Introduction
Ce guide vous demandera de retirer le boîtier supérieur à l'aide d'un tournevis gamebit, puis afin de révéler le ruban au système du port du contrôleur, vous devrez retirer le bouton de réinitialisation. Ce processus ne nécessitera que le gamebit.
Ce dont vous avez besoin
Retirez les six vis situées sous le système à l'aide du tournevis Gamebit 4,5 mm.
Soulevez les ports du contrôleur hors du boîtier, cela doit être fait sans trop de force. Notez l'emplacement de la connexion du câble plat.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
17 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
This isn’t complete. How about taking the face plate off?
In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
Raucedine - Réponse
There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
phoenixknight8082 - Réponse
I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
Thanks in advance.
Mike Watts - Réponse
For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
Austin Barnett - Réponse
Could you further explain how to short the capacitor leads?
Will Pulman -
