nonexisting) crack. I had to use a thin sharp metal knife, which scratched the paint a little bit but finally made the crack wide enough for the plastic pic to fit in and finish the job. Perhaps one thin metal pick would be helpfull in the kit for this first step.
    L. Hopmeier - Réponse
    As others have said, this step was by far the most difficult and time consuming. DO NOT RUSH THIS STEP THOUGH. Take it slow and do NOT bend the back glass to try and speed things up. Keep slicing your way though, patiently being aware of the fingerprint sensor cable. On my phone it required a lot of force and im not even sure the puller was able to make a gap.. I found that the plastic picks were too thick to get a crack started. I ended up using a piece of plastic from a clamshell plastic container to finally make it through the crack and through the adhesive. I tried the plastic backing of one of the adhesives but that wasn't rigid enough. Once though I made my way about half way through; and in haste I made the fatal mistake of bending the back glass to much and shattered it. Yes it is in fact made of glass! It will NOT BEND. I ended up getting a replacement back glass kit on Amazon for $16 which had a new sensor and the adhesive pre-installed which was very nice.
  3. Remplacement de la carte mère du Google Pixel 3, Information sur le lecteur d'empreintes digitales: étape 3, image 1 de 1
    • Lorsque vous insérez le médiator au-dessus du bouton de marche, veillez à ne pas l'enfoncer trop profondément, car cela endommagerait la nappe du lecteur d'empreintes digitales.
    While the text is accurate, I found this image to be misleading - it appears as if the finger print cable is attached to the right side (from a back-of-phone reference). Only upon close image inspection is it clear that the cable has already been disconnected from the connector that is positioned just inside and above the power button.
  4. Remplacement de la carte mère du Google Pixel 3, Trancher l'adhésif: étape 4, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Trancher l'adhésif: étape 4, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Trancher l'adhésif: étape 4, image 3 de 3
    • Tranchez l'adhésif le long du bord inférieur et autour du coin droit.
    • Laissez un médiator dans le bord inférieur pour éviter que l'adhésif colle de nouveau.
    The back cover is glass! I was sure it was some kind of nice plastic. It's probably obvious to a lot of people, and it's very obvious in hindsight, after shattering it. But I'm writing this in case anyone else is oblivious to the last decade of smartphone design. I got impatient and flexed it out as I cut the glue. Don't do that. Carefully work your way around and avoid applying any significany bending forces to the cover.
    Dharman Gersch - Réponse
    Yup, shattered the back of my phone while trying to follow these instructions. You can’t flex the back cover much at all or it is toast.
    Someone else had said to use floss to start the cutting I found this to be the most useful. After I heated the phone with a hairdryer I would cut some of the adhesive at the bottom corner after sawing away for a bit I was able to move it enough to fit one of these picks in then I slowly reheated around the edge as I slowly moved more picks and slowly cut away at the adhesive .
    Braden D - Réponse
    Didn't have guitar picks. I grabbed some plastic packaging from my recycle bin and cut it into a bunch of triangles to hold the gap open as I worked my way around.
    Leaving the pick in the bottom as described while using another to slide up for the next steps shattered the back cover - these instructions should be clear to only leave the pick in the bottom with as little inserted into the phone as possible as it does not take much flex at all to shatter. Also beware that there are no replacement back covers available from iFixit either :(
    Pixel3 Owner - Réponse
  5. Remplacement de la carte mère du Google Pixel 3: étape 5, image 1 de 3 Remplacement de la carte mère du Google Pixel 3: étape 5, image 2 de 3 Remplacement de la carte mère du Google Pixel 3: étape 5, image 3 de 3
    • Faites chauffer le bord droit avec un iOpener et continuez à couper l'adhésif avec un médiator.
    • L'adhésif peut être très poisseux. Déplacez le médiator en le faisant osciller comme une scie pour trancher plus facilement.
    What is the required temperature to soften the glue? Can I just use a small bag filled with boiling water or a heat gun.
    Wiley Sanders - Réponse
    The iOpener is a plastic bag filled with what appears to be water so probably, yes.
