Introduction
Sur la face avant de la Sonos Play 3, il y a une grille rectangulaire. Si elle est endommagée ou s'il y a une accumulation de saleté, cela peut affecter la qualité sonore de l'appareil. La grille extérieure devra être remplacée ou retirée et nettoyée afin de résoudre ce problème. Ce guide vous montrera comment retirer la grille.
Ce dont vous avez besoin
Insérez une spatule le long du bord de la grille et utilisez-la délicatement pour retirer la grille du boîtier. Faites glisser la spatule sur la longueur de la grille pour détacher tous les clips qui la maintiennent en place.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
4 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Stéphane MILOUX nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
According to Sonos the grille is NOT removable. Looks like the adhesive mentioned above is there for a purpose. Shame really.
I've had my sonos 3 outside for three years, under cover though. It started to sound awful a couple of weeks ago. I thought they would try to remove the grille, but according to Sonos there was no way to remove the grille, it was a fixed assembly.
But yesterday I put more effort into googling, and found this page. I understand that it sounded bad, there was dirt, dust and other debris in it when I finally got rid of the grille, now I just have to listen to it, because it was late yesterday and I have to pay attention to the neighbors, so I could not find out at such a low volume if it helped, but I think so. You saved me from going and buying one or two Sonos 1 play, as my son suggested. We will have to wait and see until the neighbors around have woken up. I have high hopes that it works, Thanks for a tip on the unopening Sonos 3, shame on the one who gives up (a Swedish
proverb).
Thanks
/ Anders
