Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplacement du haut-parleur de l'iPhone 6s Plus
Ce dont vous avez besoin
  1. Remplacement du haut-parleur de l'iPhone 6s Plus, Vis Pentalobe: étape 1, image 1 de 1
    • Avant de démonter votre iPhone, déchargez-le en dessous de 25 %. Une batterie lithium-ion chargée perforée accidentellement peut prendre feu et/ou exploser.
    • Éteignez votre iPhone avant de commencer le démontage.
    • Enlevez les deux vis Pentalobe de 3,4 mm de chaque côté du connecteur Lightning.
    Make sure you use the correct screw driver tip to remove these screws, which for the iPhone 6s Plus is the P2, otherwise you may strip the tip of the screw making it 10 times harder to remove. If once the screw is lose, it will not come off, use a magnet to remove it.
    Miguel Perez - Réponse
    If I do it by myself, will it damage the water resistant strip?
    I know iphone 7 have it ,but I am not sure 6s plus have it.
    Ganqian Zhu - Réponse
    iPhone 6s has an adhesive gasket under the display, similar to the iPhone 7—however, it doesn’t add much in the way of waterproofing since the 6s has non-sealed openings in other parts of the phone. Water resistance on the 6s is primarily internal (seals around the logic board connectors, etc.). It may still be worthwhile to replace the adhesive on the 6s in order to help keep the display firmly seated so it doesn’t move/wobble at all under pressure, but the phone will continue to work fine whether you replace the adhesive or not.
    Jeff Suovanen -
    Salve nella procedura iniziale di smontaggio display con la ventosa non è menzionato il fatto di scaldare i lati del display per “ammorbidire” la striscia che incolla il display alla scocca.
    Non è necessaria la cosa o è consigliabile ?
    grazie
    Hello, in the initial disassembling procedure with the suction cup, it is not mentioned how to heat the sides of the display to "soften" the strip that glues the display to the body.
    Is not the thing necessary or is it advisable?
    thank you
    Daniele - Réponse
    You’ve probably received your answer by now but for future enquirers, it does help the process of taking the screen off if heat is applied to the screen. If you have a hair Dryer use that on a low setting to heat the edges of the screen until it’s almost too hot to touch then slip very thin metal spudger around the edge to cut the adhesive. The carefully lift the screen with the help of the spudger and continue with your repair
    Cheers Wayne
    Wayne Lyell -
    How do I know that the Battery has ZERO Charging Cycles on it when it arrives ? Is there a (downside) to Higher Capacity batteries ? It is INCREDIBLY DIFFICULT to maintain a “Zero Chinese Products Lifestyle”, so how do I know that I’m not getting a deficient Chinese battery, potentially a refurb. battery ?
    integritybuilders - Réponse
    When your repair is complete, you can use coconutBattery to check your new battery stats and cycle count. (A properly tested battery may already have a charge cycle or two on it.) Avoid higher capacity batteries on iPhones—they’re generally either gimmicks, unsafe, or both. As far as the quality of the part, that comes down to how much you trust your supplier and whether they guarantee the product.
    Jeff Suovanen -
    So I need to empty the battery to zero percent?
    johnpatrickanat - Réponse
    Below 25%, exactly as stated in the instructions. There’s no benefit to draining it further than that, and in fact you’ll slightly shorten the service life of the battery by draining it all the way to zero. Follow the instructions exactly as written—if you go off-script, you’re a lot more likely to break something.
    Jeff Suovanen -
    So my screen shattered completely and the screen first had colored lines on tge while right side then it went out completely. If i get an lcd and digitizer replacement I'd that oing to fix it
    shellietheleo - Réponse
    I would initially recommend a well-lit, comfortable area and placing the screws on a white piece of paper with the screw sizes written down (apparently there are magnetic mats, also). Also, I found placing the phone on a paper towel is good so that if a screw is dropped, it will lessen the likelihood of bouncing away.
    Lou Fazio - Réponse
    I recommend that, before you even lift a screwdriver or plug in the hair dryer, get a piece of paper and a pencil. As you unscrew and remove the parts, write the size and/or number for that step and put them by their label. I also used a microscope to identify the screw heads (I'm 75 and my vision is not what it used to be). Laying them out in order, I just went backwards when putting them all back in. I used an anti-static cleaning cloth instead of paper, but I should think they both will work.
    N.B.: my kit had a nice pretty blue plastic sheet with a black outline on it. It was only when I put the whole phone back together and was packing up the supplies and tools that I realized it was a replacement gummi seal. A LABEL WOULD BE VERY USEFUL HERE!
    I am a retired engineer, and aside from the size of the bits and bobs, it was a piece of cake! Thanks...you saved me $75!
    P. Roberts - Réponse
  2. Remplacement du haut-parleur de l'iPhone 6s Plus, Procédure d'ouverture: étape 2, image 1 de 1
    • Vous pouvez également chauffer le bord inférieur de l'iPhone pendant une minute à l'aide d'un iOpener ou d'un sèche-cheveux.
    • La chaleur permet de ramollir la colle qui fixe l'écran ce qui facilite l'ouverture.
    This is important. I’ve serviced a lot of iphones/ipads for my family as a hobby in the past.
    The adhesive was so tight, I cracked the screen trying to pull it/pry it off.
    I highly suggest heating at least the bottom edge enough to soften the adhesive
    garbage911garbage - Réponse
    I didn’t have an iOpener, nor a heat gun; however I do have a small personal size hand pillow filled with feed corn. Two minutes in the nuke machine got it plenty warm, and smelled like fresh popcorn too.
    bradiac - Réponse
    I would suggest that you are not shy with the hairdryer. A high heat on the bottom of the phone for at least a minute, if not more, if required.
