Aller au contenu principal
Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009
Ce dont vous avez besoin
  1. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009, Remplacement du lecteur optique dans le MacBook Pro 13" Unibody mi-2009: étape 4, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du câble du haut-parleur droit/caisson de basses pour le débrancher de la carte mère. Veillez à ne pas soulever la prise. Tirez le connecteur vers le lecteur optique.
    • Faites levier en passant sous les fils.
    Step 4 is correct as stated (pull up, not slide out). You'll definitely see this when you put it back in place, pushing down in socket not sliding in. Just be careful and use spudger (gently!) underneath wires as shown.
    jgcolt - Réponse
    What is the best way to solder this back onto the board? I did it once 5 years ago, but that was my first and only time soldering. I know there is a soldering guide, and I have read it. Could someone tell me please the best way to reconnect the right speaker/subwoofer cable to the board, referencing the soldering guide?
    Leslie L. Gordon - Réponse
  5. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 5, image 1 de 1
    • Il est nécessaire de déplacer le petit clip de fixation du câble en plastique transparent (encadré en rouge) collé sur la carte mère de sorte qu'il ne vous gêne pas pour débrancher le câble vidéo. Lorsque vous l'écartez du connecteur du câble vidéo, faites attention à ne casser aucun des composants sur la carte.
    • Tirez le connecteur du câble vidéo vers le lecteur optique pour le débrancher de la carte mère.
    • Cette prise est en métal et plie facilement. Veillez à aligner le connecteur par rapport à sa prise sur la carte mère avant d'accoupler les deux pièces.
    When you put the Mac back together after this entire procedure, it's virtually impossible to get the camera cable reconnected because there is a small piece of plastic glued to the board to keep it from coming unplugged. An Apple store tech explained the piece of plastic and said it won't break anything if I pry it off the board. I did and then the cable connected easily.
    karenz - Réponse
    The retainer for the camera cable may be black as well as clear. It is much easier to remove and reinstall the retainer if the DVD drive cable is removed first.
    MikeG - Réponse
  6. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 6, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du lecteur optique pour le débrancher de la carte mère.
  7. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 7, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du disque dur pour le débrancher de la carte mère.
  8. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 8, image 1 de 1
    • Retirez les deux vis Phillips par lesquelles le caisson de basses est fixé au boîtier supérieur.
    • La plus longue des deux vis se trouve sur la droite.
    For step 8, I found I had to use a Phillips #0 screwdriver to remove the two screws. I'm not sure if mine were just over-tightened, but I couldn't get the two screws off with a cheapo Radioshack #00 screwdriver or a nice Wiha one for the life of me without coming close to stripping them. Tried the #0 and they popped right out. Hope this helps.
    Aaron B - Réponse
  9. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 9, image 1 de 2 Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 9, image 2 de 2
    • Ne retirez pas complètement le caisson de basses, car il est toujours raccordé au haut-parleur droit.
    • Soulevez le caisson de basses du lecteur optique et posez-le au-dessus de l'ordinateur.
  10. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 10, image 1 de 2 Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 10, image 2 de 2
    • Retirez les deux vis Phillips par lesquelles le support du câble vidéo est fixé au boîtier supérieur.
    • La vis de droite peut rester captive dans le câble vidéo.
    • Soulevez le support du câble vidéo hors du boîtier supérieur.
    There's another type of bridge, black, with an extra piece of metal to hold the cable. You don't have to remove this bridge to unmount the optical drive.
    Martin - Réponse
  11. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 11, image 1 de 2 Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 11, image 2 de 2
    • Retirez les trois vis Phillips 2,5 mm par lesquelles le lecteur optique est fixé au boîtier supérieur.
    • Soulevez le lecteur optique par le côté droit et sortez-le de l'ordinateur.
  12. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009, Lecteur optique: étape 12, image 1 de 1
    • Débranchez le connecteur du câble du lecteur optique de celui-ci.
    • Ce connecteur est particulièrement long. Pour le débrancher du lecteur, veillez à tirer au centre du connecteur.
    • Si un CD ou tout autre objet est coincé dans votre lecteur, utilisez notre guide de réparation pour lecteur optique.
  13. Remplacement du lecteur optique du MacBook Pro 13" Unibody mi- 2009: étape 13, image 1 de 1
    • Retirez les deux vis noires Phillips #0 qui sécurisent la petite attache métallique. Transférez cette attache sur votre nouveau lecteur optique ou SSD.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
103 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Fabienne Detoc nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
iFixit rocks! Got a stuck CD out of my wife's superdrive this way. Many thanks!!!
Steve Folberg - Réponse
I just took mine apart and found a piece of tape in it. Smh. Works perfect now.
Dana Kimble - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 92
Total : 154,793
