Introduction
L'Asus Eee PC 900 utilise un petit lecteur à semi-conducteurs au lieu d'un plus grand disque dur. Utilisez ce guide pour remplacer le SSD dans l'Asus Eee PC 900.
Ce dont vous avez besoin
Faites glisser les loquets de verrouillage de la batterie en position déverrouillées.
Le loquet droit est déverrouillé lorsqu'un point rouge est visible.
Le loquet gauche doit être maintenu en position déverrouillée afin de permettre de retirer la batterie.
Faites glisser la batterie tout en maintenant le loquet de verrouillage gauche en position déverrouillée.
a (minor good, as liion batteries tend to degrade, esp in alltimeuse in bay: warm, max voltage=minimumlifespan) solution is:
try to revive the no more recognized one! first!!
either at the poles: need three connections: two at the ends, one in the middle like 1(+ -)-2-(+-)3
(need a hole through the casing/housing… (each of the two packs must be over 3.0volts: you can easily put a good charged liion from outside for a few moments to get a bit charge in to rise each pack over the 3.0 threshold that prevents pack of being recocknized as ok…)
or need a bridge at the connector to see realbatterypackvoltage there… check it out
good luck, thomas@biopilze.de
addendum:
if too old, too long lying at voltages under 3v… well possible that the liions wont keep the voltage, then at least one of two packs: (each two parallel 18650 liions) are gone -in that case you could try to dissassemble casing and replace a /or both pack/s, but is rather difficult: housing is a: well glued, try to open with sharpe knive but take extreme care not to destroy or short sircuit internals!!!!!! and b: is brittle and not much space for adding solder etc… -alltogether a thorny way…
you could just add external batteries at these poles, too… -if the originalones have just a high impedence/resistance, but do NOT leak (low impedence/resistance), otherwise constant energy-loss + heating… : problem: eeepc checks voltage-drift and regulates power-up/booster… if you added to much more voltage , as a flyby addendum: it rekocknizeses overload and shuts down imediately: so try to add batteries with similar voltage, possibly via a smal resisor first that buffers drain… give feedback to me please!
>>…or need a bridge at the connector to see realbatterypackvoltage there… check it out
the connector has generally spoken: plus, minus, switch, thermal-control… some: ie2, too…
did that for a eeeepc900, external charge just at the connector, worked fine, now got eeepc900a, is different: one pin less, have to find out myself first… today did no more find any schematics in the web yet -any suggestions folks?
Retirez le petit autocollant sur le côté droit du couvercle du compartiment SSD / RAM.
Retirez les deux vis cruciforme #0 de 4,76 mm fixant le couvercle du compartiment SSD / RAM.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
7 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Brendan nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
what kind of adapter you use? My ssd died….
