Introduction
Ce tutoriel est la continuation du tutoriel prérequis Démontage du volant Logitech G27. Dans ce tutoriel, nous montrerons comment remplacer les moteurs qui créent un retour de force dans le jeu. Après avoir suivi ce tutoriel, votre volant Logitech G27 devrait être entièrement fonctionnel.
Ce dont vous avez besoin
Retirez les six vis hexagonales grises de 25 mm avec une clé Allen de 4 mm.
Soulevez soigneusement la roue, mais ne la déconnectez pas du reste de l'appareil.
Pincez et débranchez soigneusement le grand connecteur à 7 broches sous la carte PCB.
These screws refused to go all the way back in for me, and one of them stripped completely. If this happens to you, you can get replacement screws that are shorter here - https://www.amazon.com/gp/product/B01MFA...
This works for the G27, not sure about the G25 or any other wheels.
Obviously the screws being shorter means the wheel isn't as strongly attached to the base in this direction, so if you have to do this remember not to put unnecessary stress on these screws by pulling the wheel straight off the base.
bro i need new long cable i think and that connector or just replace the whole thing .. i put new grease, screw it more tight by the encoder so it woulnt go to the left .. wheel works verry nice tho all my buttons and shifter pedals wont work now tho the lights works dont know what to do now.. and now i kinda regreat opening it.. my wheel run so good now just these buttons are off not working at all and it kinda screws up midle of the game..
@alexdinpoik I’ve had the same problem when the 7 pin connectors blue and green cables broke off. First, only the blue one was broken which only took the led indicators gradual increase but all buttons were working then when i tried to plug in back, the green one broke off leading to none of the buttons working but the led indicators just working. Now i’ll try to fix it with iron soldering.
okan can u pls share a video of you doing it? so i can do the “copy paste” hahah where can i buy cables and stuff i need for that? whats the name of these white connectors ? im new to this but share me a link to buy. i rather just try to fix it then buy a new wheel since its a great wheel compare to g29 that has bad software and the other wheels are to expensive. g27 cant be found in stores anymore neither and if im gonna buy one it has to be new haha hopefully u can share some knowlage thanks!
Where i can Buy the 7 pin cable for Main board please
Hey guys!
i broke the 7 pin cable anyone know where can is buy it? Thanks
Vous pouvez maintenant retirer complètement la roue du moyeu. Mettez-le de côté jusqu'à ce que vous remontiez la roue.
Retirez les trois vis argentées les plus internes de 37,5 mm avec un tournevis cruciforme n ° 2.
Retirez le moyeu de roue et poussez le connecteur au centre du moyeu.
Retournez le boîtier et retirez la moitié supérieure du boîtier, révélant la majorité des composants de la roue.
Le couvercle du boîtier peut être mis de côté jusqu'à ce que vous remontiez la roue.
Loosen the desk clamps before removing the housing, otherwise you risk breaking something. The housing should come off without having to use any force whatsoever.
Retirez les quatre vis argentées de 7,3 mm fixant la carte PCB verte au boîtier du moteur avec un tournevis cruciforme # 2.
I’d do steps 9 and 10 in reverse order, the connectors are much easier to unplug while the board is secured in place.
Débranchez les trois connecteurs en plastique sur le côté gauche de la carte PCB.
Débranchez les deux connecteurs en plastique sur le dessus de la carte PCB.
Débranchez les trois connecteurs en plastique sur le côté droit de la carte PCB.
Some of the connectors have locks on them, I would recommend this as a two person job.
I didn't take them off :)
I messed up and broke the cables of the 5 Pin Connector on the right. Can anyone tell me what it’s called so I can buy replacement? The Rest of the cable is stuck in there so I can’t re-use it sadly.
Retirez les quatre vis de 12,2 mm à l'aide du tournevis cruciforme.
Les moteurs et la boîte de vitesses devraient maintenant sortir. Au fur et à mesure que vous le retirez, la bande de ressort métallique ainsi que la piste de l'engrenage de roue sortiront également.
Lorsque vous avez séparé ces pièces, vous pouvez les mettre de côté jusqu'au remontage.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
18 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
7 commentaires
If you do not feel confident doing this yourself, here is a link to a company that could do it for you http://www.mz-simulators.co.uk/services....
Where can i buy this motors ?
i found 1 of each
going to buy the encoder as well and start with it and then motors if needed
I found the motor model number
555sh-15260
http://www.czleili.com/english/Detail_pr...
How can I replace the new motor into G27
Fijar primero el volante en la mesa para evitar desperfectos.
Alpc360 - Réponse
