Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Ce tutoriel vous aidera à remplacer la nappe de votre disque dur ou à la resserrer si elle est lâche.
  1. Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    It looks like you need a Phillips #000 screwdriver for the 10 bottom screws. I tried the #00 and it's too big. Good thing I bought a 23 piece precision screwdriver set or else I would have been screwed.
    scott523 - Réponse
    The 10 screws that hold tha bottom case take a #00 Phillips driver, if yours doesnt fit it's probably because it's cheaply made & not precise enough. The only thing that I needed a #000 driver for was the keyboard screws. They're so small they look like specks of dirt or sand. I stripped out 4 of them & now will need to grind the heads off with a Dremel/rotary tool. The other thing that sucks is iFixit doesn't have a tutorial for keyboard replacement!
    iphonetechtips -
    A true Phillips head screw's slots are rounded at their inner corners, to allow the screwdriver to "cam out" (pop out) of the screw head before you apply too much torque and strip the threads in the part that you're torqueing the screw into. However, the screws used in the Macbook don't have those rounded inner corners, so they're not Phillips. Instead, they may be a Japanese standard known as JIS B 1012, or a Frearson (also known as a Reed & Prince), but that's a less common design. Maybe technically these non-Phillips screws should be used with a screwdriver that was specifically designed for them, but they can be properly removed and reinstalled using a truly precision-made Phillips #00 (some people find a #000 sometimes works even better) whose tip comes to a sharp point--not the lousy fake "precision" screwdrivers that are sold in too many places. See my next comment for more.
    johnsawyercjs -
    Many screwdriver manufacturers get away with marketing fake "precision" screwdrivers because, in the words of the Wikipedia article at https://en.wikipedia.org/wiki/List_of_sc...: "Most heads come in a range of sizes, typically distinguished by a number, such as "Phillips #00" or "Torx T5." These sizes do not necessarily describe a particular dimension of the drive shape, but are often arbitrary designations in the same sense as a "Size 8" dress."
    In other words, the quality of many "precision" screwdrivers is poor. In my experience, one of the biggest problems with many fake "precision" Phillips screwdrivers is that the four blades at the tip are often too wide, and their width may even vary on the same screwdriver (they're not supposed to). So just because a screwdriver is marketed as a "precision screwdriver", it may not be, and many that are labeled as #00, or even #000, will not work for a Macbook's screws. See my next comment for still more.
    johnsawyercjs -
    One of the best manufacturers of precision screwdrivers is Wiha (http://www.wihatools.com/tech-tools/prec... cost more, but they're worth it. Or buy screwdrivers from iFixit, who seem to be selling JIS screwdrivers.
    Another article with some good info on screw and screwdriver types:
    http://www.instructables.com/id/When-a-P...
    Also keep in mind that some screws are tougher to remove and reinstall because they have a thread-locking compound on them, which is usually blue.
    johnsawyercjs -
    Phillips #00 is the correct screwdriver for the lower case. Maybe the one you have is worn or badly made.
    David Fear -
    Perfect man!Many thanks!:)
    wertaerte - Réponse
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    twisk - Réponse
    thanks twisk, I wish i would have read your tip before I finished putting the bottom of my laptop back together. I managed to get all screws in somehow, but one was in fact too-tight.
    BTW, big big thanks to the Author: Andrew Bookholt. Just used this guide and my trackpad now works again.
    xitxit2 -
    i too need a #000 for the bottom of the case -- i got the recommended screwdriver (#00) and unfortunately it's too big
    plins718 - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    The colours you used for these circles are indistinguishable for colour-blind people. Please consider using something like the palette suggested by visibone: http://www.visibone.com/colorblind/
    Eric Sorenson - Réponse
    Squares, Circles, Triangles (you get the idea) would work as well to distinguish the different screws.
    danzeitlin -
    I'd use a Phillips #000 screwdriver also. The #00 can work, but if the screws are in really tight, it doesn't get far enough down into the screws to get purchase, so it will start to strip (and I agree that the screws are pretty soft). On mine, the screws for the fan were really tight, started to strip with #00, needed a #000 and quite a bit of pressure to get them to move.
    jonathanmorgan - Réponse
    I thought it took a 000 as well. However, I tried both and realized the 00 works best.
    john - Réponse
    Hi i was wondering if you can add 16gb to this model? or is 8 the maximum?
