Aller au contenu principal
IBM WorkPad c3 Motherboard Replacement
Ce dont vous avez besoin
  1. IBM WorkPad c3 Motherboard Replacement, Back Case: étape 1, image 1 de 2 IBM WorkPad c3 Motherboard Replacement, Back Case: étape 1, image 2 de 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. IBM WorkPad c3 Motherboard Replacement: étape 2, image 1 de 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. IBM WorkPad c3 Motherboard Replacement: étape 3, image 1 de 2 IBM WorkPad c3 Motherboard Replacement: étape 3, image 2 de 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  4. IBM WorkPad c3 Motherboard Replacement, Front Case: étape 4, image 1 de 2 IBM WorkPad c3 Motherboard Replacement, Front Case: étape 4, image 2 de 2
    • Turn the device over, so that the screen is laying on a flat surface.
  5. IBM WorkPad c3 Motherboard Replacement: étape 5, image 1 de 3 IBM WorkPad c3 Motherboard Replacement: étape 5, image 2 de 3 IBM WorkPad c3 Motherboard Replacement: étape 5, image 3 de 3
    • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
    • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
    • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
  6. IBM WorkPad c3 Motherboard Replacement: étape 6, image 1 de 2 IBM WorkPad c3 Motherboard Replacement: étape 6, image 2 de 2
    • The device will be extremely hot. Use a towel or oven mitt to grab it.
    • Using the Plastic Opening Tools, take the front of the case off.
    • If the case is difficult to remove, try repeating step 2.
    • The power button at the top of the device will be loose once the front part of the case is removed.
  7. IBM WorkPad c3 Motherboard Replacement, Battery: étape 7, image 1 de 1
    • Remove the yellow tape that is covering the battery connector
  8. IBM WorkPad c3 Motherboard Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, carefully disconnect the battery cable from the port
  9. IBM WorkPad c3 Motherboard Replacement: étape 9, image 1 de 2 IBM WorkPad c3 Motherboard Replacement: étape 9, image 2 de 2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
  10. IBM WorkPad c3 Motherboard Replacement, LCD: étape 10, image 1 de 2 IBM WorkPad c3 Motherboard Replacement, LCD: étape 10, image 2 de 2
    • Using the spudger lift the tabs holding the LCD/Digitizer combo cables to the WorkPad.
  11. IBM WorkPad c3 Motherboard Replacement: étape 11, image 1 de 2 IBM WorkPad c3 Motherboard Replacement: étape 11, image 2 de 2
    • Using your thumb, press down gently on the back of the LCD.
    • The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
  12. IBM WorkPad c3 Motherboard Replacement, Motherboard: étape 12, image 1 de 1
    • Using the plastic opening tool, lift the clip holding the motherboard cable.
  13. IBM WorkPad c3 Motherboard Replacement: étape 13, image 1 de 2 IBM WorkPad c3 Motherboard Replacement: étape 13, image 2 de 2
    • Gripping the motherboard as shown, lift up slightly and pull outward.
    • Small plastic tabs hold the motherboard down. Lifting too hard will break these off, and the motherboard will be loose upon replacement.
Emily Falkenstein
Membre depuis le 10/05/10
75 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 21-35, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 1,975
