Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Introduction
La carte mère abrite tous les circuits internes de la Nintendo 2DS, et la plus grande prudence doit être prise lors de son démontage. Assurez-vous de ne pas dénuder les vis, car cela pourrait être impossible à réparer.
Ce dont vous avez besoin
Retirez les 2 vis captives cruciformes qui fixent la coque arrière supérieure.
Retirez les dix vis cruciformes qui fixent le panneau arrière.
Can't take off the screw top left next to the battery. What type of screwdriver do I use and where can I find some?
I used a husky with changeable heads, you could probably find one on amazon
Retournez soigneusement le panneau arrière pour repérer la nappe qui y est connectée.
Retirez les deux vis cruciformes qui fixent la nappe au panneau arrière.
You can also detach the cable from the motherboard safely by flipping up the connector on the motherboard. Just don't forget to reattach. Some will find this tedious but may save time if you know what you're doing with said connectors.
I agree, this is what the guide i followed said to do and since I was disconnecting all the other ribbon cables it made perfect sense to do it that way.
Lin -
pay attention: my 2ds dropped it's lens covers at this step
Likewise, I used a tiny drop of glue to put the lens back in place. Take care not to dirty the lens.
The picture you have there has the camera lens ribbon installed upside down. The ribbon needs to be pointing down when you re-attach it not up.
Agreed, ribbon cable looks upside down in picture
Tenez les panneaux latéraux du boîtier de l'appareil avec vos doigts et tirez vers l'extérieur pour les retirer.
When reattaching during reassembly, take great care to ensure volume slider piece is correctly aligned with potentiometer tab on motherboard, otherwise volume control cannot be changed.
The are two small metal pins in the bottom corners of the case, take care not to misplace them.
The (3?) small ribbon cables on the bottom of the motherboard appear to already have been unplugged in this step. unplug them while unplugging the two large screen ribbon cables in step 10
What are the three ribbon cable at the bottom are supposed to be. Pls
Retirez les 12 vis cruciformes de couleur laiton fixant la carte principale.
I dont know if its just me but my gold mother board screws i had a few that just didnt fit right with a ph000. Maybe my screw driver is just garbage?
Il y a deux vis supplémentaires situées sur le rail supérieur. Retirez-les pour retirer complètement les boutons et le rail supérieur.
Il y a deux vis maintenant la base du joystick qui doivent être retirées. (Attention au câble plat, il reste connecté !)
Tenez le panneau supérieur avec vos doigts et retirez-le de l'appareil pour le retirer.
When reassembling, take care to ensure all buttons, and rubber button pads are located correctly BEFORE securing the motherboard.
Détachez les 2 nappes en soulevant les connecteurs flip noirs qui les maintiennent.
Soulevez la planche rectangulaire assise dans le visage et soulevez le carré blanc qui est le moteur du joystick (cela demande un peu d'effort). Les deux restent attachés à la carte mère.
Sur certains modèles, vous devrez retirer trois autres petits câbles plats au bas de l'écran. Ils sont sécurisés par des connecteurs rabattables. SOYEZ PRUDENT!
En tenant la carte mère de chaque côté, soulevez-la pour la retirer.
Don't forget to disconnect the two tiny ribbon cables on the bottom of the motherboard that attach to the microphone and home button.
What happens if I can't get the ribbons to reattach? Is the board broke irreparably?
What about the top 2 wires
Briana the 3 wires on bottom of board are covered under screen 2 step 10.
y e e t y e e t m y d u d e s ! ! ! ! ! ! ! ! ! !!n ! ! ! ! ! ! ! ! ! !
The motherboard of my 2017(I think) 2DS is definitely laid out differently than in this guide, be careful.
Cosa succede se i connettori dei 3 piccoli cavi piatti si dovessero rompere??
How do I flip up the two ribbons ( need help desperately)
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
31 autres ont terminé cette réparation.
Merci à ces traducteurs :
83%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
13 commentaires
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Fix what? You need to be more specific. I have to purchase a screen from China in order to fix mine.
I have a quarter inch metal pin left over. Don’t see it in any tutorials. Anyone know where it’s from?
I have the same thing, It came out when I was removing the back panel. I believe it was located towards the bottom of the panel. I’m scouring forums to see where it goes. Found this on Youtube! https://www.youtube.com/watch?v=qjoPIt5K... looks like it is just a reinforcement pin for a lanyard in the bottom corners.
Kwag -
where do i buy a motherboaRD
Depends on the country where you live. In Europe, some countries have apps (flesh market) where you will find used motherboards of Nintendo. (Wallapop, Vinted...)
For the rest of the world, you can try a l i e x p r e s s . c o m or similar.