    Christopher St. John - Réponse
  6. Remplacement de la carte mère du Google Pixel 3: étape 6, image 1 de 3 Remplacement de la carte mère du Google Pixel 3: étape 6, image 2 de 3 Remplacement de la carte mère du Google Pixel 3: étape 6, image 3 de 3
    • Continuez à faire chauffer et à trancher l'adhésif du reste du téléphone. Laissez un médiator dans chaque bord pour empêcher l'adhésif de recoller.
    • Quand vous passez au-dessus du bouton de marche, n'insérez le médiator que de moitié pour ne pas abîmer la nappe du lecteur d'empreintes digitales.
  7. Remplacement de la carte mère du Google Pixel 3, Soulever le côté gauche de la coque arrière: étape 7, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Soulever le côté gauche de la coque arrière: étape 7, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Soulever le côté gauche de la coque arrière: étape 7, image 3 de 3
    • Une fois que l'adhésif a été tranché tout le long du périmètre du téléphone, soulevez soigneusement le côté gauche de la coque arrière.
    • N'essayez pas encore de retirer la coque arrière. La nappe du lecteur d'empreintes digitales la relie toujours au téléphone.
    • Faites pivoter la coque arrière autour de l'axe du bord droit et posez-la de façon à ne pas forcer sur la nappe du lecteur d'empreintes digitales.
    Yes, per Step 7 foto, lift rear cover to vertical only! along the left edge (camera, power/volume) ..while also keeping the opposite long edge down (almost touching wireless coil) ..as left/camera edge rises (and right/lower edge slides leftward), take care to keep lower/right edge no further rightward than midway across coil (foto) ..then gently rotate now-lower right edge leftward 'clockwise', lay it flat without straining cable. [When my rear cover eventually suddenly released from the perimeter adhesive while still pulling on it, the upward force almost yanked the cover off cable; got lucky]
    [this updates my minutes-ago post ..apparently one can't edit after 5min? ..or delete/replace with this?]
    AdahS - Réponse
    Where is the guide on re-attaching the back cover with new adhesive?
    iuooip - Réponse
  8. Remplacement de la carte mère du Google Pixel 3, Dévisser les vis: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Dévissez les deux vis cruciformes de 4,1 mm de long, qui fixent le cache du connecteur du lecteur d'empreintes digitales.
    • Tout au long de la réparation, gardez la trace de chaque vis et assurez-vous que chacune d'elles revienne à son emplacement d'origine.
    • Durant le réassemblage, veillez à ne pas trop visser ces vis, vous risqueriez d'endommager votre écran.
    A magnetic screwdriver tip helped here.
    Ciprian Chelba - Réponse
    If you purchase iFixit’s kit for this replacement, their included driver is magnetic. Helped immensely!
    Rick Johnson -
    after replacing my camera, my screen had a big green/white vertical stripe. I didn’t see the disclaimer about overtightening these screws. I think it may be related.
    Ethan Berry - Réponse
    KEEP TRACK OF THE SCREWS - sketch a scale diagram of the open, inside of the phone on a piece of paper and mark the position of each screw as you remove it - lay the screws on your diagram to keep track of which screw goes where - they are NOT the same size.
    Greg B - Réponse
  9. Remplacement de la carte mère du Google Pixel 3, Enlever le cache du connecteur du lecteur d'empreintes digitales: étape 9, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Enlever le cache du connecteur du lecteur d'empreintes digitales: étape 9, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Enlever le cache du connecteur du lecteur d'empreintes digitales: étape 9, image 3 de 3
    • Prenez la pointe d'une spatule pour sortir le cache du connecteur du lecteur d'empreintes digitales de sous la bobine NFC.
    • Enlevez le cache du connecteur du lecteur d'empreintes digitales.
    Re-inserting this is tricky and requires pretty good dexterity. The shiny metal frame of the wireless charger is also not held down, so you may wish to gently apply pressure to it as you try to re-position the connector bracket.
    I could use a whole tutorial on how to reinstall this
  10. Remplacement de la carte mère du Google Pixel 3, Déconnecter le connecteur du lecteur d'empreintes digitales: étape 10, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnecter le connecteur du lecteur d'empreintes digitales: étape 10, image 2 de 2
    • Prenez la pointe d'une spatule pour soulever et débrancher le connecteur du lecteur d'empreintes digitales de sa prise.