    Igor - Réponse
    The Mid 2010 MacBook Pro 13" does support 16 GB RAM, but it is very picky about the type of RAM. OWC sells a 16 GB kit (2x 8 GB). I think it's got to be 1066 (aka 1067) MHz RAM. A lot of 8 GB modules on the market now are faster than 1066 MHz, and reports I've read say people start getting kernel panics if they use the wrong RAM.
    Some info here:
    http://www.everymac.com/systems/apple/ma...
    "1066 MHz PC3-8500 DDR3 SDRAM"
    "*Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM."
    Our Mid 2010 already had "the latest EFI" (i.e. Boot ROM version in System Profiler), so the reference to updating it may not be relevant.
    Winston -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I had the same problem. The #00 screwdriver worked for some of the screws but some others were too tight and I had to use a #000. Maybe it was because the cover had slightly bent because the battery inside had basically doubled its width, but I still found that the #000 was a much better fit for these screws. Even the ones that came out with the #00 came out much easier with the #000. I would suggest updating this guide to suggest using a #000.
    tarriojuan - Réponse
    Had no idea they were so expensive.
    Franklin - Réponse
    Phillips #00 is the right tool for all the steps (Except the 4 HD T6 screws). Maybe there is dirt in the notch.
    Luis Soto - Réponse
    There is any chance to use the Toshiba MQ01ABD 1 TB 2.5" Internal Hard Drive MQ01ABD100 , it has7200 rpm , shuold it work?
    Luis - Réponse
    If you are running OS X 10.11.2 or newer, battery provided by iFixIt will not work. I've already tried 2 batteries from iFixIt and neither worked. iFixIt needs to come clean on this unfortunate situation. I've already put 8 hours into this futile effort when it should have taken me 45 minutes.
    gkofga - Réponse
    What was your solution? I'm using 10.11.3 OS X. I may need a battery replacement very soon too.
    John Doe -
    <i>The 10 screws that hold that bottom case take a #00 Phillips driver, if yours doesn't fit it's probably because it's cheaply made & not precise enough.</I>
    I purchased the IFixIt 54 bit Driver Kit and their Phillips #00 are <b>NOT</b> the appropriate size for the bottom screws on this MacBook Pro. This manual needs to have the tools changed to Phillips #000 Screwdriver. Until then I shall not click the "Give the author +30 points" button. Apart from that, the rest of the manual is very good. It would also be an idea to make a comment about making sure the battery connector is in the correct position when plugging the battery back in. One poster commented that their battery will not charge anymore. My guess is a pin(s) was/were bent due to the connection not being in the vertical orientation when being pressed back together. :-)
    THANK YOU for writing and generously supplying this guide for our use. It is much appreciated. +30 point coming when the Phillips #000 size is changed or added.
    Joseph King - Réponse
    It would be nice to remind fixers which length screws go back in which holes, in case they get mixed up...
    Mike - Réponse
    Wonderful guide
    Freda - Réponse
    j’ai remarqué que le 4 vis philips courtes sur le bord avant ont une courte entretoise
    celles des cotés n’en ont pas et sont courtes
    la dernière sur le bord qui comporte les 3 longues, est un poil plus longue
    si l’on ne fait pas attention, les vis des cotés ne peuvent pas se visser à fond et dépassent un peu
    parfait pour le reste ! Merci
    Vincent Morault - Réponse
    I am pretty sure that one of the tools listed as needed has changed from when I looked it up last week and placed the order, and is a mistake. Here is a screen shot of the first step to replacing the fan on my Mac unibody. Doesn’t a 3mm Phillips call for a #1 PH screwdriver? Is the mistake in the size of the screw or the screwdriver designation? And I am sure the last time I looked it did not say I needed to remove 13.5 mm Phillips screws. Maybe I can figure it out, but I once ruined a laptop by dropping a back screw from the screwdriver into the innards. I never found it - until it rattled around and ruined the computer! Should I guess? What does everyone think?
