Introduction
Utilisez ce guide pour remplacer le lecteur Blu-ray de votre Playstation 3. Remplacer un lecteur Blu-ray défectueux requiert le changement de la carte du lecteur Blu-ray contre celle de l'ancien lecteur lors du remplacement.
Ce dont vous avez besoin
Utilisez la pointe d'un spudger pour retirer la vis-mère en caoutchouc noir du côté de la PS3.
Enlevez la vis torx de sécurité T10 de 8.5 mm de la plaque à puce.
How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
Tirez la plaque à puce vers la baie du disque dur, puis soulevez-la pour la retirer de la PS3.
different in mine too, Model: CECHP01
mine does not have one at all
1How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
Did not find in my CECHH01
I don’t have this bracket, where I can get it ?
Enlevez les vis suivantes :
Six vis Phillips de 52 mm
Une vis Phillips 30 mm
2 more smaller screws (don't know what size...small) just below the top middle screw and top right screw (in the picture). Look for the arrows...
can confirm, might be the backwards compatibles only
This usually isn't needed as you can additionally unclip the card reader by pushing the tabs out while lifting the top, They are located at the bottom of the screw holes with the arrows pointing at them
after you remove the screws, you may have to push a tab to take the cover off if you meet resistance on one side of the cover. Here is a link to a video that explains it, saved me lots of trouble:
Thanks @ericksi33, this really helped me out.
hogurt -
1st attempt, fan loud. Ps3 lasted about 2 wks. 2nd attempt noticed very poor contact between heatsink & cpu,gpu when taking it apart. Research - Found a better way to apply thermal past. I personally disapprove of guide on this. A small bit about the size of a grain of rice in center of cpu is plenty. Clamp the heat sinks back on. Then take it apart & check contact area. Thermal paste should have spread to about the size of a quarter.(more is better. Less then a nickel size is poor contact) possibly weak clamps. Carefully applied pressure onto the cpu & gpu, pressing them into the heatsinks before clamping heatsink clamps on. Achieved greater then quarter sized thermal past spread. Fan silent in comparison & ps3 lasted about a yr. Rarely did I ever hear the fan go to high and get loud after that. About to begin my third fix on this same ps3. One of the first 80g backwards compatible. other then those notes and that this guide was for a different model ps3 (minor differences) I liked this guide. easy to follow.
Although the battery is described as proprietary, it looks like it is the common CR2032 lithium coin battery that is used in calculators and some computers. I haven't had to replace mine but I suspect under the heatshrink cover is a battery holder which will allow the coin battery to be removed and replaced. Then wrap with electrical tape and reinstall.
I tried this with the heatgun and it ruined my PS3. The CPU and GPU are NOW RUINED!!! It did not work for and made things worst!!! I sent it to a place to get reballed and they said the HEATGUN had overheated my processor and killed them!!! So think twice about doing this. Just because it is already broken, DON'T THINK YOU CAN'T MAKE IT WORST!
Why would you try it with a heat gun, no were is it mentioned to do that
2How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
I felt more comfortable with #2 screwdrivers.
Soulevez le couvercle supérieur par le bord arrière et faites-le pivoter vers l'avant de la PS3.
Enlevez le couvercle supérieur.
Un crochet en plastique se trouve dans un trou dans le coin supérieur arrière droit. Éloignez délicatement le crochet en plastique de l'arrière de la machine en poussant un peu avec une spatule, pour dégager la partie arrière droite du boîtier.
Disconnect the memory card ribbon cable.
The top would hardly budge on the left back corner and was stuck on the right back corner. There is a plastic hook that needs to be unfastened to lift the top off. It is located in a hole on the top back corner on the right hand side, so the corner straight across the on off button. Just gently push the plastic hook a bit front the rear of the machine with a spudger. It gives easily and the top will be free to lift off after that.
I can confirm on CECHH01.
Some more details here as well.
The newer model without SACD support appears to have added that clip to the back right that needs to be pressed to release the top shell.
If equipped with the card reader you can either have to disconnect the ribbon cable or unclip the reader from the top shell after lifting it up to get finger or tool in there to push clip to side and release reader from top shell. Note: if you failed to remove the card reader screws in the previous step these clips can break.
The original 60GB with the CF card reader on the front has a button protruding out. This will make it difficult to remove the top. You need to unscrew the memory card reader so it can come out easily.
Wow, this needs more attention. This isn't explained in any disassembly guide I've seen. You also need to be cognizant of the card reader cable when you're lifting off the lid.