    • Faites attention à ne pas détacher les petits composants montés en surface autour de la prise des connecteurs de cette sorte.
    • Pour rebrancher un connecteur à pression comme celui-ci, alignez-le soigneusement et appuyez d'un côté jusqu'à ce qu'il s'emboîte, puis recommencez de l'autre côté. N'appuyez pas au milieu. Si le connecteur n'est pas aligné correctement, les broches risquent de se déformer et de causer des dégâts irréversibles.
  11. Remplacement de la carte mère du Google Pixel 3, Enlever la coque arrière: étape 11, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Enlever la coque arrière: étape 11, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Enlever la coque arrière: étape 11, image 3 de 3
    • Enlevez la coque arrière.
    • Avant de monter une coque arrière de rechange, assurez-vous de retirer tous les résidus d'adhésif du châssis du téléphone. Prenez un outil d'ouverture pour gratter et de l'alcool isopropylique à haute concentration pour nettoyer la surface.
    • Si vous réutilisez la coque arrière, assurez-vous de nettoyer tout l'adhésif et posez une nouvelle couche d'adhésif.
    • Si vous installez une coque arrière de remplacement, soyez sûr de la comparer avec la pièce originale. Transférez toutes les pièces restantes (comme le diffuseur de flash) à votre pièce de remplacement.
    • Suivez ce tutoriel pour appliquer le nouvel adhésif sur la coque arrière.
    When reassembling is it better to first attach the new adhesive back gasket to the phone back or the phone chassis frame?
    Tom Burke - Réponse
    Hi Tom!
    It depends on the adhesive. Carefully align the adhesive to the phone by matching the contours. Note which adhesive side is backed by a clear liner, and which side is backed by a colored liner. The clear liner should be removed first. Whichever component the exposed adhesive faces should be the first surface to apply to.
    Hope that helps!
    Arthur Shi -
    Two things:
    1) I recommend attaching the adhesive to the Phone frame and not the back panel. As you attach, you can more easily see the gaps and guide the adhesive along the groove, leaving equal space all around.
    2) To transfer the fingerprint sensor, you will need double-sticky tape to make a new gasket. Put the tape on the back from the inside, and trim with a blade to make the sensor hole. To attach the sensor, place it on something small to raise it off your working surface, then lower the back over it. You’ll be able to see the sensor alignment as you lower the back, which helps get a good position.
    Gary Beardsley - Réponse
    Oh, and be prepared: Removing the old adhesive is teeeeedious!! It will take you some time. :-b Alcohol is not a strong solvent, so don’t expect it to remove much; it is mostly for cleaning afterward. In the end, I used one of iFixit’s flat metal tools from the big toolkit to remove the final remains. Its was blunt enough to not cut metal shavings as I cleaned.
    I used “medicinal” 91% Isopropyl Alcohol and about 30 Qtips to do the final cleaning of the adhesive, that is, after using a razor blade and the supplied tweezers to remove most of the tape. Patience and many Qtips soaked in IPA removed most of the remaining glue and film.
    Greg B -
    I ended up reusing the original adhesive as it was in pretty good shape. So far, no problems.
    Dan Comiskey - Réponse
    Does your IF356-119-1, Google Pixel 3 Rear Cover Adhesive, template use 2 sided pressure sensitive tape? Do I simply align it on the back cover and then press it to the device to reassemble the unit? If so, how long til the back cover is “glued” to the unit?
    Martin Seffens - Réponse
    Hi Martin,
    The rear cover adhesive is indeed two-sided PSA (pressure sensitive adhesive). Apply firm even pressure for a minute to bond the adhesive to the unit.
    Arthur Shi -
    When scraping the adhesive off the back cover be careful and don’t apply too much pressure (and/or position the cover against the surface so that it’s supported against the tool used), especially in the corners, or the glass cover rounded edges could break.
    Bart Oleksiak - Réponse
    Agree. BEWARE of SCRATCHING off the PAINT from the BACK COVER when cleaning !
    The back cover is painted glass it seems - using a razor blade to scrape off adhesive also scratches off the paint on the inside of the back cover, under the adhesive, and the clear lines it creates are visible from the outside of the back case. If you are using a phone case, this won’t matter.