    Virginia S Moe - Réponse
  2. Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
  3. À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    why is step 3 necessary?
    gansodesoya - Réponse
    Citation de gansodesoya :
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    Removes the possibility of any current flow. This is especially important if you are trying to mitigate the damage to the circuitry due to a spill on a keyboard.
    amiller770 - Réponse
    I'm thinking of ordering the spudger. I was thinking of order the heavy duty spudger... or should I just order the normal. Will either of the spudgers work for this DIY?
    shockaaa - Réponse
    Once you have a set of spudgers, you will wonder how you ever went without them. :-)
    Brian -
    $@$@. Don't use an non-isolated screwdriver for this. I just shorted-out my battery :(
    Lukas Besch - Réponse
    You are absolutely right, never use a screwdriver on the logic board or any connector! Delicate use of fingernails or a credit card will get you through most situations if you lack a spudger.
    Logan Bean -
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    Would it not be advisable to drain the battery completely before attempting to repair, if you want to be sure you don't get a spark when removing the battery connector?
    Berlugana
    bduault - Réponse
    Disconnecting the battery connector is not that different from simply unplugging a battery from an older model MacBook with a removable battery. You're not trying to protect yourself from a "spark", but the internal circuitry when taking the MacBook apart.
    amiller770 -
    I neglected step 3 and now my computer won't turn on. Could I have shorted out my logic board?
    Plamen - Réponse
    I had the same problem , my macbook doesn't switch on working
    marioluiggi -
    A very easy and fast update indeed! Using this guide and the tools indicated on top I replaced the two RAM cards (2GB each) with two 8GB RAM cards from OWC for a total of 16GB RAM in my MBP Middle 2010 Core 2 Duo (Officially not supported according to Apple).
    Make sure you select RAM with these specs: 16GB DDR3 PC8500 1066MHz Kit (8GBx2)
    Apps open much faster and I can run a virtual machine at a decent speed.
    Luis Soto - Réponse
    Removing the battery is not required, but in some instances can make installing ram much easier. If you plan on upgrading from 4GB (2X 2GB) to 8GB (2X 4GB) Removing the battery would be better. There are two levels of ram. If you are replacing both levels, then remove the battery. If you are just replacing the top, dont bother. Removing the battery for very long or even at all (depending on the CMOS battery age and health) could possibly reset settings, the clock, saved wifi passwords, and more.
    Everett Whiteman - Réponse
    It is beneficial to remove the battery at this stage.
    Knox Karima - Réponse
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
    Guys I just used my index finger nail. It’s the most useful nail to let grow a little bit for this type of procedure. Came off pretty easy when using both my right hand index and left hand index together to lift the plug up out. Found some plastic folded it and place it right over the socket so the plug would go back in and now the plug holds the plastic in place so I can focus on the main work.
    clsmithj - Réponse
  4. Retirez les deux vis Phillips par lesquelles le support du disque dur est fixé au boîtier supérieur.
    • Retirez les deux vis Phillips par lesquelles le support du disque dur est fixé au boîtier supérieur.
    • Ces vis captives sont intégrées au support du disque dur.
    I can't seem to loosen one of the screws... I know they are not supposed to come out, but one will not loosen, at all...... Any ideas on how to get it loose?
    David - Réponse
  5. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  6. Soulevez le support de fixation hors du boîtier supérieur.
    • Soulevez le support de fixation hors du boîtier supérieur.
