Introduction
Afin de retirer l'écran de la tablette, il est nécessaire de retirer la batterie et la carte mère.
Ce dont vous avez besoin
Utilisez un outil d’ouverture en plastique pour ouvrir le capot arrière de la tablette.
La deuxième image montre la tablette avec le dos enlevé.
Retirez les vis suivantes à l'aide du foret Phillips 000.
Onze vis de 4 mm
Pour remonter votre appareil, suivez ces instructions dans l’ordre inverse.
17 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
6 commentaires
how did you keep the digitizer intact?my problem is the lcd screen and I bought only that.too scared to start without knowing how to keep the digitizer intact as it would take weeks before I could replace it.also wondering how to replace the lcd and only that.could you help me please?
Hans Sorensen ,Norway
In my personal opinion, this guide have a bunch of steps that aren't necessary. I just replaced a cracked one. And I just removed the battery for security purposes since I was going to use heat. But you don't have to remove the mother board or anything else, just disconnect the digitizer flex and then start prying on front. That's it.
https://youtu.be/etxKSTK3Gno?t=8m19s
Is that black tape important? I wasn't lucky and it was torn.
How do you calibrate the digitizer afterwards?
Step 11 talks about using a Phillips 000 drill bit, rather than screwdriver, to remove the screws.