    Greg B -
    My battery swelled and did all the hard work getting started popping the back open so I didn’t need the iOpener to get the back off, but now the iOpener is handy to heat up the sticky foamy factory original adhesive.
    I found isopropanol ineffective. I found heat softens it considerably. Just very warm, like hot water warm, is effective. Use tweezers or a plastic blade to help pull it off. Metal blades will either gouge the plastic or, worse, create metal shavings that will wreak havoc.
    Are there any solvents other than isopropanol that work and won’t harm the plastic? How do pros speed up this step?
    wsanders - Réponse
    I think pros often use heating pads or special jigs. They’d set the temperature, set the phone on the pad, and let the phone heat up for a few minutes. Heat guns are also a popular choice.
    Arthur Shi -
    I found that an opening pick worked well to scrape the glue off the inside of the curved edges of the back cover
    Richard Elder - Réponse
    The adhesive on mine took some effort to clean off all the way. During reassembly I did notice that my replacement back panel adhesive was larger than I expected and based off of product photos it looks like I received the 3 XL adhesive instead of the 3. That ended up having me fiddle with the adhesive to try and get it to fit right and unfortunately the camera side now has a bit of a gap that I can still press down on without having it stick. I’ll see how it stays but I fear I might have to get another adhesive. The guide was very helpful though!
    Craig Mileham - Réponse
    Does the replacement back come with all the sticky bits I need to replace it, including the fingerprint sensor, led and camers cover?
    wsanders - Réponse
    I decided not to bother with new adhesive. The seal doesn't seem great but I tend not to drop my phone in toilets as often as other people.
    James - Réponse
    The actual back glass cover part is missing from the parts list and it appears iFixit doesn't sell it anymore.
    It used to be there, and I ordered one months ago and used this guide successfully then. I broke it again and the part is no more.
    Elijah Lynn - Réponse
  12. Remplacement de la carte mère du Google Pixel 3, Dévisser la bobine sans fil: étape 12, image 1 de 1
    • Dévissez les cinq vis cruciformes qui fixent la bobine de charge sans fil :
    • Deux vis de 1,9 mm
    • Deux vis de 4,2 mm
    • Une vis de 4,3 mm
    The top 1.9 mm screw can’t be totally removed — it comes out with the coil once loosened
    Dmitriy - Réponse
    This was not true for me.
    Will Herrick -
    Can I leave the wireless charging coil out?
    This may also allow a bigger battery!
    Jex Webster - Réponse
    You may be able to! Note that this is not only the wireless charging coil, but also the NFC antenna (the upper loop).
    Arthur Shi -
    The 1.9 mm screws are actually screwed into the head of another screw beneath them. Sometimes the lower screw unscrews instead of the upper. That leaves both screws attached to the coil. If possible you should separate the two screws and screw the lower one back in first using a small flat blade screwdriver.
    If you decide to clean the wireless coil assembly, be aware that IPA will completely remove the printed 2-D barcode on the lower right. (Hopefully that's not important.)
    Bitt Faulk - Réponse
    There were 7 screws!!! The last two were both near the power button.
    Emily Viehland - Réponse
    Yes, I have that to, and a little black plastic part covering I port.
    ekan97Kingen (ekan) -
    l won’t mother board google pixel3 contact on WhatsApp +250783996430
    Nhimimana Glibert - Réponse
  13. Remplacement de la carte mère du Google Pixel 3, Retirer la bobine de charge: étape 13, image 1 de 1
    • Soulevez et retirer la bobine de charge sans fil.
    There seems to be a small amount of adhesive holding down the camera-side edge of the coil. Used a spudger to peel it off...and some of the black film on the back side of the coil was torn away.
    Jacob Dziubek - Réponse
    Had some adhesive tape holding down the camera side of the coil. Used the tweezers and the spudger to carefully peel it off.
    Also has some adhesive from the back cover edge that caught on the black film at the top of the phone (above NFC coil) - VERY carefully scraped it off with the point of the spudger while gently pulling the coil assembly away.
    Stuart Clark - Réponse
  14. Remplacement de la carte mère du Google Pixel 3, Déconnexion de la nappe de la batterie: étape 14, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnexion de la nappe de la batterie: étape 14, image 2 de 2
    • Prenez la pointe d'une spatule (spudger) pour soulever et débrancher le connecteur à emboîter de la batterie de sa prise sur la droite du téléphone.