I didn't have trouble during disassembly, but reassembly was tough. I loosened the card reader screws by 1 turn and used a small gauge wire to lasso the button and ran it through the CF hole.
Déconnectez le cable d'alimentation du lecteur Blu-ray de la carte mère.
Pull the cables gently, the plug will come out of the socket. The plug is encased by the socket.
That’s also what I did.
My PS3 is the CECHL01 and I had to remove the PSU to get to the disk drive ribbon cable.
I mistakenly ripped the whole thing out... I do not know where to begin on repairing it.
Utilisez vos ongles pour faire basculer le clapet de retenue de la prise du câble plat Blu-ray.
Retirez le câble plat de sa prise.
Retirez le lecteur Blu-ray de la PS3.
Not all systems look like this, some have tape instead of the flap.
Every system that I have seen has had the ZIF connector, while some had tape over the connection as well. If your connectors are taped, be sure to remove the tape, then proceed with undoing the ZIF connector.
The version 2 systems baseboard PCB started switching to the new narrow 24 pin ZIF header/ribbon and Blu-Ray drive connection.
You should not attempt to detach the taped ribbon cable from the drive end first as described above for the older wide 60 pin ribbons. You must remove the drive and ribbon as one unit to protect the fragile ZIF sockets.
The slimmer fragile ribbon is taped to the drive housing to afford a more secure ZIF connection. The opposite base connection is slightly under the PSU.
continued
From continued
One should firstly remove the PSU: Disconnect the drive power cable as described above. Unscrew the 5 (3-P1 2-P2) PSU mounting screws. Now leaving the power cables attached, lift the PSU off the power baseboard PCB pins and move over slightly to access the baseboard drive cable end ZIF. Release the ZIF latch and slide the entire (drive and ribbon) strait away from the baseboard ZIF to disconnect.
After the complete drive/ribbon removal, you can carefully remove the restraining tape on the bottom of the drive to release the ribbon ZIF, then remove the 24 pin ribbon from the drive logic PCB.
Install in reverse order making sure to add new tape to secure the ribbon to the drive.
I needed to remove the PSO completely to reach the baseboard drive cable end ZIF. To do that disconnect the power and data (I assume) cables and then pull the unit straight up. To longish prongs are heading straight up into it from the baseboard and it is a bit tight, so gently pull until it's clear.
cornellg -
If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the motherboard, and the Blu-ray drive will not work with a different board. -------------- I understand however my daughterboard is not on the bottom of the blu-ray drive it must be on the inside. Is there any advice out there on how I go about doing this as I am not sure what I am doing???? If someone could post a link or any tips it would be greatly appreciated.
When I received my new drive there was a sheet that said you could keep the old boards but you have to 'flash' them with the ps3's digital information. Currently trying to figure out how.....
Cheffy -
My CECHH01 has its blu-ray drive encased in a shield plate. Only one ribbon cable is visible. (The one we have to disconnect). Mine had some tape over it.
Also, I used a spudger instead of my nails.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
154 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
15 commentaires
Most helpful. Thx need to buy parts.and tools needed to fix game game. Were to buy ?
Not sure myself, need one too. Look under comments section under ps3 laser replacement for more info. They are supposed to sell them on this website but I think they are still out.
Very helpful
Thanks but I need the step by step procedure for the remarry process.
Jailbreak it with Rebug. Downgrade it to CFW 3.55. Open Rebug tools and turn one factory service mode. After restart open Rebug tools and select remarry BD. Exit FSM, and upgrade to CFW 4.82 (or 4.84)
aangelcg -
Hey everyone if your wondering where u can buy a cd drive just look up “KEM-400AAA disc drive" and you should find results i spent weeks looking for it i hope no one encounters the same problem i had
Hi, do you know ut there is a difference between the kem410a0a 1 and the kem410aca?
Can't seam to find any 410a0a replacements…
Where can i buy a ps3 disk drive cechl01 please
Brought eBay lot and there was two PlayStation3s both opened… one had power supply and disc drive I powered it on the non backwards compatible PS3 only played movies no games the other PS3 is backwards compatible and doesn’t power on I brought a power board and on way but does this mean the disc drive I have in non backwards compatible PS3 is for the backwards compatible PS3?! Just curious please answer if you know anything that could help!
Does this work on a slim PS3 as well?! I have a 120Gb model
I kill you..
Fake repair. Real fault: How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
Player - Réponse
