Introduction
Lorsque le nettoyage du filtre HEPA n'améliore pas l'aspiration de votre aspirateur, il est temps de le remplacer.
Sur le devant de l'aspirateur, localisez le loquet au bas de l'évent avant.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
4 commentaires de tutoriel
the taking out worked great but putting the new one back in is impossible.......will not fit i will not buy a new vac because of this........
this is the second filter that i have purchased and it is the same...does not fit properly i could use a hammer to it?????
I can’t get the Hepa filter to come out, the front comes out easily, but the actual filter behind it will not. How do I remove it?
@lynndavidson lay the machine on its back, get someone without fingernails to grab both sides of HEPA and pull STRAIGHT UP. It is pretty tight. You might be able to pop a side up by prying with a flat screw driver or small putty knife? Just don’t chip the housing.
