Introduction
Ceci est le guide de remplacement de la carte mère de la Microsoft Xbox.
Ce dont vous avez besoin
Utilisez un spudger en métal pour dégager les quatre pieds en caoutchouc.
The screw is in the outside corner. If you pry up only the half of the foot on that side, you can easily remove the (very long) screw, and the foot will stay attached.
Ah I always used to damage the feet.
Vous pouvez soit enlever les étiquettes ou simplement rechercher les trous de vis à travers les étiquettes et ensuite couper ou percer un trou à travers elles.
It is also easy to feel for the screw hole with your finger and then cut a hole, or punch it out with the tip of the Torx driver to reveal the screw.
Tirez le câble ruban de données du disque dur et le câble d'alimentation à la verticale du disque dur.
Remember that the new drive will only work if it has been properly prepared, and the Xbox has been modified.
there is NO way to legally replace the xbox hard drive. it is LOCKED to the motherboard and the xbox will not boot to the OS or make it past the BIOS if the HDD is not the one that came with it from the factory. you MUST use a mod chip and “home brew” to do a HDD swap and expect it to work
Could you point me to a good tutorial on using a modding an original Xbox? All I want to do is swap an HDD in original Xbox with another original Xbox HDD because I want my saved game data. Any way to figure this out? Seems like modding is a !&&* of a burden.
Can i replace the original hard drive with new one
Retirez le lecteur de disque. Il devrait sortir tout de suite.
Débranchez le câble ruban et les câbles jaunes à l'arrière du lecteur de disque.
Soulevez les languettes en plastique noir autour du lecteur afin de le retirer de son logement. Une fois retiré, mettez le lecteur de côté.
ENLEVER SEULEMENT SI HS!
It is ok to remove the drive if it isn't dead. If repairs are required to the drive it needs to be removed from the drive's housing.
Surely this needs to be removed to access the motherboard?
Yes, it does.
Zerobuss -
Débranchez le cordon d’alimentation multicolore de la carte mère. C'est assez serré là-dedans, donc cela peut demander un effort.
Débranchez le faisceau de câbles jaunes ainsi que le cordon arc-en-ciel de la carte mère.
Pour remonter votre appareil, suivez ces instructions dans l’ordre inverse.
39 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