    The connecton board is quete flexible … be careful otherwise other connectors may get looze.
    This is also valid when re-assemble … pusing battery conector may cause other conectors to “pop“.
    Tsanko Tsolov - Réponse
    The square connector directly below the battery connector came undone and will not pop back into place.
    Curtis Redfield - Réponse
  15. Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 15, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 15, image 2 de 2
    • Dévissez les deux vis qui fixent le cache de la caméra :
    • Une vis cruciforme de 4,1 mm
    • Une vis d'entretoise de 4 mm
    • Le mieux est de dévisser les vis d'entretoise à l'aide d'un embout pour vis d'entretoise. Un petit tournevis plat peut aussi faire l'affaire, mais veillez à ce qu'il ne glisse pas et n'endommage pas les composants qui se trouvent autour.
    • Ôtez le cache de la caméra.
  16. Remplacement de la carte mère du Google Pixel 3, Identifier les caméras: étape 16, image 1 de 1
    • Si vous remplacez les caméras frontales, sélectionnez celle que vous devez remplacer :
    • La caméra normale
    • La caméra grand angle
    • Si vous êtes en train de retirer la carte mère. vous devrez enlever les deux caméras.
    I actually didn't have to remove the cameras to get my motherboard out and back in, just pushed the connectors out of the way. It's probably less hassle prying them up as directed than wiggling the board back under two extra connectors when re-assembling as I did :)
    elyze - Réponse
    Make sure that the cameras each go in exactly the same spots or not the phone will boot loop forever. The connectors on both of these cameras are the same, so they will easily connect on both sides. So be careful.
    Let's Talk Tech - Réponse
  17. Remplacement de la carte mère du Google Pixel 3, Déconnecter la (les) caméra(s): étape 17, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Déconnecter la (les) caméra(s): étape 17, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Déconnecter la (les) caméra(s): étape 17, image 3 de 3
    • Servez-vous de la pointe d'une spatule (spudger) pour soulever et débrancher le connecteur de la caméra ou des caméras que vous remplacez.
  18. Remplacement de la carte mère du Google Pixel 3, Détacher la(les) caméra(s): étape 18, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Détacher la(les) caméra(s): étape 18, image 2 de 2
    • Les caméras sont collées en place.
    • Insérez la pointe de la spatule derrière le coin du module de la caméra et faites levier pour la détacher du châssis.
  19. Remplacement de la carte mère du Google Pixel 3, Retirer la(les) caméra(s): étape 19, image 1 de 1
    • Retirez la ou les caméras avec une pincette arrondie.
    • Si l'adhésif qui collait le module de la caméra est en bon état, vous pouvez le réutiliser. Remplacez-le sinon par du ruban adhésif double-face Tesa.
    • Si vous remplacez le module de la caméra, assurez-vous qu'il n'y a ni résidu d'adhésif ni saleté dans la lentille du châssis du téléphone.
  20. Remplacement de la carte mère du Google Pixel 3, Déconnecter le haut-parleur: étape 20, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnecter le haut-parleur: étape 20, image 2 de 2
    • Prenez la pointe d'une spatule pour soulever et débrancher le connecteur du haut-parleur de sa prise sur la carte mère, à droite du téléphone.
    • Faites attention à ne pas perforer la batterie avec la spatule.
  21. Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 21, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 21, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 21, image 3 de 3
    • Dévissez les quatre vis cruciformes suivantes :
    • Une vis de 1,9 mm
    • Une vis de 4,3 mm
    • Deux vis de 4,3 mm avec des tiges plus fines
    • Ôtez le petit clip de mise à la masse qui se trouve dans le trou de vis à gauche. Faites attention à ne pas le perdre.
    • Remontez le clip de façon que le profil soit orienté vers la gauche du téléphone.
    • Enlevez le petit insert en plastique à droite du port USB-C.
    • Assurez-vous de réinstaller cet insert avant de revisser la carte fille.
    The three 4.3 mm screws highlighted in Orange are not all the same. The one closest to the battery is slightly different, a larger diameter. It would be good to note this for reassembly.
    genec123 - Réponse
    Thank you! I will adjust the guide to reflect this!
