Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE
Ce dont vous avez besoin
  1. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE, Bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 1, image 1 de 1
    • Avant de poser les nouvelles bandes adhésives, connectez temporairement votre nouvelle batterie et vérifiez son alignement dans l'iPhone.
    • Si tout a l'air en ordre, déconnectez et retirez la batterie.
    Non-Sticky Run Through
    Critical to Success is doing a non-sticky run through of these steps. I realized:
    1) Need to remove the screen. I was going to attempt the battery replacement without removing the screen, but after running throught these steps, it was clear I needed the freedom of movement. You only get one shot.
    2) Shape of the connector cable at the socket was more shallow on the new battery. The connector cable has a shape like a flag and flag pole. The original had a ‘V’ shape between flag pole & flag. The new battery had an ‘L’ shape. Using the spluger and a plastic card, I carefully reshaped the connector cable. I was not too picky about matching the shape; Seems like this cable could break. I made just enough shape to route the cable off the socket level, down to the back of the phone where it rejoins the flag pole— If you can imagine it.
    3) Step 7 and 8. In my infinite wisdom, I was going to do steps 7 & 8 differently. Thankfully, I paid attention to these steps. You only get one shot.
    xtian - Réponse
  2. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 2, image 1 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 2, image 2 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 2, image 3 de 3
    • Décollez le large film en plastique bleu de votre nouveau set de bandes adhésives et retirez-le complètement.
    • Faites attention à ne pas toucher accidentellement les bandes adhésives après cette étape. Elles ne collent qu'une fois. Si elles adhèrent à vos doigts ou à une autre surface, vous devrez les jeter et en utiliser d'autres.
    • Le film bleu est parfois défectueux et il n'est plus possible de le décoller. Dans ce cas jeter les bandes et procurez-vous-en d'autres.
    • Si cela vous arrive et que les bandes viennent de chez iFixit, contactez-nous et nous vous enverrons immédiatement une pièce de remplacement.
    • Entretemps, vous pouvez remonter temporairement votre iPhone en fixant la batterie avec un morceau de ruban adhésif double-face.
    Be cautious: On some adhesive strip packages (I didn’t buy my at iFixit) they have mixed the colours! Be sure to peel off the largest piece of plastic.
    Tor - Réponse
    I wish I had read your comment first; this happened to me too with another company’s adhesive strips and my tab ended up back-to-front. I know now for next time what to look for when orienting the strips and their tab (black surface of the tabs facing upward when laying the strips in to the case).
    Dugald Holmes -
  3. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 3, image 1 de 2 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 3, image 2 de 2
    • L'adhésif à découvert face à la terre, repliez la languette noire de 90° vers le haut.
  4. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 4, image 1 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 4, image 2 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 4, image 3 de 3
    • L'adhésif à découvert toujours orienté vers le bas, alignez soigneusement les languettes dans la coque arrière de votre iPhone.
    • Positionnez la languette noire juste à côté du boîtier en plastique noire du haut-parleur dans le coin inférieur droit, mais sans le toucher.
    • Posez les bandes adhésives sur la coque arrière et faites-les adhérer.
    Should have mentioned to leave a 1/16” gap at bottom so there's room to fold adhesive removal tab back down, mine so tight no room to fold back ,Hope it goes back together again !
    Wayne Camarano - Réponse
    Use a piece of cardboard paper behind the black tab, to give you some room.
    Fold the adhesive removal black tab before sticking the adhesive,, to give it the shape, and be better prepare for step 10.
    Sebastien CHAPUIS - Réponse
  5. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 5, image 1 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 5, image 2 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 5, image 3 de 3
    • Appuyez sur chaque bande pour qu'elle adhère entièrement à la coque arrière, en commençant par le milieu puis progressant vers l'extérieur de part et d'autre.
  6. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 6, image 1 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 6, image 2 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 6, image 3 de 3
    • Décollez complètement le large film rose.
    I propose to fold the black tab in the middle downward, as desribed in step 10, already now, before removing the pink film and inserting the battery. For the next steps, press the so folded tab towards the speaker. I used a plastic card for this (old credit card cut to the correct width). Remove the pink film using the other hand, then insert the battery. This is much easier than squeezing it into the narrow gap after the battery has been mounted. I die some photos, but I don't know whether I can opload them.
    Schiebi - Réponse
  7. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 7, image 1 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 7, image 2 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 7, image 3 de 3
    • Sans coller encore la batterie, approchez son connecteur de l'iPhone et alignez-le avec sa prise sur la carte mère.
    • Connectez la batterie.
    I connected the battery before removing the pink strip; removing the strip was easy with battery connected and the chance of touching adhesive while fiddling with the connector was reduced.
    Bob McNally - Réponse
  8. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 8, image 1 de 2 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 8, image 2 de 2
    • Une fois que la batterie adhère, vous ne pouvez ni la repositionner ni l'enlever sans détruire les bandes adhésives et devoir recommencer à zéro.
    • Positionnez soigneusement la batterie et posez-la dans l'iPhone.