    Mark Taberham - Réponse
  3. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 3, image 1 de 1
    • L'écran du iPhone 6s Plus dispose d'une fine bande adhésive tout autour de son périmètre. Si vous préférez le remplacer, prévoyez un nouveau set de bandes adhésives avant de continuer. Il est possible de finaliser la réparation sans remplacer la bande adhésive, et vous ne remarquerez probablement aucune différence au niveau de la fonctionnalité.
    • Fixez une ventouse en bas à gauche sur la vitre.
    • Si votre écran est méchamment fissuré, vous pouvez le recouvrir avec du ruban adhésif pour mieux faire adhérer la ventouse. Du ruban adhésif très solide peut être utilisé à la place de la ventouse. Si toutes les autres méthodes échouent, vous pouvez utiliser de la super glue pour coller la ventouse à l'écran cassé.
    take out screws first!!
    Yoav Karmon - Réponse
    Make sure you use the right screw driver tip for i phone 6s Plus, which is the P-2. If the screw will not come off once is lose, try using a magnet.
    My cracked screen prevented the suction cup from sealing. SOLUTION: With a piece of clear packing tape across the screen, the suction cup will seal and pull.
    Jim Cowles - Réponse
    I broke my iphone screen in the first step!
    Pierre Bertram - Réponse
    This screen removal step got more wrestley than I anticipated. The adhesive is quite strong. I used a flat-ended razor tool that I have to begin the prying - I don’t know how I would have got it started without this.
    Lou Fazio - Réponse
    Ok - just got my battery replacement kit and even got the opening kit for added insurance just in case. Settled down to startwork after carefully cleaning my (immaculate) screen - no scratches or anything, with rubbing alcohol, removing screws and warming with a hair dryer, only to find the suction cup provided in the kit is worse than useless! It won’t stick to the screen well at all. When it does - it pops off at the lightest pull :-( Now what do I do to get this started?!
    CoffeeCup - Réponse
  4. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 4, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 4, image 2 de 2
    • Soulevez la ventouse de façon ferme et constante pour créer un petit interstice entre l'écran et le boîtier arrière.
    • Ne tirez pas trop fort sur la ventouse, vous risqueriez d'endommager l'écran. Soulevez juste assez pour créer un petit interstice entre l'écran et le boîtier arrière.
    I had a shattered front glass panel so I could not get the suction cup to seal properly. I tried a couple of different ways to get good suction but to no avail. I eventually used a Stanley knife to pry up the corner so I could get the spudger into the opening.
    John Architzel - Réponse
    A really high quality packing tape over the entire screen will usually be enough to use the suction cup on a shattered screen.
    djwooten -
    I used a suction cup on each side to provide counter traction. I braced the iphone between my knees and pulled apart while my helper inserted the spudger
    jkanne - Réponse
    This was by FAR the most difficult part of this whole thing. I confess the spudger was not cutting it so I used a butter knife to get into the small opening first, then used the spudger to go around the screen.
    Julie Sanchez - Réponse
    Hey everyone, if you never have done this part before be aware there is an extremely strong adhesive around the lip of the screen and once again is extremely strong. I had to get a friend to insert the pry/pick into the small gap while I used one hand to brace the phone down and the other to pull the suction cup without it digging into my hand. Go slow, it took me 5 tries because I didn’t realize how strong the adhesive was.
    bartmistrot - Réponse
    I also had a badly cracked lower screen - that glass was actually threatening to pull off the phone in chunks during this step, even with packing tape. Resorted to @j2arch’s tip and inserted a utility knife vertically into the seam between the display and phone body. Was able to lever the glass enough to get the spudger in there.
    Jason Augustyn - Réponse
    I have replaced sevrel screens for my sister in law and my niece. The packing tape has worked every time and that’s with it Shattered and pieces already falling out. You have to make sure the packing tape goes to the edge of the screen but doesn’t touch the frame. I have the plier like screen remover and use that it is much easier to remove the screen by your self with that tool. I also have the little finger suction cup that comes with the kit here. I bought the plier suction cup tool When I had to replace the screen that had the pieces of the screen missing and I don’t regret spending the extra money for that it has made a world of difference. I do this as a hobby it’s not a job for me. The electric divide repair kit from Lowe’s is also a very good kit to help. If you’re only going to do it once the kit that comes with the package is a great deal from ifixit. Well worth the money to spend the little extra to get the kit if you all ready don’t have the tools.
    Brent - Réponse
    If you try to use the spunger near the home button and try to pry it can crack your screen. This happened to me.
    Jeffrey - Réponse
    Same thing happened to me. This should be a big warning in these steps. If you have a small to moderate crack in you screen, but you weren’t planning on replacing the screen at the same time as another repair inside, there’s a risk of damaging the screen further and making it inoperable.
    DW7ACCT -
    I found it easiest to use two suction cups. One on the front as directed, and a second one on the back. Give the spudger to your assistant, and have them slip it in place while you pull the display from the case.
    gordojenkins - Réponse
    I gave up with the suction cup as it wasn't working for me with a cracked screen. Having heated the bottom of the phone with a hair dryer with a high heat for a good minute or so, I used a safety scraper (essentially a razor blade in a holder) along the bottom of the phone to separate the screen from the body of the phone. I used the scraper vertically between the bottom of the screen and the phone body and levered it sufficiently so that I could fit the spudger between the screen and the phone body. My experience when I first used the spudger around the frame was that the cracks in the screen caused the screen glass to separate from the frame, so I had to re-do it and ensure that the screen frame was separated from the phone body.
