Introduction
Ce guide vous guidera à travers les étapes de retrait du joystick. Cela vous sera utile si vous avez un joystick escroc
Ce dont vous avez besoin
Placez le contrôleur (boutons) sur une surface solide.
Retirez les six vis TRI-Wing Y0 de 9,2 mm qui maintiennent le panneau arrière en place.
Saisissez le bouton Z par la cheville avec une pince à épiler et retirez-le du contrôleur.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
31 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
13 commentaires de tutoriel
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
without taking the controller completely apart, pull the joystick straight up with your hand
