Aller au contenu principal
Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010
Ce dont vous avez besoin
  1. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010, Lecteur optique: étape 4, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur du caisson de basses de la carte mère afin d'éviter les décharges électriques. Cette étape est facultative.
    • Retirez le rembourrage qui peut se trouver au-dessus et débranchez doucement le connecteur de sa prise sur la carte mère.
    It is not necessary to remove the camera cable connector (step 5) or the camera cable connector (step 10). Simply push the camera cable gently aside to remove one of the three screws securing the optical drive (step 11). Gently wiggle the optical drive from under the camera cable connector and go to step 12. Less chance of ruining your motherboard!
    tomhart - Réponse
    Absolutely. Leave it alone, you don’t need to run the risks of removing this cable, I did the replacement fine without it
    Steven Taylor -
    It does indeed come out of the connector, but the picture makes it hard to see how; the connector it goes into sits on top of the board—however, I, too, ripped mine off the board trying to remove it; I only got it out of the clip after I tore it off. SIMPLY DONT; it's unnecessary. I plan to solder it back if one of my Robotics club friends lets me borrow a soldering iron.
    Rachel - Réponse
    Alors je déconseille très fortement de toucher ce connecteur, il est extrêmement fragile. De plus, cela n’a pas d’incidence sur la suite des opérations
    Laskoni - Réponse
    The author needs to go back through this guide and correct lots of order mistakes. The fan was removed in steps 3-5 yet it’s still being shown installed in steps 19-22.
    plink53 - Réponse
    The 4-pin push connector for the sub-woofer is near impossible to reconnect
    It mates with a female connector that sits on top of 4 tiny solder points (it's held on by a spot of glue, I believe), and when applying ANY pressure to connect, the side clip(s) will snap off. Then the connector itself will become unglued. It would be simple enough to connect the 2 parts, then place a drop of glue on the logic board after positioning it above the solder points, but the female connector broke apart in my hand. So now screwed, with no way to connect sub/ R speaker without installing another logic board. Fan connector looks to be exactly the same
    Peter Watkins - Réponse
  5. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 5, image 1 de 1
    • Il est nécessaire de déplacer le petit clip de fixation du câble en plastique transparent (encadré en rouge) collé sur la carte mère de sorte qu'il ne vous gêne pas pour débrancher le câble vidéo. Lorsque vous l'écartez du connecteur du câble vidéo, faites attention à ne casser aucun des composants de la carte.
    • Tirez le connecteur du câble vidéo vers le lecteur optique pour le débrancher de la carte mère.
    • Cette prise est en métal et plie facilement. Veillez à aligner le connecteur par rapport à sa prise sur la carte mère avant d'accoupler les deux pièces.
    I just completed this replacement and there is no need to do this step, you can work around this cable pretty easily. Obviously you need to be careful "dancing" around it. But it's perfectly feasible and you don't risk to break stuff disconnecting it.
    Massimo C - Réponse
  6. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 6, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du lecteur optique pour le débrancher de la carte mère.
  7. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 7, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du disque dur pour le débrancher de la carte mère.
  8. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 8, image 1 de 1
    • Retirez les vis suivantes par lesquelles le caisson de basses est fixé au boîtier supérieur :
    • Une vis Phillips 3,8 mm.
    • Une vis Phillips 5 mm.
    On my computer, the 3.8 mm screw was near the midpoint of the subwoofer (left-to-right in the photo) and near the bottom. The 5 mm screw was top right of the subwoofer.
    BobG - Réponse
  9. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 9, image 1 de 2 Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 9, image 2 de 2
    • Ne retirez pas complètement le caisson de basses, car il est toujours raccordé au haut-parleur droit.
    • Soulevez le caisson de basses du lecteur optique et posez-le au-dessus de l'ordinateur.
  10. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 10, image 1 de 2 Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 10, image 2 de 2
    • Retirez les deux vis Phillips 10 mm par lesquelles le support du câble vidéo est fixé au boîtier supérieur.
    • La vis la plus à gauche peut rester captive dans le câble vidéo.
    • Soulevez le support du câble vidéo hors du boîtier supérieur.
  11. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 11, image 1 de 2 Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 11, image 2 de 2
    • Retirez les trois vis Phillips 2,5 mm par lesquelles le lecteur optique est fixé au boîtier supérieur.
    • Soulevez le lecteur optique par le côté droit et sortez-le de l'ordinateur.
    Install 2 outside screws first and then single inside screw to allow wiggle room to get outside screws in. Do not tighten screws until all are started.
    JASON CULP - Réponse
  12. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010, Lecteur optique: étape 12, image 1 de 1
    • Débranchez le connecteur du câble du lecteur optique de celui-ci.
    • Ce connecteur est particulièrement long. Pour le débrancher du lecteur, veillez à tirer au centre du connecteur.
    • Si un CD ou tout autre objet est coincé dans votre lecteur, utilisez notre guide de réparation pour lecteur optique.
  13. Remplacement du lecteur optique dans le MacBook Pro 13" Unibody Mi 2010: étape 13, image 1 de 1
    • Retirez les deux vis noires Phillips #0 qui sécurisent la petite attache métallique. Transférez cette attache sur votre nouveau lecteur optique ou SSD.
Pour remonter votre appareil, suivez les instructions dans l'ordre inverse.
81 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
I removed my optical drive without disconnecting the hard drive or anything else. I just unplugged the optical drive from the board, unscrewed the speaker, and very slowly removed the drive after taking out the three screws holding it in place. I was discouraged at first to remove my optical drive because it looked a little too tricky for me from the directions, but it was actually quite easy! I'm going to be interested to see if pulling the optical drive results in any noticeable improvement in battery performance on my 13" 2.4GHz MBP! I doubt it haha
T Buckle - Réponse
I skipped down to the step with 3 screws holding the optical drive, removed them, gently pried out the optical cable, and slid out the optical drive (at a slight 10 degree angle)!! Thank you!
Ary Safian - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 37
30 derniers jours : 124
Total : 124,426
