Introduction
Utilisez ce guide pour retirer et remplacer le système de ventilation de votre PS4 Slim.
Ce dont vous avez besoin
Localisez l'autocollant de garantie en plastique à côté des trois ports sur le côté de la console.
Retirez l'autocollant de garantie en le décollant avec tout type de spatule.
Dévissez et retirez la vis de 5,0 mm qui se trouvait derrière l'autocollant à l'aide d'un tournevis Torx de sécurité T8 avec un mouvement dans le sens antihoraire.
T8 fits like a glove for me
Is there anything else you can use
A small flathead screwdriver will work
There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
Nicholas -
There is a metal thing inside of the screw slot any insite on this?
Placez la Playstation 4 Slim à l'envers avec le côté de la vis que vous venez de retirer face à vous.
Soulevez les deux coins qui vous font face avec vos doigts.
Retirez le capot inférieur en le faisant glisser vers les coins arrière et en le soulevant.
It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
Placez la Playstation 4 Slim côté droit vers le haut, avec le logo PS en haut et le côté avec les mots "SONY" et "PS4" face à vous.
Retirez le capot supérieur en le faisant glisser vers les coins arrière et en le soulevant.
Dévissez et retirez les deux vis (une gauche 31,0 mm et une droite 24,0 mm) à l'aide d'un tournevis T8 avec un mouvement dans le sens antihoraire.
Dévissez et retirez la vis de 3,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
UK model seems to be different here. There's no Philips screw where there is on your image.
This regards EU models in general, i think. My danish version is the same.
Retirez les quatre vis Philips de 16 mm qui maintiennent le bloc d'alimentation en place.
Only 2 Phillips actress here on my UK
Only 2 phillips screws on the US one as well.
I also only have two screws here in the US.
Retirez la tôle métallique du dessus de l'alimentation en la saisissant et en la soulevant avec vos mains.
I think the metal sheet protects the rest of the console or something from heating too much.
Retirez l'antenne du haut de l'alimentation en guidant le fil avec vos doigts dans les rainures sous le panneau métallique.
What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
Me neither, guess they are different models.
Retournez la Playstation 4 Slim sur son dos.
Dévissez et retirez la vis de 4,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
How do you get it when the screw is stripped
Débranchez la connexion filaire de l'alimentation en la tenant fermement avec vos doigts ou une pince à épiler et en la tirant.
Retirez complètement l'alimentation en saisissant et en soulevant avec vos mains.
Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
Misha FV -
You are right, pulling the wires is entirely wrong. I used the small rectangular, thin blue plastic to push the cable back from the socket. It was too tight. From my experience of repairing, never pull wires. The consequences of damaging it are not worth it.
Dévissez et retirez la vis de sécurité de 31,0 mm à l'aide d'un tournevis T8 avec un mouvement dans le sens antihoraire.
Localisez les deux fils connectés au bas de la carte mère.
Retirez les fils en saisissant fermement les connexions métalliques avec vos doigts ou une pince à épiler et en tirant vers le haut jusqu'à ce qu'ils se déconnectent.
Retournez l'appareil vers l'arrière.
Dévissez et retirez les vis noires 14 (19 pour les CUH-21xx) x 4,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
Dévissez et retirez les vis argentées 8 (7 pour les CUH-21xx) x 6,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
Dévissez et retirez les vis argentées 4x 3,0 mm à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
- There are 14x 4.0mm black screws, but the step only shows 13 of them circled in red. One of the 11 orange circles (near front of unit) is actually the 14th black screw. Photo: http://i.imgur.com/7G64egd.png
- As for the 6.0mm silver screws, there are only 8x of those. The two silver screws behind the IO ports on the back are 3.0mm fine-threaded screws. Photo: http://i.imgur.com/cQD6KQu.png
- Source: Have a PS4 Slim (CUH-2015A) right in front of me, doing this exact job. Hope this helps someone else down the road.
In my PS4 slim many of the screws shown in this step are melted plastic rivet type fasteners. I guess I’m supposed to just cut through them and hope the game stays together or is there a way to remove them and drill and tap holes for screws that will hold the board etc in place? My game is getting old and I would like to clean the fan and make sure the thermal paste or Liquid Metal is still working (“the perfect amount “). The fan in my game seems to run a quite a bit. Thanks!
By definition, "unscrew" is in a counter-clockwise motion. And, people who are taking apart a device like this will be able to tell when they try to turn the screw which way is correct.
In the second picture, there is a hard disk. In the first and third pictures, there is no hard disk. You might want to update these instructions to include hard disk drive removal.
