Aller au contenu principal
Remplacement du LCD du Nokia 3310
  1. Remplacement du LCD du Nokia 3310, LCD: étape 1, image 1 de 1
    • En premier lieu, retirez le boitier arrière.
  2. Remplacement du LCD du Nokia 3310: étape 2, image 1 de 1
    • Ensuite retirez le boitier avant et le clavier.
  3. Remplacement du LCD du Nokia 3310: étape 3, image 1 de 1
    • Enlevez ensuite le boitier en métal.
  4. Remplacement du LCD du Nokia 3310: étape 4, image 1 de 1
    • Enlevez le LCD
  5. Remplacement du LCD du Nokia 3310: étape 5, image 1 de 1
    • Une fois que vous avez installé un nouveau LCD, remontez le tout en suivant le tuto en sens inverse.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
9 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Tay
Membre depuis le 11/17/16
304 Réputation
1 tutoriel rédigé
4 commentaires de tutoriel
One thing the nokia 3310 is supposed to be the one phone that cannot be broken how did you even break the screen
Max - Réponse
how?????????
Lee Hunt -
if you look at the screeen, you will notice that it isnt cracked or broken or anything like that. it is very evident that the author OR user has deliberately kept the screen near a lighter or flame and fire-damaged it. The reasons for this are extremely self-explanatory. Their parents(if they are a minor) do not permit them to buy a new phone until their current one gives up, and considering this restriction i can assume that their parents themselves bought the 3310 for their child in a strategic move, strategic because, THE 3310 SIMPLY NEVER GIVES UP! Now, they(the author) are fed up of playing snake on the Nokia, and want to play something else. So they tried to destroy the 3310, and came to the point of burning the screen. There is one more reason i can think of. The author must've been budget conscious and they must've thought, "until this thing gives up I AINT BUYING A NEW PHONE!" and they regretted their life choices after this. I hope this helps you in your quest to understand how the screen broke! 😜
ronik103 -
Ez a jelenség lehet hogy nem emberi hiba lehet hanem emberi felelőtlenség mert sokáig volt a napon a uv sugárzás kikezdi a képernyő mögötti foliát ami így leválik olyasmi mint a embereknél a hámlás ha sokat vannak a napon vagyis egyszóval környezeti ártalomnak lett kitéve! 😉👍
KNIGHT RIDER - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 18
30 derniers jours : 83
Total : 7,028