  7. Soulevez le disque dur en tirant sur sa languette d'extraction et sortez-le du châssis, en faisant attention au câble qui le relie à l'ordinateur.
    • Soulevez le disque dur en tirant sur sa languette d'extraction et sortez-le du châssis, en faisant attention au câble qui le relie à l'ordinateur.
  8. Retirez le câble du disque dur en débranchant son connecteur du disque dur.
    • Retirez le câble du disque dur en débranchant son connecteur du disque dur.
    You can stop here if you only need to replace the hard drive, right?
    Joe Ireland - Réponse
    Only if you don't want a hard drive in your MacBook Pro. ;P
    *Step 7: REMOVE HDD
    *Step 8: REPLACE HDD
    Key steps if you need to save or access data. That is, unless you use an external HDD. Then yes, you can stop at step 7.
    iphonetechtips -
    Straight-forward and easy to follow.
    No problems except minor ones from not reading all the text...easily fixed by reading :-)
    Used Carbon Copy Clone rather than Super Duper to clone drive.
    JOSEPH BLANKIER - Réponse
    I did this exactly with a 7200 RPM WD Scorpio that I had been using in my MacBook 13" Unibody (before Apple discontinued that). I get a nasty crash on boot, even with the OS X 10.6 Install DVD. I mean BSOD-equivalent crash. The MacBook Pro is brand new. Anybody know why this happens?
    Blake - Réponse
    I fixed it. I don't know which of the following did it. 1) I ran all software updates to the OS using the MacBook before transferring the drive again into the MBP, and 2) when I installed the drive I disconnected the battery – perhaps this reset the SMC. While booting, I held Option and it recognized the new HD right away. From then on, it booted fine.
    Citation de Blake :
    Blake - Réponse
    This could be from the Apple firmware update for 7200 RPM Drives. They released an update because these were causing vibration that people were complaining about. Maybe it wouldn't function without update?
    iphonetechtips -
    I guess it's probably my fault that I broke the SATA cable during this step (unless the cable was somehow already weakened), but for anyone reading this, be extra careful. My connector was fitted really tightly, and when it finally came out it ripped the cable, which is pretty expensive in its own right (although you can get a cheaper deal on eBay).
    nitrous - Réponse
    Had no issue since installation of a 7200RPM WD Scorpio 750GB drive and had no issues with vibration. I did notice back when I got this MacBook Pro though, the pre-installed Apple branded drive was only performing at half of the 3Gbps potential (1.5)
    I could see letting Apple get away with that on a consumer level machine but for the premium price, I expect performance.
    Needless to say even running the same HDD on my same MBP, I've had not a single problem with the HDD upgrade. Best money spent on it along with additional RAM.
    Brian - Réponse
    Everywhere I see recommendations for a torx t6 driver yet many warn me I need a tr6 security driver. ???? Are ALL macs including the mid 2010 using the tamper resistant screws? I am going blind trying to see the pin in the middle!
    suzann fulbright - Réponse
  9. Dévissez les quatre vis suivantes, qui fixent la nappe du disque dur et du capteur IR au boîtier supérieur :
    • Dévissez les quatre vis suivantes, qui fixent la nappe du disque dur et du capteur IR au boîtier supérieur :
    • Deux vis cruciformes de 1,5 mm.
    • Deux vis cruciformes de 9,5 mm.
    Anyone have a source for the two 9.5mm screws?
    gwaldman - Réponse
    Taking the two little screws from the cable was easy... putting them back was another story LOL. It really would have been helpful to have a magnetic precision screwdriver so the teeeeeeny little screws would stick to it... because trying to get them back into the hole, when the new cable is still kinda bouncy and not bent to those sharp right angles... I actually launched one of them about 3 feet away when my finger slipped and the cable popped up with the screw in the hole (but not yet tightened). Luckily I found it, and eventually got them screwed back in!
    gorisikh - Réponse
    is there anywhere i could buy another set of the screws that hold down the hdd cable? i think mine is broken and i could get it out of it's socket, any information about the screw specs is very appreciated, thanks
    Andy Wijaya - Réponse
    I could not shift the 1.5mm screws - either I need a smaller screwdriver or they’ve seized. In the end I had to cut the PCB bar on the old cable, and put the new one over the top - which then meant the retaining bracket wouldn’t fit.
