Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplir des enceintes à eau
Ce dont vous avez besoin
  1. Remplir des enceintes à eau, Changement de l'eau et du bouchon: étape 1, image 1 de 2 Remplir des enceintes à eau, Changement de l'eau et du bouchon: étape 1, image 2 de 2
    • Vous allez avoir besoin d'un espace libre, d'enceintes à eau, de la colle forte, de l'eau minérale ainsi qu'un tournevis cruciforme.
    i see a tiny hole on top of the glass speakers. but i see no obvious way to open it. it seems to me though that this would be where i should add the mineral oil. Anyone else have the same speakers i have? any ideas on how to open it.. without damaging the glass?
    Betty Jo Doney - Réponse
    You need to take the clear part with the water off of the black part.
    Follow this instructions posted here.
    Good luck
    Uzibah - Réponse
    Using the phillips screw driver remove the 4 screws seen on the back of speakers.
    Once the four screws are taken out you will need to slide the bottom piece from the water canister. When the two are separated set the water canister bottom facing up.
    On the bottom of the water canister you will see a SMALL HOLE where the water was inserted. There will be a black plug covering the hole. Using your screw driver you can pry the plug out. Once the plug is taken out you can refill the speakers. Only refill the speakers with one inch of water.
    After the water is filled to approximately one inch. Super glue the hole shut and let dry.
    When the glue is dry slide speaker back on to water canister. Once they are put together place back panel on and insert the four screws. repeat steps 2 through 6 on second speaker.
    Uzibah - Réponse
  2. Remplir des enceintes à eau: étape 2, image 1 de 1
    • À l'aide du tournevis cruciforme, enlevez les 4 vis visibles à l'arrière des enceintes.
  3. Remplir des enceintes à eau: étape 3, image 1 de 1
    • Une fois les quatre vis dévissées, faites glisser la partie inférieure afin de la séparer du réservoir d'eau.
    • Posez ensuite le réservoir d'eau à l'envers.
    I have got the same speakers, and You should refill it with water but one inch of the top so almost full. Just correcting your stupid mistake You smarty pants. Thank You!!!
    Tomasz Kijak - Réponse
    Sorry you confused me... How much water?
    Uzibah - Réponse
    Bonjour, soucis avec une de mais haut-parleurs ou il manque énormément de liquide, pouvez-vous me donner la référence du liquide qu'il faut mettre car j'ai essayé avec de l'eau démoralisé cela ne fonctionne pas, merci par avance en attente d'une réponse.
    Jean-Claude GANDON - Réponse
  4. Remplir des enceintes à eau: étape 4, image 1 de 2 Remplir des enceintes à eau: étape 4, image 2 de 2
    • En dessous du réservoir, vous trouverez le trou par lequel il a été rempli d'eau. Ce trou est fermé par un bouchon en caoutchouc noir.
    • Faites levier avec le tournevis pour retirer le bouchon.
    • Remplissez ensuite les enceintes. Ne mettez dans chacun d'eux que 2,5 cm d'eau.
    I tried prying it but it didn't work and I ended up breakin the little space it was in.
    Kennedy Meza - Réponse
    Mine didn't have a plug, and I had to use a very small bit to drill the hole open. added water and glued. works okay, except it makes a random 'grinding' noise and the liquid in the refilled one doesn't cascade like the original - almost as if the original liquid was not water - at least not plain water. Any thoughts?
    Fehring - Réponse
    it's mineral oil
    Shreyash Patel -
    Just bought these speakers; there's only about an 1/8" of water in them. Took it apart with your instructions and found water plug... It's tiny! How did you add water? A syringe? Also in the picture the water tank appears full, you say add one inch. We don't understand (duh), could you explain please?
    peterhulse86 - Réponse
    Only the inch of water in the bottom of the water tank is shot up into the air in the water tank.
    Elijah -
    when and how much mineral oil do I add to the water?
    Christopher Robertson - Réponse
    No answer yet on the mineral oil? Maybe all mineral oil?
