Tutoriel réalisé par la communauté
Un membre tout à fait remarquable de notre communauté a réalisé ce tutoriel. Il n'a pas été créé par l'équipe iFixit.
Introduction
Comment remplacer la lentille laser uniquement - tutoriel vidéo.
How to disassemble the PS3 super slim and remove the Laser Unit /Deck you can see here:
Ce dont vous avez besoin
Outils
Instructions vidéo
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
9 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Je commence à traduire ›
5 commentaires de tutoriel
1. Do not loosen any screws the guide bars sit on. They are factory set at the correct height.
2. It is only necessary to remove the clips on the drive motor side of the guide bar. The laser will come right off the worm gear and you can remove the laser.
Wade - Réponse Partager
Hi, i have a ps3 super slim CECH-4201C and it stopped playing any disk i put in it. So i wanna change it but my lens is a single lens and all the ones i can find is double, will it still work for mine? Also where can i get a single lens and which is better. The console is 500gb came with "The last of us". Thanks. Hope to hear from you soon.
temidayoabayomizannu - Réponse Partager
Too advanced for me to do. Whenever I take things apart I mess them up. Once took a PS3 fat apart and could never get it back together. If I sent it to Playstation they wouldn't delete my saved data right?
konekodemon - Réponse Partager
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
Robert Shelton - Réponse Partager
Cómo se que modelo de láser comprar?
Anderson Egenor - Réponse Partager