    Peter B - Réponse
  10. Faites glisser le support du disque dur et du capteur IR pour l'éloigner du bord du boîtier supérieur. Détachez soigneusement la nappe du disque dur et du capteur IR du boîtier supérieur.
    • Faites glisser le support du disque dur et du capteur IR pour l'éloigner du bord du boîtier supérieur.
    • Détachez soigneusement la nappe du disque dur et du capteur IR du boîtier supérieur.
  11. Avec l'extrémité plate d'une spatule (spudger), faites levier sur le connecteur de la nappe du disque dur pour la débrancher de la carte mère.
    • Avec l'extrémité plate d'une spatule (spudger), faites levier sur le connecteur de la nappe du disque dur pour la débrancher de la carte mère.
  12. Soulevez l'ensemble nappe du disque dur/capteur IR hors du boîtier supérieur.
    • Soulevez l'ensemble nappe du disque dur/capteur IR hors du boîtier supérieur.
    • Si votre pièce de rechange est livrée sans la fixation du disque dur et le témoin lumineux, détachez-les de l'ancienne pièce et transférez-les sur la nouvelle.
    • Il se peut que votre pièce de rechange soit livrée avec plusieurs intercalaires autocollants en mousse. Ils servent à bien ajuster à la fois la fixation et le disque dur. Utilisez-les seulement si nécessaire.
    I bought the cable from ifixit and did have to peel off the IR receiver, which was surprisingly challenging. I'd never come across the ribbon cable clamp connection before and so didn't know how to open it, or how much of the new cable needed to go in. I'd also suggest marking the location of the cable that attaches to case bottom, before you pull it off. A few pencil marks would work. (That's probably a step 8 add)
    gregsrow - Réponse
    I had the same challenge with the ribbon cable clamp. There is a tiny orange ribbon, visible in the lower left corner of the photo for step 10, above, that needs to be connected to the new part using a tiny clamp, also visible right there in step 10. To open it, you flip up part of the clamp that is opposite the ribbon. That will release the ribbon, and enable you to slide the ribbon into the new clamp, which then you can adhere to the bracket. Hope that's helpful for future fixers.
    Bryony - Réponse
    Thank you, Bryony! Very helpful clarification on how to open the clamp. All set now.
    Lucas -
    Thanks. You comment should be added to the guide along with a close up photo.
    larsvange -
    Thanks to Bryony I easily fastened the small orange connector. For future fixers: I photographed the little clamp while opened: http://imgur.com/a/1cYyx. Use the edge of a credit card or a plectrum to open it.
    Pete -
    Thanks for posting these tips. Made detaching and then attaching little orange cable possible for me.
    B. Saunderson -
    It would REALLY be helpful if there were some instructions with close-up photos to guide you through the process of removing AND re-attaching the IR sensor component to a new drive cable. This is not intuitive and the part is very small and fragile. Forcing things the wrong way will quickly result in breaking parts. Bryony's comments were very helpful (Thank YOU!). Any way to get these steps added to the guide?
    tpoyner - Réponse
    Just want to endorse tpoyner's request to add guidance on how to attach the tiny, tiny orange ribbon cable to the clamp. I managed to do it without lifting the clamp but was terrified of damaging the delicate cable. Wish I'd ready Bryony's comment first.
    David - Réponse
    Does anyone have pictures of how to reinsert the IR orange cable? Or a link to a site that does..stuck at that part
    knickerbockers16 - Réponse
    Success. I agree that this is the trickiest part of the job, and is the least documented.
    Getting orange ribbon cable off is relatively easy, but reseating it onto the new cable was an <OMG, I am going to break this> moment.
