Introduction
La Plaque de base du Krups F203 est trompeusement difficile à retirer. Afin d'accéder aux composants internes, il est nécessaire d'y procéder.
Ce dont vous avez besoin
Dans chacun des quatre emplacements rectangulaires de la base de l’appareil se trouve un clip en E
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
9 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Artefil nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
11 commentaires de tutoriel
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