    Safety scraper:
    https://www.amazon.co.uk/Unger-CD170-Win...
  5. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 5, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 5, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 5, image 3 de 3
    • Le meilleur endroit pour faire levier est l'encoche dans l'écran située au-dessus de la prise casque.
    • Tout en tenant la ventouse, insérez l'extrémité plate d'une spatule (spudger) dans l'encoche directement au-dessus de la prise casque.
    This was by far the hardest part of the repair for me. Getting leverage while finding a way to prod with a spudger is a challenge in coordination. I used a second spudger with point holding the phone down by the headphone jack, with the other end of the spudger anchored to my desk.
    drpotter - Réponse
    When warmed, the suction cup was useless. Using the tip of a knife blade, was able to get it separated enough to insert spudger.
    hutland - Réponse
    For me this was the most time consuming task. I used a hair dryer for heating. I found a very tight adhesive. For a moment I thought of abandoning my efforts and take the assembly to a professional repairman. But as they say, patience is a virtue.
    After fiddling for about 20 minutes, I achieved a barely noticable opening. So I decided to change the strategy. Instead of applying heat all over the base, I preceeded with small steps with heat concentrated near the opening. I applied intense heat only for about 15 to 20 seconds and immediately working with spudger. It took about an hour to completely open the case. It worked.
    Thanks for reading.
    - Mr Gamma
    Gamma Pailvan - Réponse
    I also struggled with this step. Lots of heat, 3 different suction cups, I finally could see a small gap... much too thin to fit even a piece of paper into. A video on another site said it was the easy way. I used a sharp craft knife barely into the seam between metal and glass and pried slightly. And it started up. Still a pain freeing the rest of the adhesive. Perhaps the adhesive really sets up over the course of 5 years? I have it hinged open now, so onto the next steps.
    Mark Tollefson - Réponse
  6. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 6, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 6, image 2 de 2
    • Agrandissez l'interstice entre l'écran et le boîtier arrière en tournant la spatule.
    just changed the screen, but due to the tape along side the screen , it is best to heat a little so the glue losses and you can get the screen off better, like indicated
    Bart Blanckaert - Réponse
  7. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 7, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 7, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 7, image 3 de 3
    • Tirez fermement la ventouse vers le haut et faites glisser la spatule sous le bord du coin gauche de l'écran.
  8. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 8, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 8, image 2 de 2
    • Faites glisser la pointe de la spatule le long du côté gauche entre l'écran et le boîtier arrière.
  9. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 9, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 9, image 2 de 2
    • Insérer l'extrémité plate de la spatule sous le côté droit de l'écran.
    • Faites glisser la spatule le long du bord droit.
  10. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 10, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 10, image 2 de 2
    • Utilisez un outil en plastique pour tenir le boîtier arrière pendant que vous tirez sur la ventouse pour ouvrir le téléphone.
    • Ne retirez pas complètement l'écran, sinon vous endommageriez les nappes de connexion placées près du bord supérieur de l'iPhone.
  11. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 11, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 11, image 2 de 2
    • Tirez sur le petit bouton en plastique sur la ventouse et enlevez-la de l'écran.
    Remember to apply the screen gasket on the re-assemble. The gasket is provided in the kit but not mentioned here on the instructions.
    Won Hong - Réponse
    There’s a link to the entire gasket replacement procedure in Step 21.
    Jeff Suovanen -
  12. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 12, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 12, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 12, image 3 de 3
    • Saisissez délicatement l'écran et soulevez-le pour ouvrir le téléphone, en vous servant des clips en haut du panneau frontal comme charnière.
    • Pendant les étapes suivantes, adossez l'écran à un objet afin de maintenir un angle de 90° par rapport au boîtier.
    • Evitez d'ouvrir l'écran à un angle de plus de 90° - il est toujours relié au téléphone par les nappes de l'écran, de la vitre tactile et de la caméra frontale, qui peuvent se déchirer facilement.
    • Utilisez un élastique pour garder l'écran fermement en place pendant la réparation. Cela va empêcher une pression excessive sur les câbles de l'écran.
    • À la limite, vous pouvez utiliser une cannette de boisson fermée pour tenir l'écran.
    if the display cables are damaged how can you tell ?
    Smiley McSmilebot - Réponse
    In theory, I like the idea of propping up the screen with a rubber band and box/soda can like this, but after ripping the FaceTime camera cable twice, I realize that this method puts too much stress on the cable because it places the screen so far back. Even in this photo, you can see that the cable is taut. I’d recommend just holding the screen with your free hand to put the least amount of stress on that cable as possible.
    Ben Estabrook - Réponse
  13. Remplacement du haut-parleur de l'iPhone 6s Plus, Connecteur de batterie: étape 13, image 1 de 1
    • Enlevez les deux vis cruciformes qui attachent le cache du connecteur de batterie à la carte mère :
    • Une vis de 2,9 mm
    • Une vis de 2,3 mm
    • Tout au long du tutoriel, gardez soigneusement la trace de vos vis afin de revisser chacune d'entre elles là où elle était avant. Revisser une vis au mauvais endroit peut causer des dommages irréversibles.
    FYI - I used some blue painters tape wrapped around a piece of cardboard to hold the screws and brackets in place, in order, so they did not get lost. Some of those screws are MICROSCOPIC so be careful!
