Aller au contenu principal
Remplacement de la carte mère du Super Nintendo
Ce dont vous avez besoin
  1. Remplacement de la carte mère du Super Nintendo, Boitier externe: étape 1, image 1 de 1
    • Retirez les six vis situées sous le système à l'aide du tournevis Gamebit 4,5 mm.
    In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
    Raucedine - Réponse
    There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
    phoenixknight8082 - Réponse
    I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
    Thanks in advance.
    Mike Watts - Réponse
    For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
    Austin Barnett - Réponse
    Could you further explain how to short the capacitor leads?
    Will Pulman -
  2. Remplacement de la carte mère du Super Nintendo: étape 2, image 1 de 3 Remplacement de la carte mère du Super Nintendo: étape 2, image 2 de 3 Remplacement de la carte mère du Super Nintendo: étape 2, image 3 de 3
    • Retournez soigneusement l'appareil.
    • Localisez la couture. Soulevez et séparez la moitié supérieure du boîtier de la moitié inférieure du boîtier.
  3. Remplacement de la carte mère du Super Nintendo, Interrupteur: étape 3, image 1 de 1
    • Retirez les deux vis cruciformes n° 2 de 11,7 mm reliant l'interrupteur d'alimentation à la carte mère.
    There are two models of SNES- the one pictured here, and the other with a large sound board chip behind the game cartridge reader.
    Gena FM - Réponse
  4. Remplacement de la carte mère du Super Nintendo: étape 4, image 1 de 2 Remplacement de la carte mère du Super Nintendo: étape 4, image 2 de 2
    • L'interrupteur d'alimentation est connecté à la carte mère près du coin supérieur gauche de la console.
    • Retirez délicatement le connecteur de sa prise sur la carte mère. Vous devrez peut-être le sortir pendant que vous tirez.
    • Ne détachez pas le connecteur en tirant sur les fils. Cela pourrait endommager les fils ou la prise.
  5. Remplacement de la carte mère du Super Nintendo, Bouton d'éjection: étape 5, image 1 de 2 Remplacement de la carte mère du Super Nintendo, Bouton d'éjection: étape 5, image 2 de 2
    • Soulevez le côté droit du levier d'éjection hors du boîtier.
  6. Remplacement de la carte mère du Super Nintendo: étape 6, image 1 de 3 Remplacement de la carte mère du Super Nintendo: étape 6, image 2 de 3 Remplacement de la carte mère du Super Nintendo: étape 6, image 3 de 3
    • Tirez la barre métallique à travers le côté droit du levier d'éjection.
    • Assurez-vous de garder une trace du ressort situé sur le côté gauche du levier car il peut jaillir lors du retrait de la barre métallique.
    • Au remontage, la procédure devient plus difficile à cause du ressort (marqué en rouge). Nous recommandons qu'une personne maintienne le ressort en place (photo 3) tandis qu'une autre personne glisse la barre métallique dans le boîtier de gauche et glisse le levier d'éjection sur la barre métallique.
  7. Remplacement de la carte mère du Super Nintendo, Port du contrôleur: étape 7, image 1 de 1
    • Soulevez les ports du contrôleur hors du boîtier, cela doit être fait sans trop de force. Notez l'emplacement de la connexion du câble plat.
  8. Remplacement de la carte mère du Super Nintendo: étape 8, image 1 de 2 Remplacement de la carte mère du Super Nintendo: étape 8, image 2 de 2
    • Retirez délicatement le câble plat de son port.
  9. Remplacement de la carte mère du Super Nintendo, Carte mère: étape 9, image 1 de 1
    • Retirez les deux vis cruciformes de 11,6 mm qui relient le blindage avant à la carte mère.
    Older versions of the SNES have the shield attached to the 62 pin connector and you will need to remove more screws and take the shield off with the pin connector in one step.
    Paul Arnold - Réponse
  10. Remplacement de la carte mère du Super Nintendo: étape 10, image 1 de 1
    • Soulevez le bouclier avant vers le haut pour le retirer de la carte mère.
  11. Remplacement de la carte mère du Super Nintendo: étape 11, image 1 de 1
    • Retirez les deux vis cruciformes n° 2 argentées de 15,6 mm de chaque côté du connecteur à 62 broches.
  12. Remplacement de la carte mère du Super Nintendo: étape 12, image 1 de 1
    • Retirez la vis cruciforme n° 2 de 11,8 mm située à l'arrière de la SNES.
  13. Remplacement de la carte mère du Super Nintendo: étape 13, image 1 de 1
    • Soulevez la carte mère vers le haut pour la retirer.
    Be careful, when removing the motherboard on my SNS-001 model, the two silver phillips screws on each side of the RF Modulator HAVE to be removed (towards the rear next to the dc power in and the av multi in).
    K4PDaddy - Réponse
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
44 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Melina
Membre depuis le 10/12/10
953 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-47, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 membres
25 tutoriels rédigés
4 commentaires
There are several versions of the Super Nintendo. Steps for my version are a bit different.
joshenders - Réponse
This seems to be a newer super nintendo. If you have one of the older ones, there will be a bit more screws but still basically the same steps.
Anonymous Idea -
There are two versions of the Super Nintendo- the one pictured here, and one with a sound chip board behind the game cartridge reader. These two models have different shells that are not interchangeable (important to know if you're looking to buy a replacement housing for your SNES)
Gena FM -
It’s possible they may be referring to the European/Japanese version of the Super Nintendo/Super Famicom. Either that, or it’s one of the weird, misshapen “reskins”.
Rupin Soland - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 82
30 derniers jours : 405
Total : 71,194
