Introduction
Dans ce tutoriel, vous allez apprendre à remplacer le vibreur situé dans chaque gâchette de votre manette. Cette tâche requiert un démontage complet de votre manette.
Ce dont vous avez besoin
Saisissez fermement la manette pour démonter les poignées latérales. Introduisez une spatule dans la jointure des coques frontale et des poignées.
Faites levier pour soulever et éloignez la coque latérale de la coque frontale avec un mouvement de va-et-vient. Faites ceci tout le long de la jointure de la coque latérale.
One you take it off, is it possible to click it back in?
As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
Brandon -
I don’t have a squdger
getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
Dont think ill be doing this in the future
edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
Avec un tournevis, faites un trou exactement au milieu du label.
Dévissez les 5 vis de 10 mm à l'arrière de la manette avec un tournevis Security Torx T8.
It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
The T8 is only good for the middle screw on my One S controller. The others require something bigger
These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
The driver that iFixIt sells is cannulated.
where do you get this dumb ass screw driver
You can bypass it with a 1.5mm flathead.
thank you for this. worked for me
TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
Dessoudez les joints soudés tout en maintenant les fils noir et rouge contre le haut de la carte mère.
Dessoudez les fils noir et gris fixés à la partie supérieure de la carte mère.
Retirez les moteurs vibreurs et mettez-les de côté.
Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
If you have a soldering station around i would still recommend using it.
Dévissez les 2 vis T6 de 7 mm situées près des emplacements des moteurs vibreurs.
Are these just T6 screws or Torx security T6 that is cannulated?
The outer screws are security screws. The ones on the system boards are Torx.
Rongwey -
Tenez fermement les côtés de la carte mère à mi-longueur.
Soulevez-la tout en la faisant légèrement osciller d'avant en arrière.
Retirez le ruban adhésif jaune maintenant les fils en place sur le devant de la manette.
Pour réassembler votre manette, suivez ces instructions dans l'ordre inverse.
19 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
10 commentaires
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
My right trigger won't work on gta 5 and on other games it works
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow -
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Do you know how to remove the plastic plate where the trigger rumble sits?
Could you not just pull the wires?
How do you place the wires back onto the trigger rumble?
Where would one buy the replacement trigger motors?
can this guide be reworked to add rumble feature to the powera fusion controller for nintendo switch?