    I also suggest having very good lighting, even a camping headlight for hands-free well lit work space. You will thank me later :-)
    Use the bit labeled “PH000”.
    Joe Teichert - Réponse
    PH000 bit just wants to free-spin in the 2.3 mm screw. no bite in the head at all. had no difficulty removing the 2.9 mm screw with the same Phillips. had to abandon battery replacement effort.
    Benjamin Stalcup - Réponse
    For this part, neither PH000 or Y000 worked. Technically, it’ll set you back 31$ because you will need the PH00 screwdriver for this part, and the part where you need to open the screen. They have ph00 screwdrivers in every hardware store and even ifixit.com. just know that they put the wrong screwheads for you
    Jack Daniel - Réponse
    Do not lose track of which hole these screws go into. They MUST be put back into the correct hole that they came out of. If not, you will get the dreaded “long screw damage” on the mainboard, and that will be the end of the show.
    Just remember where these screws go, and it will be fine.
    Harry McDow - Réponse
    Ended up employing a Philips #0 from a regular jeweler/precision kit on the 2.3mm screw. Bits seem a bit off for this step.
    Vance Bell - Réponse
  14. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 14, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 14, image 2 de 2
    • Retirez le cache de connecteur de batterie.
    Does it matter if the brackets arent put back in the phone? I bought a used phone and brackets are missing. Thanks!
    Coupon Crazy - Réponse
    Auch die Abdeckung ist angeklebt. Also mit etwas Vorsicht und Geduld rangehen.
    eckhardd@icloud.com - Réponse
    If you have forgotten your High School German -
    The cover is also glued. So take some care and patience.
    Glen Paetz -
    My bracket actually has a black wire connected on the underside that is attached to the metal bracket (with screw) below it in the picture. I decided to leave it on and just move it to the side.
    Victor Ng-Thow-Hing - Réponse
  15. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 15, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 15, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 15, image 3 de 3
    • Utilisez une spatule (spudger) ou un ongle propre pour déconnecter le connecteur de batterie de la carte mère en le soulevant tout droit vers le haut.
  16. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 16, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 16, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 16, image 3 de 3
    • Repliez le connecteur pour éviter un contact qui pourrait rallumer votre iPhone pendant que vous travaillez dessus.
    When putting the new battery in, make sure to line up the plug and not to the top of the battery… our battery was smaller so the plug would NOT have lined up if we used the top of the battery. ALSO, the plug was NOT 90 degrees so we had to finagle the plug. Also, make sure there is a clear CLICK when you plug in the connector or it may not work. Ours went in but guess didn’t go far enough so we had to take the screen off and push it harder until we heard the “click” then it worked fine.
    Won Hong - Réponse
    There was some black goop/glue around the battery connector, and when I lifted the old connector, some of that glue fell into the receptacle. It was easy to fish out (with magnifying glass and tweezers) but if you don't catch it, you may not get a good connection.
    Steerpike - Réponse
  17. Remplacement du haut-parleur de l'iPhone 6s Plus, Ecran: étape 17, image 1 de 1
    • Enlevez les vis Phillips suivantes :
    • Trois vis de 1,3 mm
    • Une vis de 1,6 mm
    • Une vis de 3,0 mm
    • Lors du remontage, il est très important de mettre la vis de 3,0 mm dans le coin en haut à droite du cache. Si elle est placée à un autre endroit, elle risque d'endommager la carte mère.
    I really don't see value in removing screen use box and rubber band keep at 90 degrees.
    John Parker - Réponse
    I leave screen on as well for this. - Tho I prefer a 45 degree lean.
    Thor -
    I just changed my battery and also left the screen attached. I was lucky enough to get all 3 adhesive battery strips out clean so I didn’t have a struggle with the battery coming out. If I was going to need to get rough with it I was going to take the screen off at that point.
    Michael Gross - Réponse
    To keep track of screws, draw a quick outline of the display cable bracket/cover, with five dots where screws should be. Drop the screws on the corresponding dot. Helps if you use magnet pad.
    Christa - Réponse
    Better yet, print out the pictures from the iFixit website, and use clear tape (“Scotch tape”) to TAPE the screws onto the place in the picture where they belong.
    Tom -
    Which screwdriver from the kit do I use for which screw?
    Shiva Sharma - Réponse
    I made a mistake and unscrewed the screw just north north west of the one circled in yellow. Of course I lost the screw. Can anyone give me any guidance about this? what does the wire connected to it do? What is the size of the screw, in case I have to replace it?
    P.S. This is another reason to consider the possibility of NOT removing the screen just to replace the battery: removing the screen presents a additional possible headache, especially for people like me with bad eyesight who probably shouldn’t be doing this in the first place.
    Tom - Réponse
    It is a 1.4 mm Phillips screw holding the NFC bracket in place.
    Larry Lynch -
    I didn’t think this was necessary, bit I see it relieves stress on the front-facing camera and sensor cable connector; I did not disconnect the display connector nor remove the display screen.
    Lou Fazio - Réponse
    I second this finding. I too did not remove the screws nor the bracket. The cables look a bit stretched, but certainly not strained.
