Aller au contenu principal
Remplacement du ventilateur de la Nintendo Wii
Ce dont vous avez besoin
  1. Remplacement du ventilateur de la Nintendo Wii, Façade: étape 1, image 1 de 2 Remplacement du ventilateur de la Nintendo Wii, Façade: étape 1, image 2 de 2
    • Utilisez une spatule (spudger) en métal pour retirer les caches de vis en plastique blanc, collés sous la coque inférieure, à l'avant de la Wii.
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - Réponse
    Don’t mistakenly remove the rubber case feet
    Bob Trout - Réponse
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - Réponse
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - Réponse
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - Réponse
  2. Remplacement du ventilateur de la Nintendo Wii: étape 2, image 1 de 1
    • Enlevez les deux vis Tri-wing de 8,3 mm dont vous venez d'enlever les caches.
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - Réponse
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - Réponse
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - Réponse
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - Réponse
    How do you make one ? If you don’t have the screwdriver
    Ethan - Réponse
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - Réponse
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - Réponse
  3. Remplacement du ventilateur de la Nintendo Wii: étape 3, image 1 de 1
    • Enlevez la vis cruciforme de 5,9 mm située sous la trappe d'accès aux ports contrôleur, la plus proche de la façade.
  4. Remplacement du ventilateur de la Nintendo Wii: étape 4, image 1 de 1
    • Utilisez une spatule en métal pour retirer le patin en caoutchouc collé sur le côté de la Wii, près de l'ouverture du lecteur DVD.
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - Réponse
  5. Remplacement du ventilateur de la Nintendo Wii: étape 5, image 1 de 1
    • Enlevez la vis cruciforme de 5,9 mm cachée sous le patin que vous venez d'enlever.
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - Réponse
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - Réponse
  6. Remplacement du ventilateur de la Nintendo Wii: étape 6, image 1 de 2 Remplacement du ventilateur de la Nintendo Wii: étape 6, image 2 de 2
    • Tirez délicatement la façade de l'avant de la Wii.
    • Utilisez une pincette pour déconnecter le connecteur en plastique du câble LED de la carte mère.
    • Retirez la façade.
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - Réponse
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - Réponse
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - Réponse
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - Réponse
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - Réponse
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - Réponse
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - Réponse
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - Réponse
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - Réponse
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - Réponse
    Needlenose pliers did the trick for us!
    Ron Cormier - Réponse
    Needlenose pliers did it for us!
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - Réponse
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - Réponse
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - Réponse
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - Réponse
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - Réponse
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - Réponse
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - Réponse
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - Réponse
  7. Remplacement du ventilateur de la Nintendo Wii, Coque externe: étape 7, image 1 de 3 Remplacement du ventilateur de la Nintendo Wii, Coque externe: étape 7, image 2 de 3 Remplacement du ventilateur de la Nintendo Wii, Coque externe: étape 7, image 3 de 3
    • Ouvrez la trappe d'accès aux ports contrôleur jusqu'à ce qu'elle soit perpendiculaire à la plaque noire des ports.
    • Tirez la trappe vers le haut pour la détacher de la coque externe.
    • Répétez cette procédure pour la trappe d'accès au lecteur de carte mémoire.
    I wasn't able to reassemble the socket covers when I reversed this step..
    While disassembling, I did as instructed pulling the covers upwards when they where perpendicular to the black cover plate but Nintendos instructions says to open the covers (so that they are perpendicular to the black cover plate) and then gently push the covers towards the console with your fingers on the outside of the cover opposite side of the hinges so that the cover hinges will pop out and then lift it up..
    I'm not sure, but I think ignoring Nintendos instructions caused the hinge sockets to break for me, so replacing the controller/memory card socket covers will not work.
    When reassembling, the cover can be placed perpendicular to the black cover plate and rest on the plastic hinge with a few millimeters between the cover and the console, and then they can be pushed down to click in place. But in my case they keep falling all the way down since there's no resistance and nothing to click into.
    Martin Johansson - Réponse
  8. Remplacement du ventilateur de la Nintendo Wii: étape 8, image 1 de 2 Remplacement du ventilateur de la Nintendo Wii: étape 8, image 2 de 2
    • Enlevez les deux vis cruciformes de 4,1 mm restantes le long du bord supérieur de la plaque noire des ports contrôleur.
    • Soulevez la plaque de la bordure supérieure, et enlevez-la de la Wii.
    The 3rd hole is in step 3.
    James middleton - Réponse
    The bezel is the flat black plate. Removing the three screws that secure it allows you to remove it. If your cube is like mine, this plate likes where it lives and, even with the screws removed, managed to stay in situ without anything holding it.
    Dennis Johnston - Réponse
    Beware. The edge of the bezel, opposite these screws, has clips. Lift the bezel from the top edge, where the the screws are, to avoid breaking these clips.
  9. Remplacement du ventilateur de la Nintendo Wii: étape 9, image 1 de 1
    • Enlevez les deux vis cruciformes de 5 mm au dessus des ports contrôleur.
  10. Remplacement du ventilateur de la Nintendo Wii: étape 10, image 1 de 1
    • Utilisez une spatule en métal pour enlever les trois cache-vis collés sur le côté de la Wii.
  11. Remplacement du ventilateur de la Nintendo Wii: étape 11, image 1 de 1
    • Enlevez les vis suivantes :
    • Deux vis cruciformes de 5 mm
    • Une vis Tri-wing de 8,2 mm
    Instead of the Phillips screw on the left I had a very small one under a cover to the left of that!