In my experience with creating guides you use existing guides as stepping stones to build up new guides. That means sometimes pictures will show a procedure for one step where other steps may come before or after the one being described. The point is you should be looking at what's being described rather than nit-picking on things like is the hard drive there or not. Just assume if the instructions haven't told you to remove the hard drive, then you don't need it removed even if the picture shows it having been taken out.
With regard to the second picture in particular, I added that one when I was taking apart my grandson's CUH-21xx system only to find that the screws were substantially different than the ones in the original guide. My point was to document those differences and no, I didn't worry about whether the hard drive was there or not, so my picture has it in and the others don't.
Dévissez et retirez les deux vis de 5,0 mm sur le côté de la console à l'aide d'un tournevis cruciforme n ° 1 dans le sens antihoraire.
These are 3.0mm screws, not 5.0mm. This step could probably be condensed into the previous step.
These screws are not present on the US model
Yes, my US model doesn't have it either
Localisez le fil blanc connecté au coin du haut de la carte mère.
Débranchez le fil en saisissant fermement la connexion métallique avec vos doigts ou une pince à épiler et en tirant vers le haut jusqu'à ce qu'il se détache.
Dévissez le fil de la bande et déplacez-le sur le côté à l'aide d'une pincette ou de vos doigts.
Retirez la plaque métallique en saisissant les deux côtés de la plaque et en la soulevant et en l'éloignant de vous-même.
This step would benefit from showing a picture of the black pads in question. Pic: http://i.imgur.com/zQnehtA.png
The US model has two black screws under the HDD
Dévissez et retirez les deux vis 10,0 mm (une argent et une noire) à l'aide d'un tournevis cruciforme n ° 1 avec un mouvement dans le sens antihoraire.
Retirez la petite plaque métallique en la saisissant avec vos doigts et en la soulevant.
Why is one silver and one black? I keep thinking they are different and try to keep track of where they go.
What's the name is the part with the two metal screws that is being taken off
both screws are black on the US version
Retirez cette connexion de fil en la tenant fermement avec des pincettes et en la tirant.
Do not attempt to disconnect the plug by pulling on the wires! If you rip out the wires, you’re gonna have a very bad day. Wiggle the plug using the plastic on the male end of the connector while pulling out.
que pasa si se desolda esa parte como puedo volver a soldarlo o cuanto se cobra por solo soldar
this is plugged in WAY too hard. I've been wiggling it for 5 minutes. Not budging an inch. i learned that if you follow the cables of that, they are just held in place by a few plastic hooks. You can slide them out of there by flipping the ps4 over and then pull the motherboard out no problem, cable still attached.
Also, dont forget about the small plug in at the top of the motherboard. That is the fan power cable and needs to be off to remove the mobo as well.
I broke the cable by accident, where can i find a replacement?
Dévissez et retirez les six vis de 4,0 mm à l'aide d'un tournevis PH00 avec un mouvement dans le sens antihoraire.
On my model, there are screws on the opposite side of the PS4 that are long and have their threads facing up into this plate. You have to unscrew them from the opposite side so they come off.
Also, you DEFINITELY need to reapply thermal paste when doing this step in reverse order after replacing the fan!! How is this not mentioned, its critical otherwise your CPU will overheat.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
65 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
Thank you so much for this guide! It was very helpful!
Deine Schrauben großen machen gar kein Sinn du hast mehr verschiedene Schrauben als es gibt
My PS4 “Slim” is quite different internally than the one shown. But regardless, this guide is an excellent resource for us diy’ers. And don’t forget any parts when reassembling, like I did. Took four tries to get everything back where it belonged. And man, was it dusty in there! Regular cleaniings are a must.
My ps4 slim is different it has some extra parts, now I don’t know how to put it back, hahahahahhahaha
This guide gets you 90% of the way there. Some really important pieces are missing though, primarily:
- How you dont need to unplug the power supply cable from the motherboard, you can just unhook it from the plastic clips on the case.
- It never mentions cleaning the old Thermal Paste off the heatsink + cpu and replacing with a new dab.
Both of these are essential for a proper tear-down. If you dont replace the thermal paste, your PS4 is guaranteed to break down irreparably in the future. I had to know or discover them for myself. Please, please update this guide with that info.
Remove the screw directly to the left of that one in the picture as well. Should be silver.
Elizabeth Johnson - Réponse
ihr seid so ein scheiß haufen das stimmt über haubt nix
Toaster 95 - Réponse
einfach alles stimmt nicht