    -Gamma
    Gamma Pailvan -
    This step of separating the two parts of the phone deserves careful consideration. In my case, I had propped up the display assembly with a box and rubber bands. However, only 2 of the battery adhesive strips came off easily. The effort to remove the battery with the display assembly attached was not a good move on my part. I jarred the ear speaker cable and after reassembly I had no camera or working ear speaker. Taking off these 5 screws and removing the three cables is not difficult. My suggestion: is you have ANY trouble removing the 3 battery adhesive strips, STOP, separate the two components, and then continue with the battery removal. Don’t struggle removing the battery with the display assembly attached. (I replaced the ear speaker cable, and all is working now)
    Richard Perl - Réponse
    Thanks for this tip! I am having a really hard time removing this plate because one of the screw heads are stripped. So I’ll try removing the battery adhesive strips first to see if I can get the battery out without removing the screen.
    nathanfunk -
    Use dixie cups and label them for each part you take out. You can stack the dixie cups to keep them in order.
    Bradley Nolen - Réponse
    I skipped this for the battery removal, but when I went to replace the seal, I had to remove it anyway.
    dgol69 - Réponse
    I lost the bottom left screw of the five in this step - anyone know if it’sgoing to cause a problem? ‘m going to go ahead and put thephone back together anyway - wil report back withresult
    CoffeeCup - Réponse
    OMG…. SO excited! It works! Seems that missing screw wasn’t an issue. The reason I’m so excited is, I’m a senior and have bever attempted anything like this before and was worried I’d mess it up, or it just wouuldn’t work for whatever reason. I know I never would have tried if it weren’t for finding this site, the great service, parts to do it and the videos/guides. Thank you so much ifixit. :-)
    CoffeeCup - Réponse
    I changed the battery, without removing the screen, when I closed the phone the front camera and speaker no longer work.
    Mr T - Réponse
  18. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 18, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 18, image 2 de 2
    • Retirez le cache de la nappe d'écran.
    Be careful on this step: with my iPhone, one of the connectors (the home button/fingerprint sensor) was stuck to the underside of the bracket and I almost strained its cable.
    kevin - Réponse
  19. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 19, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 19, image 2 de 2
    • Veillez à ne déconnecter que le connecteur et non pas la connection sur la carte mère.
    • Utilisez un outil en plastic pour déconnecter le connecteur de la caméra avant et de la nappe de capteur.
    FYI, in the video she uses the spudger for this but I think either one will work.
    I found prying from the right to be better
    Lou Fazio - Réponse
    Is there any need for this step if only the Battery is replaced
    mrrreid - Réponse
    I don’t recommend using the spudger for this as you can do more damage that way. I scratched the black square thing underneath.
    Laura Houghton - Réponse
    I managed to remove the battery without disconnecting and removing the display first. This avoids possible difficulties in these steps (see below).
    One has to be careful that, while fighting with the battery strips, the display remains in its 90º position
    alfasw33 - Réponse
  20. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 20, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 20, image 2 de 2
    • Utilisez un outil en plastique pour déconnecter le connecteur de la nappe de la vitre tactile de sa prise sur la carte mère.
    • En reconnectant la nappe de la vitre tactile, n'appuyez pas au milieu du connecteur. Appuyez d'un côté du connecteur, puis de l'autre. En appuyant au milieu, vous plieriez la pièce et risqueriez d'endommager la vitre tactile.
    Thanks you i fix it
    God Hand - Réponse
    “When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage. “
    The following note above was so helpful. I was speeding through the process of getting things back together, since it seemed easy to connect the digitizer cable, but I kept pushing it in the middle and I wouldn’t connect. Until I read through this step and realized it was easier if I would’ve connected one side and then the opposite side right after.
    Jeffrey Robinos - Réponse
    Don’t be too shy when pushing the ends of the digitizer connector back to place. If it does not connect properly, you might face the “half backlight” problem, even if you did not kill any LCD filter. Also check carefully, that you don’t clamp parts of the sticky sealing material placed around the connector inside the connection area.
    Norbert Andreas Richartz - Réponse
    This part was a very frustrating experience for me.  I thought that my replacement screen was just poor quality, as it worked when it wanted to work.  Pressing home/power repeatedly sometimes brought it back, charging to 100% also brought it back.    The actual problem was that it is very easy to get some of the gasket material caught in the connector, which I couldn’t see until I used my jeweler's loupe.  I used 91% alcohol to carefully clean all of this off until all pins were shiny, and it took about 6 tries to get it right.  However, the screen’s been running well for 2 days now.  I already bought another screen replacement which I have for a spare as it was 100% not the problem.
    chumblyf - Réponse
    I followed all the steps, so the sound is missed. What could be happened? thanks a lot. Fabio Balbino
    Fabio Balbino - Réponse
  21. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 21, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 21, image 2 de 2
    • Vérifiez que la batterie est déconnectée avant de déconnecter ou reconnecter la nappe de cette étape.
    • Déconnectez la nappe du bouton home/lecteur d'empreintes en le soulevant tout droit hors de sa prise sur la carte mère.
    How much is this to replace?
    Alistair knight - Réponse
    And where could I buy from?
    After finishing the assembly I got the message “Touch ID cannot be enabled on this phone”. I found this connector was loose. Plugged it back in and that fixed it.
    Bryan Province - Réponse
    Thanks for the tip. Same thing happened to me, some leftover adhesive was in the way!
    Sean - Lua Tech -
    Always make sure to disconnect the battery before you do any work on the phone replacing any parts the digitizer or anything. And before you start make sure the phone is turned off you don’t want any power surges. If you also have a static electricity bracelet that also is a plus to use but isn’t a necessity just a nice piece of mind. Some cases you do need to use one so you don’t discharge static electricity to an electrical component and mess it up.
    Brent - Réponse
    Be very careful in this step. I noticed it’s very easy to tear the flex when trying to lift it out of its socket from the right side.
    shoeib - Réponse
    What is the cable and how is it connected/fixed to the motherboard between the bottom socket and the screw hole.