    Donna Vought - Réponse
  12. Remplacement du ventilateur de la Nintendo Wii: étape 12, image 1 de 1
    • Utilisez une spatule en métal pour enlever les deux patins en caoutchouc collés sur la face inférieure de la Wii, près des ports arrière.
  13. Remplacement du ventilateur de la Nintendo Wii: étape 13, image 1 de 1
    • Enlevez les deux vis Tri-wing de 8,2 mm cachées sous les patins que vous venez de retirer.
    • Vous pouvez utiliser un tournevis hexagonal de 4 mm pour étendre votre embout et atteindre les vis.
    had a little trouble with theses screws. they were just barely too deep for my 54pies bit driver kit to reach. I ended up inserting a small wad of paper into the shaft of my driver so the tri-wing bit stuck out far enough to engage the screw. (I used the tweezers to remove the paper when I was done) :)
    rbelknap - Réponse
    I can confirm, this works fantasticly!
    Thank you
    James middleton -
    When putting the screws back in hold the tip still with the screw and carefully drop it in.
    James middleton -
    Thank you rbelknap, this is excellent advice for those using the ifixit branded driver.
    George Squires - Réponse
    You could also use the 4mm nut driver in the iFixit kit to turn the tri-wing driver. This will give you a little more reach.
    Edward Tucker - Réponse
    How is no one talking about the included 4mm nut driver trick at Edward Tucker mentioned?! That is genius! Thanks mate!
    Zabuza -
    That's the idea that I needed. Agree with Zabuza.
    cwdick -
    Bingo. All of the other comments were unnecessary.
    Tony Shannon -
    Because it doesn't come with the screw driver in the kit. Only has the tri wing and the cross tips.
    Craig Goodsell -
    This paper wad trick totally worked for me too!
    anonymous 779 - Réponse
    Standard Tri-Wing bits will NOT fit into the holes. Make sure that you get one of the tool kits from iFixit (I just ordered the Mako Driver/Bit kit with 64 bits ) - the Tri-Wing bits in this kit have a narrow shaft that allows it to reach deep into narrow holes like these on the Wii . (Disclaimer - I have no association with iFixit).
    dave whale - Réponse
    I just sawed off a bit of the shank holder from the iFixit tool, in order for the bit to go deep enough into the case.
    The tool still works fine.
    Alan Walker - Réponse
    Thanks for the paper wad trick advice! Worked perfectly with my Wii
    Finder352 - Réponse
    The 4mm driver was the exact fix for this problem, no mods necessary
    Tony Shannon - Réponse
  14. Remplacement du ventilateur de la Nintendo Wii: étape 14, image 1 de 1
    • Soulevez la coque externe pour la retirer de la Wii.
    This step could use at least another picture from the backside so it's clearer what comes up and what stays down.
    Jose Vazquez - Réponse
    I used a spudger around the edges of the outer case to gently ease it upward since I could not lift it out with my fingers. Then it came right out.
    Marko - Réponse
    Good tip. Having, in the past, broken pieces that required a little persuasion, I attempted to "lift" the outer case, but it wouldn't budge. Using the spudger to persuade it worked like a charm. Also added this suggestion to Step 18 "Lift the drive shield."
    Dennis Johnston -
    hey marko that really helped me thanks\. als if you need help figuring which side is up, its the one with the nintendo engraving on it
    Aryan Garg - Réponse
    A fan filter fell out at this step how do you put it back?
    Edit: I figured it out it was from the side intake vent. Just line up the two notches with the pegs in the case to hold it in place
    Darren Jones - Réponse
    This is an awful guide
    Alexander D Schaefer - Réponse
  15. Remplacement du ventilateur de la Nintendo Wii, Ventilateur: étape 15, image 1 de 1
    • Déconnectez le connecteur du ventilateur avec des pincettes et soulevez-le tout droit hors de sa prise sur la carte mère.
    • Assurez-vous que votre pincette est fixée sur le connecteur du ventilateur et non sur la prise reliée à la carte mère.
  16. Remplacement du ventilateur de la Nintendo Wii: étape 16, image 1 de 1
    • Retirez les deux vis cruciformes de 10 mm fixant le ventilateur à la base du ventilateur.
  17. Remplacement du ventilateur de la Nintendo Wii: étape 17, image 1 de 1
    • Retirez le ventilateur de la Wii.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
28 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
9 commentaires
Awesome guide, just replaced faulty fan unit in my 9 year old wii. Should hopefully keep it going for another 9 years :)
Finlay Macrae - Réponse
Super easy and great instructions! I feel a little guilty that my Wii sat in the garage for 4 years! Now it'll be a great birthday present for my 2 boys.
e_gayheart - Réponse
Does anyone have a diagram for the Wii’s airflow? I’m looking to install a booster fan at the bottom to help blow air in but I want to make sure it is effective.
Jessica Parnelli Fawkes - Réponse
nice¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Réponse
Thanks! Wii Quarantine’n in 2021!
Daniel Thomas - Réponse
Beautiful instructions. Thank you. A++. Would disassemble my Wii again.
Henry - Réponse
Pls help my Wii fan came off the motherboard!
Dantendo - Réponse
Muito obrigado!
Wackson Wel - Réponse
Much appreciated
Hazzer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 54
30 derniers jours : 268
Total : 42,603