    Uzibah - Réponse
    Le bouchon ne se retire pas du tout, je voulais le remplir a nouveau mais comme dit le bouchon ne s'enlève pas 😕
    Lydia Blin - Réponse
  5. Remplir des enceintes à eau: étape 5, image 1 de 1
    • Une fois que vous avez rempli jusqu'à une hauteur d'environ 2,5 cm, rebouchez le trou avec de la colle forte et laissez sécher.
  6. Remplir des enceintes à eau: étape 6, image 1 de 1
    • Une fois la colle sèche, ré-assemblez le réservoir et le reste de l'enceinte.
    • Reposez ensuite le panneau arrière et revissez les 4 vis cruciformes.
    • Répétez les étapes 2 à 6 pour la seconde enceinte.
    Can you showe me how to fixs my water speakers
    Kenneth Ruybal - Réponse
    Just got mines on sale for $15 soeakers works great n loud but the water its not dancing don't want to return it back but how can i make the water to dance kinda mad about it someone helps me plz thanks
    carmen nieves - Réponse
    Just purchased this set of speakers. (I appreciate the instructions you provided on how to add the water…as this info did not come in the box!!!
    Shirley Massison - Réponse
    Bonsoir, je tombe sur votre TUTO super intéressant, mais le problème pour moi, est que je trouve pas l orifice pour l eau….pas de bouchon noir…et 2ème chose, peut on remplacer la colle forte, par de la colle chaude, d après vous’ car une fois refroidit, elle devient dure…! Merci de votre aide
    ha oui, mon enceinte n est pas tout à fait pareille que la votre, elle est ronde et c est une Polaroïd (sans vouloir faire de pub)
    severine.tribolet - Réponse
    wood
    okkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
    IAN VOGT - Réponse
    Is a hot glue gun an effective glue substitution?
    Chelsey Richardson - Réponse
Vos enceintes à eau sont maintenant prêtes à l'usage. Merci d'avoir suivi ce tutoriel.
47 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
90%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Andrew
Membre depuis le 02/17/15
1 339 Réputation
2 tutoriels rédigés
Équipe
Vegas Room H9 Membre de l'équipe Vegas Room H9
Community
13 membres
17 tutoriels rédigés
35 commentaires
the pump is defective how to replace
anpicard@videotron.ca
andrepicard2012 - Réponse
I couldnt get plug out either so I drilled a hole in back and filled it with mineral water and sealed it with a small strip of scotch tape and duct tape on top of that in case I had to get back in. It works, but now it looks different. Sometimes the water clings to the inside and it looks a little foggy. Is it mineral water, or mineral oil? If it leaks again I'll prob try the oil.
Lacepage - Réponse
The original liquid has a lower surface tension than water. I used odorless mineral spirits.
If the pump is noisy, try a drop of oil in the motor.
aeromojito - Réponse
My speakers keep spraying even though their is no music playing, is that a good thing?
Andrew - Réponse
That means that the speakers are broken. You might need to replace it. If not, then its a probelm with the board, which I have no idea how to fix.
Skittlekingthefirst -
good it worked with me, thanks for guidance.
Shujath Shariff - Réponse
I got one of these for Christmas at five BELoW for $5. I figured out why they were selling it. Someone lost the black plug on the bottom that plugs the hole and they used hot glue to fix it, but it still leaks somewhere. I will probably drill a hole in the top or back and fill it with water and cover it up and then use some sealing tape to make sure it stops leaking.
blakesr171 - Réponse
Try some JB weld on the area
Troy Reinhardt jr -
My water dance speaker still has water. My problem is the water isn't splashing about with the music, any more. What would cause that to stop?
lorirunninglate - Réponse
lolirunninglate, you have broken pumps in your speaker, but i don't know how to fix that.
Elijah - Réponse
I read somewhere u can use baby oil to is that true. My son got some but there is nothing in there so I have to fill them.
Michelle W - Réponse
lorirunninglate u would have to get a new motor for the or both speakers if neither work there is no pumps it's three magnetics that are attached to the motor with a wheel try looking up on YouTube on how to replace the motor
Troy Reinhardt jr - Réponse
Regarding identifying the liquid:
Based on a search for the MSDS, the MSDS (ref: http://www.mobilefun.co.uk/blog/wp-conte... ) calls it "Artware Oil C-300", with a viscosity of 3.6 mPa.s (aka 3.6 cSt).