    Mine came loose somehow?
    Jason Engelsman - Réponse
    I figured out my own question its the Wi-Fi diversity antenna cable. But how is it connected/secured to the motherboard?
    i pressed on the center of the digitizer connection. and the bottom half of my screen didnt work. i then took that same front panel assembly and tried to install it on another old iphone 6s+ and i had the same issue.
    can i still fix it?
    what exactly is broken now?
    alejandro rueda - Réponse
    @mynameisoli Honestly this just sounds like a defective screen to me, but it’s hard to say for sure. Look closely at the connector at the end of the ribbon cable and check it for damage. If it’s slightly bent/curved, all the pins won’t make good contact in the socket. You can try bending it back so it lays flat, but you have to be very careful not to damage the connector or contaminate the pins with skin oils, so it’s tricky—and it may be harder to return as “defective” if you mess up the connector. So try this at your own risk. Apart from that, I would just return it and try a different display. Good luck!
    Jeff Suovanen -
    The 6s plus screen repair kit i bought has the wrong size cable here on the replacement part. SOL.
    Alex Richardson - Réponse
    Once I accidentally disconnected the display assembly cables before disconnecting the battery. Now the home button and fingerprint sensor doesn’t work. Any solution to this?? I have tried a different home button, even that doesn’t work.
    a3roar - Réponse
    I changed the battery on my iPhone and put all together again and charged it. When I pressed the home button the lock screen with my picture appeared and when I pressed it again the screen with the digits from 0 to 9 appeared. I was asked to enter my passcode, but when I did that nothing happened, the phone did not open.
    What could be wrong? Is the home screen cable not fully connected or what could be the reason for this?
    THORDUR JOHANNESSON - Réponse
  22. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 22, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 22, image 2 de 2
    For instructions on home button swap out to the new screen you just installed, go here
    Remplacement du bouton home avec nappe de l'iPhone 6s Plus
    Superior Office Systems - Réponse
    Do you know whether the adhesive contributes to waterproofing, or just for stability/adhesion?
    Christa - Réponse
    @kitabel The iPhone 6s case isn’t waterproof, so I don’t think adhesive around the display is contributing anything other than stability. The 6s series does have some water resistance, but it’s mostly internal and not something Apple advertises.
    Jeff Suovanen -
    If you have a replacement adhesive for the display, you may need to install it before reconnecting cables to the components. If the adhesive wraps all the way around the display, it will be impossible to install it once the display is reconnected.
    Matthew Olwell - Réponse
    These instructions worked great for me. Thank you!
    Chris Enloe - Réponse
  23. Remplacement du haut-parleur de l'iPhone 6s Plus, Caméra iSight: étape 23, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus, Caméra iSight: étape 23, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus, Caméra iSight: étape 23, image 3 de 3
    • Décollez les bandes adhésives recouvrant les vis du support de la caméra iSight.
    If like me you are only wanting to clean out the speaker, you do not need to do this step. You can skip to step 50
    Brad “Bradster48” Mason - Réponse
    Mine had no tape there
    Gustavo Delfino - Réponse
  24. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 24, image 1 de 1
    • Dévissez les vis cruciformes suivantes du support de la caméra :
    • Une vis de 1,9 mm
    • Une vis de 2,4 mm
  25. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 25, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 25, image 2 de 2
    • Retirez le support de la caméra iSight.
    When replacing the bracket be sure to get the other end of the NFC bracket included with the right hand screw.
    Thomas Hayes - Réponse
  26. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 26, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 26, image 2 de 2
    • Déconnectez le connecteur du support de la caméra iSight de sa prise sur la carte mère.
    • Veillez à soulever seulement le connecteur et non la prise de la carte mère.
    If necessary, the sticky patch on top f the connector should be removed. Helped my case a lot :)
    Alexander Leuschner - Réponse
  27. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 27, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 27, image 2 de 2
    • Insérez l'extrémité plate d'une spatule (spudger) entre la caméra iSight et la coque arrière.
    • Soulevez délicatement la caméra hors de son emplacement.
  28. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 28, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 28, image 2 de 2
    • Retirez la caméra iSight.
    Hi ,
    Thanks a lot for your tutorial !
    Can you explain how can we change the lens of the camera ?
    Thanks ;)
    rocofolie - Réponse
  29. Remplacement du haut-parleur de l'iPhone 6s Plus, Tiroir de carte SIM: étape 29, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus, Tiroir de carte SIM: étape 29, image 2 de 2
    • Insérez un éjecteur de carte SIM dans le trou du tiroir de carte SIM.
    • Appuyez pour éjecter le tiroir de carte SIM.
  30. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 30, image 1 de 1
    • Retirez le tiroir de carte SIM.
    • Lorsque vous remettez le tiroir de carte SIM, veillez à l'orienter de façon à ce que le trou pour l'éjecteur de carte SIM soit en bas.
  31. Remplacement du haut-parleur de l'iPhone 6s Plus, Carte mère: étape 31, image 1 de 1
    • Dévissez l'unique vis cruciforme de 1,4 mm maintenant le support NFC.
    The silver end of the NFC bracket goes here. The gold floppy end goes under the camera bracket.
  32. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 32, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 32, image 2 de 2
    • Retirez le support NFC.
  33. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 33, image 1 de 1
    • Dévissez les deux vis cruciformes de 2,7 mm fixant le support de la nappe de contrôle audio à la carte mère.