    Arthur Shi -
    Ah, all great and everything but this should be in big bold red letters: “Be sure to reinstall this insert before you screw down the daughterboard.“
    Screwed 4.3 thin screw without that small insert and penetrated new screen module behind…
    Maks - Réponse
    Noted and changed!
    Arthur Shi -
  22. Remplacement de la carte mère du Google Pixel 3, Détacher le haut-parleur: étape 22, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Détacher le haut-parleur: étape 22, image 2 de 2
    • Le haut-parleur est fixé par un joint adhésif tenace. Avant d'essayer de l'enlever, il faut faire levier à plusieurs endroits pour faire céder le joint adhésif.
    • Insérez la pointe d'une spatule sous le coin inférieur droit du haut-parleur.
    • Faites levier pour détacher le haut-parleur du téléphone à cet endroit.
  23. Remplacement de la carte mère du Google Pixel 3: étape 23, image 1 de 2 Remplacement de la carte mère du Google Pixel 3: étape 23, image 2 de 2
    • Insérez la pointe de la spatule sous le coin supérieur gauche du haut-parleur.
    • Faites attention à ne pas percer la batterie avec la spatule.
    • Faites levier pour détacher le haut-parleur de ce côté.
  24. Remplacement de la carte mère du Google Pixel 3: étape 24, image 1 de 2 Remplacement de la carte mère du Google Pixel 3: étape 24, image 2 de 2
    • Insérez l'extrémité plate de la spatule sous le bord supérieur du haut-parleur, vers la gauche.
    • Faites levier pour détacher le haut-parleur.
  25. Remplacement de la carte mère du Google Pixel 3, Retirer le haut-parleur: étape 25, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Retirer le haut-parleur: étape 25, image 2 de 2
    • Enlevez le haut-parleur.
    • Vérifiez l'état du joint adhésif avant de monter un haut-parleur de remplacement.
    • S'il est en bon état, vous pouvez le réutiliser. Assurez-vous qu'il ne recouvre pas la sortie de son.
    • Si le joint est inutilisable, retirez-le et remplacez-le avec une bande prédécoupée de ruban adhésif.
    tesa tape seems hard to come by in my town. Is there anything else I could use?
    Michael Schlimmer - Réponse
    Never mind. A bunch of tesa tape came with the kit
    Adhesive is VERY strong. Used the Ifixit opening tool on the uppder edge between battery and speaker to get better leverage without risking cable / board underneath or the battery.
  26. Remplacement de la carte mère du Google Pixel 3, Déconnecter le câble d'antenne bleu: étape 26, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnecter le câble d'antenne bleu: étape 26, image 2 de 2
    • Soulevez le câble d'antenne bleu avec la pointe d'une spatule pour le débrancher de sa prise sur le module recharge.
  27. Remplacement de la carte mère du Google Pixel 3: étape 27, image 1 de 2 Remplacement de la carte mère du Google Pixel 3: étape 27, image 2 de 2
    • Gardez la pointe de la spatule pour soulever et dégager délicatement le câble bleu de ses clips de mise à la masse.
    • Le câble est fragile et se casse facilement. Si vous avez l'impression qu'il est coincé, ouvrez légèrement le clip avec la pointe de la spatule, puis réessayez.
  28. Remplacement de la carte mère du Google Pixel 3, Déconnecter le câble d'antenne noir: étape 28, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnecter le câble d'antenne noir: étape 28, image 2 de 2
    • Toujours avec la pointe de la spatule, soulevez et débranchez le câble d'antenne noir de sa prise à côté du port USB-C.
  29. Remplacement de la carte mère du Google Pixel 3, Dégager les câbles d'antenne: étape 29, image 1 de 1
    • Dégagez soigneusement les deux câbles d'antenne et enlevez-les du module recharge.
  30. Remplacement de la carte mère du Google Pixel 3: étape 30, image 1 de 3 Remplacement de la carte mère du Google Pixel 3: étape 30, image 2 de 3 Remplacement de la carte mère du Google Pixel 3: étape 30, image 3 de 3
    • Utilisez de nouveau la pointe de la spatule pour soulever et débrancher le connecteur du module recharge de sa prise sur la carte mère, à côté du bord droit du téléphone.
    • Détachez délicatement la nappe qui recouvre le lecteur de carte SIM.