    • Laissez un léger espace (d'environ 2 mm) entre le bord inférieur de la batterie et du haut-parleur. Vous pourrez plus facilement replier la languette noire tout à l'heure.
    Be sure to set the battery closely towards to top of the phone to leave space to fold the black tap of the adhesive tape at the bottom.
    Christian Jensen - Réponse
    ***** ALERT This is a non obvious failure point. If the battery is too close to the right (lower) end in picture, you can’t fold the black Tab down which is two steps further down. This should be in the main instruction, not as a note. Mine is too close to the home button connector socket, I will try folding the black tab over battery. Report to follow
    Thank you both for your comments; I’ve added your tips to the instructions. That said, when photographing this guide, I installed the battery pretty much bang up against the speaker, and was still able to fold the tab down—it just took a little patience. So, don’t anybody panic if you installed your battery a little too far down! You can still complete the repair.
    Jeff Suovanen - Réponse
    Report on previous ALERT comment…I successfully completed the battery installation and closed up the phone with the black tab lying over the battery rather than tucked down and into the space between the end of the battery and the other components. The case closed up ok, and the end screws went in successfully ( I had to squeeze the case closed to get the screws at the end to line up with the holes on the little tabs inside.
  9. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 9, image 1 de 2 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 9, image 2 de 2
    • Appuyez fermement sur la batterie pour qu'elle adhère bien.
  10. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 10, image 1 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 10, image 2 de 3 Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 10, image 3 de 3
    • Prenez l'extrémité plate de votre spatule ou une pincette émoussée pour replier la languette noire vers le bas et l'insérer entre le bord inférieur de la batterie et les composants qui se trouvent en bas de l'iPhone.
    • Faites extrêmement attention à ne pas perforer la batterie avec un outil pointu au cours de cette étape. Une batterie lithium-ion accidentellement percée peut déclencher un dangereux incendie.
    This is literally impossible. My battery pack had to be all the way down and the plug piece was still too high and I could barely connect it. There’s no room for the tab to go.
    Beth Devine - Réponse
    Attatch the adhesive strips to the battery first, putting the black tabs over the front edge and sticking them down then peel the backing off-that's the Top done. Then fold the strips under the battery and allow the strips to adhere underneath on the back of the battery. Remove the backing from the strips underneath that are stuck to the bottom of the phone , plug in new Battery and carefully seat the battery down on to the rear phone case. Be careful, you will only get ONE go at this per set of strips. It is always worth an extra Buck for 2 sets of strips in case you make a mistake.
    mavernon - Réponse
  11. Remplacement des bandes adhésives fixant la batterie d'un iPhone 5s, 5c ou SE: étape 11, image 1 de 1
    • Veillez à de nouveau déconnecter la batterie avant de remonter votre iPhone.
    • Travailler sur votre téléphone quand la batterie est connectée peut détruire des composants fragiles.
    No fault of the author(good job credit coming your way), but my adhesive strips were a bear to install. My tabs were two separate as opposed to one long tab. Of course, I messed them up by letting one of the aforementioned tabs touch the adhesive strip. I had to use some double sided tape to finish the install. At least my iPhone 5S is working!
    Chris Courtney - Réponse
    Geschafft aber man braucht sehr viel Fingerspitzengefühl,insbesondere beim Aufstecken der Kontakte !
    Danke für die Hilfe !
    Thilo Klamroth - Réponse
    You may want to rephrase step 11. If I disconnect the battery before reassembly, I'm pretty sure the phone won't work.
    Rossiter Livingstone - Réponse
Pour réassembler votre iPhone, retournez au tutoriel utilisé pour retirer la batterie et suivez-en les instructions en sens inverse.
Pensez à apporter votre ancienne batterie dans un centre agréé de récupération des déchets.
238 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
93%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jeff Suovanen
Membre depuis le 08/06/13
427 889 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 734 tutoriels rédigés
4 commentaires
Call me crazy, but can’t I just use a thin strip of blu-tack?
domarius - Réponse
Maybe, but the adhesive strips are designed to be very strong and very thin, and reasonably heat-resistant. This keeps the battery secure even if you shake the phone (or take it jogging), and it won’t come loose if the phone gets hot. The thin profile also means the battery has room to expand slightly without contacting or putting pressure on the display. Considering how cheap the strips are vs. the cost of the expensive phone you are repairing, I tend to err in favor of putting it back together the way it’s designed. But, your phone, your choice!
Jeff Suovanen -
All worked well except removing one of the adhesive strips. I used a “Bed Buddy” microwavable heat pack to warm the phone as directed and it worked fine. So far I’m pleased. Now comes the re-assembly challenge.
Curtis Potter - Réponse
Use this iFixit video guide for applying the adhesive instead IMO—many people will tell you to apply it to the battery itself instead of the bottom of the case:
https://www.youtube.com/watch?v=Xthi6DOx...
At least you have options now. :)
Ze Bra - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 52
30 derniers jours : 221
Total : 65,255