  34. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 34, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 34, image 2 de 2
    • Retirez le support de la nappe de contrôle audio.
    Wo kommt den der “6 s Plus Bluetooth Flex” überhaubthin bitte ?
    Also "das = https://www.ebay.de/itm/123934065844
    Mystery Shopper - Réponse
  35. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 35, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 35, image 2 de 2
    • Déconnectez la nappe de contrôle audio en soulevant son connecteur tout droit au-dessus de sa prise sur la carte mère.
  36. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 36, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 36, image 2 de 2
    • Déconnectez la nappe de l'antenne cellulaire en soulevant son connecteur tout droit au dessus de sa prise sur la carte mère.
    how do you plug this cable back in? any tips for lining up with the socket? i can't get it to stay :(
    kapluni - Réponse
    Hold the cable with your tweezers and line the connector up over the socket as perfectly as you can, and then press straight down on it with the flat end of your spudger. Should snap into place with a bit of force.
    Jeff Suovanen -
    My problem when I pull the cable in the socket i shocked bot of them pull togeher the cable and the socket in the logic board the small circle i cry how to fix pleasss help mee
    Darrel Alan - Réponse
    The cable broke instead of coming out of the socket. Oh well. GG
    hiddenanddangerous2009 - Réponse
    My phone doesn't have a cable running here
    TJ Anderson - Réponse
  37. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 37, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 37, image 2 de 2
    • Déconnectez la nappe de l'antenne Wi-Fi diversity en soulevant son connecteur tout droit au dessus de sa prise sur la carte mère.
  38. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 38, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 38, image 2 de 2
    • Déconnectez la nappe du bouton marche de sa prise sur la carte mère.
    Don’t forget this guy when you’re putting it back in! you’ll have to undo a bunch of screws
    Cassandra Vil - Réponse
  39. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 39, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 39, image 2 de 2
    • Déconnectez de la carte mère le câble d'interconnexion.
    This is not a Lightning connector - its a radio connector.
    NorthernBigDummy - Réponse
  40. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 40, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 40, image 2 de 2
    • Avec l'extrémité plate d'une spatule (spudger), déconnectez de la carte mère la nappe du connecteur de charge Lightning.
    From here you can skip ahead to step 50.
    Mark Cousins - Réponse
  41. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 41, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 41, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 41, image 3 de 3
    • Dégagez le câble d'antenne des deux clips sur la droite de la carte mère.
    This is super vague. Doesn’t explain exactly HOW to remove the cable from the clips, like it does in step 44. Slightly damaged my cable because I didn’t know how to remove it or the nature of the clip.
    Mason Rogers - Réponse
  42. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 42, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 42, image 2 de 2
    • Dévissez les vis suivantes :
    • Une vis cruciforme de 1,3 mm
    • Une vis cruciforme de 2,6 mm
    • Une vis d'entretoise de 2,2 mm
    • Le mieux est de dévisser les vis d'entretoise à l'aide d'un embout pour vis d'entretoise et d'un manche du tournevis.
    • Un petit tournevis plat peut aussi faire l'affaire, mais veillez à ce qu'il ne glisse pas et n'endommage pas les composants qui se trouvent autour.
    Use can use a spudger in a pinch to dislodge the 2.2mm standoff screw. This was the most difficult screw in the phone. A Phillips bit will not work.
    mechamster - Réponse
    What do we call / name this bracket?
    B. Jansen - Réponse
  43. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 43, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 43, image 2 de 2
    • Retirez le support.
  44. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 44, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 44, image 2 de 2
    • Délogez le câble d'antenne supérieur du premier clip sur la carte mère en le poussant de sous le clip en direction de la batterie.
  45. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 45, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 45, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 45, image 3 de 3
    • Continuez à déloger le câble d'antenne cellulaire des deux clips suivants sur la carte mère.
    • Avec le bout pointu d'une spatule (spudger), faites délicatement levier sur le câble d'antenne cellulaire pour le retirer du clip au milieu de la carte mère.
    • Ne tirez pas sur le câble pour le retirer de ce clip, il se déchirerait facilement.
    • Pour que le câble atteigne sa prise sur la carte mère, faites-le passer au-dessus de la carte mère et sous la nappe de contrôle audio, comme indiqué sur la première photo.
    My clip in the middle is not removing no matter how hard i pry or what i do, any help??
    David Gray - Réponse
  46. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 46, image 1 de 1
    • Dévissez la dernière vis cruciforme de 2,0 mm juste au-dessous du lecteur de carte SIM.
  47. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 47, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 47, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 47, image 3 de 3
    • Soulevez délicatement – mais sans l'enlever – la carte mère en la saisissant par le bord inférieur le plus proche du connecteur Lightning.
  48. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 48, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 48, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 48, image 3 de 3
    • Soulevez la carte mère à la verticale de façon à voir l'unique connecteur d'antenne sur le dessous, à côté du bord supérieur de la carte.
    • N'essayez pas encore de retirer complètement la carte mère, car l'antenne Wi-Fi/Bluetooth est toujours connectée sur le dessous de la carte.
  49. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 49, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 49, image 2 de 2
    • Posez délicatement la carte mère à l'envers, la partie supérieure reposant sur le rebord de la coque arrière de l'iPhone.
    • Avec l'extrémité plate d'une spatule, déconnectez le câble de l'antenne Wi-Fi/Bluetooth de sa prise à l'arrière de la carte mère.
    Ugh, the socket connector separated from the back of the rigid cable. Two wires are still attached to the socket connector, but I’m guessing I’ll need to purchase a replacement WiFi/Bluetooth antenna cable at some point. I hope you sell these too?
