Introduction
Use this guide to replace the motherboard.
Ce dont vous avez besoin
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Use a plastic opening tool to pry the rear-facing camera connector from its socket.
268 autres ont terminé cette réparation.
40 commentaires
Between step 13 and 14, there should be a step to detach the cable to the camera lens and speaker assembly and the removal of the assembly.
The are usually $100 and Galaxy S III (Verizon) Motherboard
Where do i buy the original motherboard and what is the cost
I have a motherboard of samsung galaxy s3 sgh-t999 t mobile pm me here's my email tan.jeffrey84@yahoo.com for more info
Cheapest place to buy them is ebay.
