Introduction
Consultez ce tutoriel pour remplacer le joint Force Touch de votre Apple Watch Series 2. Ce tutoriel montre la procédure à suivre quand l'écran est connecté. Si vous préférez déconnecter l'écran ou remplacez de toute façon l'écran, veuillez consulter ce tutoriel et remplacer le joint Force Touch après le retrait de l'écran.
Avant de commencer toute réparation, ôtez votre montre de son chargeur et éteignez-la.
Préparez un iOpener (ou servez-vous d'un sèche-cheveux ou d'un pistolet à air chaud) et faites chauffer l'écran pour ramollir l'adhésif qui le fixe.
Laissez l'iOpener agir pendant au moins une minute pour chauffer complètement l'écran et ramollir l'adhésif qui le fixe à la coque.
I have heated up the iOpener to 165 degrees and left it on for more than a minute. No way I can lift the screen off with the exact knife. Tried different angles in various places, but no go. I also used a hair dryer un til the watch screen was too hot to touch and even tried a very hard cutting tool blade and also no go. Could n ever get the blade under the face I applied enough force where I could see that the blade left small marks, not very big, but could never get anything to move or lift. What am I doing wrong? I spent 47 years at a global computer company and I am used to taking apart small things and applying force when required. I don’t know what I am doing wrong. Please help me.
Getting the initial gap is not easy. Maybe a playing card could work its way in the tiny gap and cut some adhesive. After that there might be some success with an exacto knife. Or you want to try a piece of aluminum foil (folded for more rigidity) for cutting the adhesive. Be aware of the force touch gasket and that it might get damaged during that procedure.
I finally used a hot air gun set to 150 deg. C heating up the edges by slowly spinning the watch around before the technique worked. Difficult is the level noted and it’s correct. Finally worked and watch perfectly functioning.
I had to heat the iOpener 2 times and leave it on top of the watch for 10 minutes.
The Watch 3 stainless Steel has an additional Frame. Where do i have To Open it?
I wore thick gardening gloves just to be safe 😅 and it took a while but the screen did come off.
Insérez le bord d'une lame courbée dans le fin interstice entre l'écran et le boîtier extérieur. Commencez du côté court de l'écran, le plus proche de la couronne digitale.
Appuyez fermement à la verticale vers le bas dans l'interstice.
Une fois qu'elle est dedans, faites pivoter la lame pour soulever légèrement l'écran.
It’s difficult to grip case in a way that keeps fingers safe from the blade but doesn’t hit the side buttons and turn the device on!
If it’s a struggle to get the display to release, warm case for a few more minutes.
Avec un tournevis Y000, dévissez la vis Tri-point qui maintient le cache métallique du connecteur de la batterie.
Ôtez le cache.
Insérez la pointe d'une spatule du côté extérieur du joint Force Touch et soulevez le joint tout droit vers le haut pour le déconnecter.
Imbibez un coton-tige d'un peu d'alcool isopropylique (>90 %) ou servez-vous d'une lingette nettoyante pour enlever délicatement les résidus d'adhésif sur l'ancien joint Force Touch.
Retournez l'Apple Watch de sorte que les nappes de l'écran sont à plat et le fond légèrement incliné.
Enlevez soigneusement tout résidu d'adhésif au dos de l'écran.
Prenez une pincette pour retirer délicatement le film de protection en dessous de votre nouveau joint Force Touch.
There’s a clear plastic stiffener that must be removed at the same time as or just before removing the protective liner. Be careful to remove only the plastic and not the protective liners, it is possible!
Tenez le joint Force Touch de travers pour le faire passer par-dessus l'écran.
Faites délicatement pivoter l'écran vers l'avant de façon à aligner le joint Force Touch avec le châssis.
En commençant du coin opposé du connecteur du joint Force Touch, posez le joint sur le châssis et appuyez dessus.
Servez-vous d'une pincette pour remettre en place la plaque métallique qui recouvre le connecteur de la batterie.
Remettez la vis Tri-point #000.
À ce moment, il est utile d'allumer la montre pour vérifier que tout fonctionne correctement avant de la refermer.
38 autres ont terminé cette réparation.
Merci à ces traducteurs :
60%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
7 commentaires
Hola, Me presento como nuevo y NOVATO. Me llamo Jaime, y Yo creo que os mereceis un 10. La caña de España.
Hola Jaime! Bienvenido! Muchas gracias por tu comentario. Nos alegra que te guste nuestro sitio. Cualquier duda que tengas, no dudes en consultarme. Soy la moderadora y líder de la comunidad hispanohablante.
The gasket comes with all the necessary adhesive or you need to put he the sealing adhesive separately? I need to replace my screen and I got the gasket and screen but don’t know if I need glue to waterproof it?
I bought iFixit’s battery replacement kit and the gasket which I received had adhesive on both sides, just like in this guide.
The repair kit does comes with extra gasket adhesive, which confused me at first. The extra adhesive is included in case you manage to open the watch without damaging the original gasket.
I have no idea why they include the extra adhesives. When I tried to use one the screen sat too high and it looked bad.
Thank you for an awesome guide. It got a little dodgy for a second there, but I replaced the screen, Force Touch Gasket and Battery. It works as new!
Congrats, welcome to the club of fixers :)
Verify your model. The back of the Cellular model just says GPS, so be sure to check the groves where the watch band goes to determine you model. I made the mistake of just reading the back of the device and since I’d been gifted the device didn’t know it was cellular. Cellular has a different type of touch force gasket, different screen, and different battery connections.
Ryan Holt - Réponse
From what I just read on Apple, the only differences in watch series 3 is 38mm and 42mm.
mcr4u2 -
As a consumer all you need to know are 38mm and 42mm
Michael Adoga - Réponse
The back will say GPS LTE if it’s the cellular version. If it doesn’t say LTE it is only the GPS version. The displays are different whether or not it is LTE(cellular).
themepark - Réponse
This alternative method only reboots the watch.
Gregg Stanley - Réponse
