Ce dont vous avez besoin
Retirer les huit vis Philips #00 1,3 mm fixant les clips du panneau avant sur les côtés intérieurs de la coque arrière.
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
Merci à ces traducteurs :
100%
Anthony Fassler nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Don't accidentally remove the volume switch screws here. That comes later, and two of those screws are different from these and it's hard to tell them apart.
Chris Dotson - Réponse
hello guys,
i have recently encountered a problem with my iphone 5. the front panel is lifting away from the body of the phone and i can see the backlight assembly behind it. i figured the problem is from the front panel clips not holding the screen in place thus it is popping up. please if i have diagnosed it incorrectly and there is another cause for my problem, let me know.
for the time being, i am considering purchasing a used rear case on ifixit grade C as i only need the clips holding the screen in place. i want to make sure that the clips indeed come with the rear case when you purchase it, if not can someone please tell me where i can get them?
thanks in advance
sally96 - Réponse