  31. Remplacement de la carte mère du Google Pixel 3, Déconnecter le connecteur de l'écran: étape 31, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnecter le connecteur de l'écran: étape 31, image 2 de 2
    • Prenez l'extrémité plate d'une spatule pour soulever délicatement le ruban adhésif noir qui fixe la nappe de l'écran sur la droite du téléphone.
    • N'utilisez pas d'outils métalliques, vous pourriez endommager la nappe.
    • Utilisez le bout plat d'une spatule pour soulever et déconnecter le connecteur de l'écran de sa prise sur la carte mère.
  32. Remplacement de la carte mère du Google Pixel 3, Décoller le ruban adhésif noir de la batterie: étape 32, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Décoller le ruban adhésif noir de la batterie: étape 32, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Décoller le ruban adhésif noir de la batterie: étape 32, image 3 de 3
    • Faites attention à ne pas percer la batterie lorsque vous travaillez à côté avec une spatule.
    • Faites glisser la pointe d'une spatule dans l'interstice sous le ruban adhésif noir qui fait le pont entre la batterie et la carte mère.
    • Faites glisser la spatule le long de l'interstice pour soulever le ruban côté de la batterie.
    • Décollez soigneusement le ruban de la batterie et repliez-le pour qu'il ne gêne pas.
  33. Remplacement de la carte mère du Google Pixel 3, Déconnectez les connecteurs à emboîter: étape 33, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Déconnectez les connecteurs à emboîter: étape 33, image 2 de 2
    • Avec votre spatule, soulevez et débranchez les sept connecteurs à emboîter suivants de leur prise sur la carte mère :
    • Connecteur des boutons externes
    • Connecteur du microphone supérieur
    • Connecteur du haut-parleur interne
    • Connecteur du capteur de pression gauche
    • Connecteur de l'écran
    • Connecteur du capteur de pression droite
    • Connecteur du tiroir de carte SIM
    Note the "screen connector" mentioned here SHOULD refer to the smaller, upper screen connector. The one indicated here was already disconnected in step 31.
    Ray Livingston - Réponse
  34. Remplacement de la carte mère du Google Pixel 3, Déplacer la nappe du haut-parleur interne: étape 34, image 1 de 1
    • Soulevez puis repliez soigneusement la nappe du haut-parleur interne vers le haut, à l'aide de la partie plate de la spatule, pour l'écarter de la carte mère.
    I STRONGLY recommend simply REMOVING the phone speaker at this step. It is VERY easy to damage the flex cable when removing the motherboard if the speaker is left in place. Removing the speaker entirely takes only a few seconds. Just be sure to replace the adhesive when re-installing. TESA tape works fine here.
    When re-installing, make sure you remember this part when putting the motherboard back in. I followed the steps in reverse order, as suggested, and almost damaged the orange flex cable when I pushed it down.
  35. Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 35, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Retirer les vis: étape 35, image 2 de 2
    • Quelques-unes de ces vis sont munies de minuscules clips de mise à la masse. Faites attention à ne pas perdre ces clips en dévissant les vis.
    • Retirez les six vis qui retiennent la carte mère :
    • Une vis cruciforme de 4,2 mm
    • Trois vis cruciformes de 1,9 mm
    • Une vis cruciforme de 4,3 mm
    • Une vis d'entretoise de 3,83 mm
    • Enlevez les trois petits clips de mise à la masse et mettez-les de côté.
    During reassembly, don’t forget to replace the plastic piece before placing the 4.3mm screw.
    William DeCook - Réponse
    be careful not to forgetto remove the bottom screw not to damage your motherboard
    Paul - Réponse
  36. Remplacement de la carte mère du Google Pixel 3, Retirer le cache de l'antenne: étape 36, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Retirer le cache de l'antenne: étape 36, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Retirer le cache de l'antenne: étape 36, image 3 de 3
    • Ôtez soigneusement le cache de l'antenne du coin supérieur gauche du téléphone.
    • Pour réinstaller les petits clips métalliques de mise à la masse :
    • Posez-les, partie argentée en haut.
    • Orientez la pointe des clips en forme de goutte d'eau vers le bord du téléphone.