    My approach was to slide the side of a credit card underneath and use that as an in situ support. I was then able to exert some lateral force to reseat the orange cable connector into the connector on the black plastic terminal piece of the new cable.
    NB: I did unpeel the sticky back of the black piece before reconnecting cables.
    Advice: at the end, stick the length of the cable to the case following the original path; make sure it is flush with the other side of the case on the short vertical drop. Any slack in the cable length will foul the replacement of the back IR sensor assembly.
    Good Luck!
    (PS: got my cable cheaply from eBay, but I note that the date stamped on the cable is 2009, so if it was a faulty batch from that period, maybe I have a problem in store for the future...?)
    Leo - Réponse
    Pic 1,2 : the new 2012 cable does not fit on the old 2009 Mac.
    Pic 3 : the 2009 cable on the 2009 Mac.
    Pic 4, 5 : both cables 2012 821-1480-A (new but does not fit), 2009 821-0814-1 (defective, to be replaced).
    Pic 6 : the clamp closed.
    Pic 7 : the clamp opened with orange ribbon still in.
    Pic 8, 9 : orange ribbon out.
    I could open the clamp with nail.
    I could unscrew with PH00.
    Some crews hard as mentioned.
    Sorry for the bad pictures, I did not set my camera at max resolution.
    Presbytes have good lenses !
    http://pierre.albarede.free.fr/technique...
    palbarede - Réponse
    I have tried in every possible way, but I am not able to slide the orange ribbon deep enough in the tiny hole to make contact. The light stays off and I guess the IR receiver will not work as well.
    I am very frustrated, Thanks anyway for the help.
    rubecube - Réponse
    I have a mid 2009 and i use another cable that fits perfect and everything expect for two holes for screw will it work? Is that i was booting it from external until i bought the cable
    carlos - Réponse
    is there a more detailed guide on replacing the sensor portion?
    John - Réponse
    From which direction do I flip up the IR sensor ribbon cable clamp?
    B. Saunderson - Réponse
    For future readers..... Just came across this post which explain with good photos about how to flip up the IR sensor ribbon cable clamp.
    http://www.dannydullin.com/macbook-pro-m...
    B. Saunderson -
    To connect the orange ribbon for the IR sensor you have to have to lift the little handle on the back part 90 dregrees up of the black plastic terminal piece. So now its open.
    After you did this its totally easy to insert the orange ribbon flat cable. After that close the little handle again - thats all!
    Jpat70 - Réponse
    Thank you Jpat70 for your tip on the orange sensor cable. Made the install super easy!
    Stephen Boyd - Réponse
Pour remonter votre ordinateur, suivez ces instructions en sens inverse.
285 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Used a Phillips #00 and a creditcard. It's an easy job, takes about 10 minutes. :)
sjoerdstra - Réponse
In step #8 the two small screws were very tight in my computer. The Phillips #00 was too large and damaging the screws. I changed to a Phillips #000 applied substantial pressure and voila, the screws came off.
Reassembly: placing the IR sensor cable (the one you"peeled off" in step #9) is a bit tricky. Start from the side opposite the IR sensor (the side with the two small screws of step 8) and press first along the short vertical side and then across towards the IR section. There should be a little left for a vertical section at the IR sensor end.
bgrinstein - Réponse
Very Easy and clearly written instructions
omar - Réponse
Can you illustrate how to attach the gold strip cable?
Rene - Réponse
if i change the HDD cable and get the same results what could be the the real problem , because the original problem as we all know was the we were getting the question mark on the white screen .
Curtis O'brien - Réponse
I’m also experiencing this issue after replacing the cable. Were you able to resolve it?
ANNA -
Did a combination of the hard drive replacement cable, a hard drive swap to SSD, and battery swap. Super easy. Great instructions! Thank ya!
Aaron Dimatulac - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 6
7 derniers jours : 46
30 derniers jours : 254
Total : 160,784