Mineral oil comes in MANY viscosities, the closest I could find would be Peneteck, the second closest would be 4463 oil (ref http://www.hollandchemicals.com/Document... ).
Can't find a seller for "Artware Oil C-300", "Peneteck", or "4463 oil" yet. I expect there would be other mineral oils in this viscosity range as well. I haven't found a source for oil yet, but hope this helps in the search.
Will update / add comment if I find a mineral oil in this range.
Matt - Réponse
I'm trying to fill my second speaker and when I open it the plug is like 1/4 of an inch down and I can't get to it.
Tyler unnecesary - Réponse
I dont get it - its not water or mineral water , but oil - mineral oil of a fairly low viscosity so that it runs easily but doesnt stick. So exactly what is it, and when it leaked, where did it go to as if it is oil it wont evaporate.
ajb - Réponse
I have the same problem, but I have the Water Tower BT SC1128BT Model.
I can’t even find the refill area or access the “Guts” of this thing!!
howlbob -
When I opened the box only one speaker had water in it. So I found these directions for filling it. Both speakers had broken pieces in them. When I opened the back of the empty one, there wasn't a plug. Instead, there was a big thick layer of apoxy or something. When I finally got enough of the glue/apoxy stuff off, I put the water in and glued it back closed. Then, while trying to get it back together, three wires broke lose. My husband said he would try to sodder the wires back in place when he got a chance but I'm not optimistic it will work. Luckily, I didn't pay anything for the piece of crap. It was given to me. My husband said if he couldn't fix it, he would buy me another one......don't think I really want to chance money on buying another one though.
Lori McDonald - Réponse
I also had trouble removing the plug (I resorted to pushing it in) and eventually broke a wire in the process. The oil that had escaped had made the inside of the bottom piece kind of sticky.
At this point, its no longer worth trying to salvage it. The other one still works, but it looks silly with just one. It was a neat little gift, but very cheaply made…
Maria Nikkel - Réponse
Can you just use regular water?
April Lopez - Réponse
Can’t I just put a hole in the top and put tap water in it because I’m too trashy to go through all this &&^&^$ effort
Solvenskia - Réponse
I AGREE with the last comment! my eyes dont see those tiny little holes, black dots…etc got these at goodwill for $2 so im guessing these will sit in a cabinet til i throw them out.
We have the dancing sharks and after a month the stopped floating and just sit on the bottom. Is there a way to fix this? Thank you.
Jen Brunell - Réponse
Do you have any suggestions on refilling water on the Water Dancing BT Tower Speaker Model#SC-1128BT??
It EVAPORATED out and I just hear the Pump growling!! HELP!!
howlbob - Réponse
For you know how to fix a speaker that has a hole in the plastic at the top?
CyWolf Games - Réponse
its not water , its light oil.
Philp Chung - Réponse
The wiring to the lights fell off while I was refilling! I tried to reattach them, but they keep falling back off when I try to replace the cover . How can I make them stay without a solder?? I was going to use glue, but don't want to damage it beyond repair! Help!?!!
ericka prince - Réponse
Sadly no. At least not very reliabley. You could try to use a teenie tiny metal clamp.
Zarkex -
Hab mich extra registriert um +30 zu vergeben. Danke!
Geri - Réponse
tuto non compatible pas de bouchon pour remplir enceinte a eau en forme de verre !!!! tres deçu
Christelle Lehee - Réponse
It's mineral oil not water. I followed your instructions. have found out the hard way, it doesn't mix.
Pam Beech - Réponse
Moter wairs point plz
Fayyaz Shaikh - Réponse
Should I change it before I use it?
Wanda Tiller - Réponse
Charge it before I use it?
I have some hello kitty dancing water speakers but the LEDs started flickering on the right speaker, specifically the blue and green colors so I’m wondering if there’s a fix to this or where I can send them to be fixed
Zari - Réponse
My water speakers have noisy motors … they are brand new Goldman’s… if they aren’t on full all you hear is the motor for the jets… I don’t want to have to take them back but I wanted them for soothing music at bathtime not a disco!
elfkincatcher - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 31
30 derniers jours : 162
Total : 166,668
