Introduction
Allez à l'étape 1 ↓Si la brosse rotative ne tourne pas, vérifiez la courroie du rouleau pour voir si elle doit être remplacée. L'aspirateur fonctionnera toujours mais la brosse ne tournera pas si la courroie est cassée.
Ce dont vous avez besoin
Pièces
Outils
Tirez sur la poignée tout en appuyant sur le bouton de levage pour retirer le corps de l'aspirateur.
Retirez la courroie du rouleau autour de la brosse rotative et de l'engrenage du moteur.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
34 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Je commence à traduire ›
31 commentaires de tutoriel
Very helpful re shark vacuum , thank you!
First of all, I couldn’t find the belt at 3 different stores that sell the vacuum including the place I bought it. Not on their websites either. And not on Shark’s website. Strange. I got it from Amazon. Next, I cannot get at the roller as the housing won’t come apart even with brute force. And yes, I got all the screws out and followed all instructions. It just fits so tightly, I cannot get it apart. I have a $350 vacuum, an $8 belt, and I cannot vacuum my rugs. Really disappointed as I’ve replaced belts in other vacuums in the past with no problems. And I’ve had this vacuum for a relatively short time and use it only weekly in a fairly small condo. Not sure why the belt literally disintegrated and came out in pieces.
The number of screws in the instructions is not correct. There were 11 in mine. One that is deeper and my screw driver didn't reach. But since I was just trying to clean the roller I gave up. But I'm betting you still need a screw or two out if you only took out the number listed. good luck. P.S. sometimes something you vacuum up gets in just the wrong spot and eats the belt by rubbing. The heat disintegrates it.
