Aller au contenu principal
Samsung Galaxy S III microSD Card Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S III microSD Card Replacement, Rear Case: étape 1, image 1 de 2 Samsung Galaxy S III microSD Card Replacement, Rear Case: étape 1, image 2 de 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III microSD Card Replacement: étape 2, image 1 de 2 Samsung Galaxy S III microSD Card Replacement: étape 2, image 2 de 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III microSD Card Replacement: étape 3, image 1 de 2 Samsung Galaxy S III microSD Card Replacement: étape 3, image 2 de 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III microSD Card Replacement: étape 4, image 1 de 2 Samsung Galaxy S III microSD Card Replacement: étape 4, image 2 de 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III microSD Card Replacement: étape 5, image 1 de 2 Samsung Galaxy S III microSD Card Replacement: étape 5, image 2 de 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III microSD Card Replacement, Battery: étape 6, image 1 de 2 Samsung Galaxy S III microSD Card Replacement, Battery: étape 6, image 2 de 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III microSD Card Replacement: étape 7, image 1 de 2 Samsung Galaxy S III microSD Card Replacement: étape 7, image 2 de 2
    • Remove the battery.
  8. Samsung Galaxy S III microSD Card Replacement, microSD Card: étape 8, image 1 de 3 Samsung Galaxy S III microSD Card Replacement, microSD Card: étape 8, image 2 de 3 Samsung Galaxy S III microSD Card Replacement, microSD Card: étape 8, image 3 de 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  9. Samsung Galaxy S III microSD Card Replacement: étape 9, image 1 de 2 Samsung Galaxy S III microSD Card Replacement: étape 9, image 2 de 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
27 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 15,687