    • Mettez la moitié basse du clip à deux trous sur le trou de vis inférieur droit du châssis.
  37. Remplacement de la carte mère du Google Pixel 3, Vérifier la carte mère: étape 37, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Vérifier la carte mère: étape 37, image 2 de 2
    • Insérez la pointe d'une spatule à côté du coin supérieur gauche de la carte mère, juste en-dessous de la caméra arrière.
    • Faites doucement levier pour détacher la carte mère, en écartant toutes les nappes pour dégager le chemin.
    • Si la carte mère résiste, vérifiez que toutes les nappes et vis ont été détachées.
  38. Remplacement de la carte mère du Google Pixel 3, Détacher la carte mère: étape 38, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Détacher la carte mère: étape 38, image 2 de 2
    • Faites délicatement levier avec votre spatule sous le bord supérieur de la carte mère pour détacher cette dernière.
    • La nappe du haut-parleur interne se trouve contre la carte mère. Prenez votre temps et manœuvrez délicatement la carte mère autour de la nappe.
    Make sure the ambient sensor is disconnected right underneath the flash!
    jrancanoarias - Réponse
  39. Remplacement de la carte mère du Google Pixel 3, Commencer à retirer la carte mère: étape 39, image 1 de 2 Remplacement de la carte mère du Google Pixel 3, Commencer à retirer la carte mère: étape 39, image 2 de 2
    • Soulevez le bord gauche de la carte mère et faites-le soigneusement pivoter vers la droite. Écartez délicatement les connecteurs à pression qui risquent de rester accrochés à la carte mère.
  40. Remplacement de la carte mère du Google Pixel 3, Retirer la carte mère: étape 40, image 1 de 3 Remplacement de la carte mère du Google Pixel 3, Retirer la carte mère: étape 40, image 2 de 3 Remplacement de la carte mère du Google Pixel 3, Retirer la carte mère: étape 40, image 3 de 3
    • Soulevez délicatement la partie supérieure de la carte mère hors du châssis.
    • Ôtez la carte mère.
    • Au moment de réinstaller la carte mère, faites attention à ne coincer aucun connecteur de nappe en-dessous.
    • Il peut s'avérer difficile de repositionner la carte mère autour de la nappe du haut-parleur interne. Vous pouvez soulever doucement le haut-parleur interne, installer la carte mère et réinstaller le haut-parleur interne.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
Apportez vos déchets électroniques à un recycleur certifié R2 ou e-Stewards.
La réparation ne s’est pas déroulée comme prévu ? Consultez la section Google Pixel 3 de notre communauté de réponses pour obtenir de l’aide au diagnostic.
14 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Arthur Shi
Membre depuis le 01/03/18
249 876 Réputation
503 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 734 tutoriels rédigés
7 commentaires
Hallo,
wo bekomme ich denn ein neues Mainboard her? Ich komme nicht mehr ins recovery und vermute Mainboarddefekt.
Helge - Réponse
I followed your instructions to the letter. Got it all put back together, but before affixing the back glass, I powered up the Pixel 3 to make sure all features are working. The touch screen does not work, now, but it did before. Any advice?
Philip Wickstrom - Réponse
Hi Philip,
Does the screen light up? If it doesn’t, I would suggest disconnecting the battery connector and double-checking the display connector to make sure it is properly seated. As I looked into your question, I noticed that the step was missing a disconnection procedure—so thank you! I’ve amended that step.
Arthur Shi -
Hi, I met the same issue as you, the touch didn't work after replacing the mother board. Do you know why? And have you fixed the problem?
notreally -
Where can I buy the motherboard? Is the 128 GB motherboard different from the 64 GB?
Orlando Terte - Réponse
You can find the motherboards on ebay here https://www.ebay.com/sch/i.html?_nkw=goo...
Paul -
muy interesante todo, seria bueno compartieras donde comprar la placa madre de reemplazo que sea original, para no caer en estafas, en mi caso se me rompió el regulador de voltaje del LCD el PM8005 y no tengo idea de donde lo venden para comprarlo, solo me queda la opción de una placa nueva. Si fueras tan amable de compartir donde comprarla te lo agradecemos. Excelente trabajo por cierto.
Yunis Maikel Suárez Martinez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 44
30 derniers jours : 172
Total : 14,824