    **Update** I used the tiniest drop of super glue with activator on both the connector and cable. It seems to be holding! Will reassemble and see if it works. Lucky for me, you sell the replacement cable for $14.99 if my cheap bastard fix fails :)
    **Update #2** Using super glue on the upper left wi-fi connector seems to have worked, both my bluetooth and wi-fi are working well post-repair.
  50. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 50, image 1 de 1
    • Retirez la carte mère.
  51. Remplacement du haut-parleur de l'iPhone 6s Plus, Ensemble haut-parleur: étape 51, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus, Ensemble haut-parleur: étape 51, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus, Ensemble haut-parleur: étape 51, image 3 de 3
    • Avec l'extrémité plate d'une spatule, décollez du haut-parleur la nappe du connecteur de charge Lightning.
  52. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 52, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 52, image 2 de 2
    • Dévissez les trois vis cruciformes suivantes fixant le support de la nappe Taptic engine :
    • Deux vis de 3,5 mm
    • Une vis de 2,7 mm
  53. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 53, image 1 de 1
    • Dévissez les cinq vis cruciformes suivantes fixant le haut-parleur à la coque arrière :
    • Deux vis de 2,7 mm
    • Une vis de 2,5 mm
    • Une vis de 1,5 mm
    • Une vis de 1,7 mm
  54. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 54, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 54, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 54, image 3 de 3
    • Dégagez le câble d'antenne Wi-Fi diversity de son manchon en caoutchouc.
    • Si l'autocollant blanc indicateur de contact liquide vous empêche d'y accéder, décollez-le délicatement.
    This step isn't necessary. You can leave this cable in place.
    yes totally unnecessary to remove this or the board at all.
    Smartfone NI - Réponse
    Dégagez le câble d'antenne Wi-Fi diversity du clip du connecteur de mise à la terre (italique = description à vérifier !)
    Apy Ben - Réponse
  55. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 55, image 1 de 2 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 55, image 2 de 2
    • Avec une pincette, déconnectez le câble d'antenne Wi-Fi diversity de la nappe du connecteur de charge Lightning.
  56. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 56, image 1 de 1
    • Dévissez la dernière vis cruciforme de 2,6 mm, fixant le haut-parleur à la coque arrière.
    Bei mir war da nur eine Schraube !
    Boris Alt - Réponse
    Beim mir ist da nur eine, Schraube. Auf dem Bild auch.
    Matze Diamond - Réponse
  57. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 57, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 57, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 57, image 3 de 3
    • Avec l'extrémité plate d'une spatule, soulevez l'ensemble haut-parleur hors de son emplacement.
    • Retirez l'ensemble haut-parleur.
    If you’re following the quickest past, don’t pull it off, cable of Wi-fi Anten is still attached
    Martin - Réponse
  58. Remplacement du haut-parleur de l'iPhone 6s Plus, Antenne de diversité Wi-Fi: étape 58, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus, Antenne de diversité Wi-Fi: étape 58, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus, Antenne de diversité Wi-Fi: étape 58, image 3 de 3
    • A l'aide d'une pincette, décollez les câbles d'antenne du haut-parleur.
    The shorter cable is disconnected at both ends and will come free. If you followed my earlier recommendation, the longer cable is still connected at the logic board end and so needs to be separated from the speaker but left in place in the phone.
  59. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 59, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 59, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 59, image 3 de 3
    • Continuez à décoller les câbles d'antenne du côté long du haut parleur.
    • A ce moment, le clip qui maintient les câbles d'antenne peut se défaire du haut-parleur. Si c'est le cas, veillez à le récupérer pour le remontage.
  60. Remplacement du haut-parleur de l'iPhone 6s Plus: étape 60, image 1 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 60, image 2 de 3 Remplacement du haut-parleur de l'iPhone 6s Plus: étape 60, image 3 de 3
    • Utilisez l'extrémité plate d'une spatule (spudger) pour faire levier et pour enlever l'antenne de diversité Wi-Fi du haut-parleur.
    • Retirez l'antenne.
    If you followed my earlier recommendation, this is still connected to the logic board at the other end. It does need to be removed from the speaker as shown here.
  61. Remplacement du haut-parleur de l'iPhone 6s Plus, Haut-parleur: étape 61, image 1 de 1
    • Il ne reste que le haut-parleur.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
37 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
40%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Arthur Shi
Membre depuis le 01/03/18
249 670 Réputation
503 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 718 tutoriels rédigés
4 commentaires
It is possible to perform this repair without separating the display from the back, and without removing the logic board (which means you need not remove the camera, cellular antenna cabling, audio cabling, and other components). I carefully completed steps 1-15, 38-39, 50-52, and 54-60. It's also not necessary to disconnect the WiFi diversity cable from the logic board . This saves a lot of time and greatly reduces the risk of damaging delicate parts.
I second Mark's comment. In fact, if you are inexperienced with repairing small electronics, I highly advise against removing (or even touching) the logic board, as it is certainly the most expensive part, and among the most easily damaged.
Talon - Réponse
Agree with the other commenters. It would be insane to perform all of these repair steps for just the loudspeaker. Press the back button in your browser and watch the Loudspeaker repair video, not this ridiculous guide. Or use this guide and after removing the display, skip to step 50. This is like taking the engine out of your car to change the wipers.
Peter G - Réponse
This guide has been updated! Unnecessary steps have been trimmed.
Arthur Shi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 72
Total : 44,285
