Introduction
Bumper replacements can be expensive, but it isn't always necessary to replace the bumper. Gluing a cracked bumper probably isn't the way to go, but a fiberglass reinforcement is usually sufficient for isolated cases of mild to moderate damage. Use of fiberglass bonds the broken bumper pieces together and adds rigidity.
Use this guide to repair cracks in your bumper using fiberglass.
Ce dont vous avez besoin
Use low-grit sand paper to sand off burs, debris and previous repair attempts so that the bumper piece can be manipulated back to its original shape.
Clean off all sanding dust when you are done using water and if necessary, soap. Clean the area around the crack on the inside of the bumper especially well, as this is where the fiberglass will be laid.
Lay the fiberglass mats over the crack on the inside of the bumper. Be sure the mats are pressed flat against the bumper insides and that there are no bubbles.
Allow the epoxy to dry as long as required by its instructions.
The repair is complete once the epoxy dries! If you wish to further conceal the damage, follow our Body Work Dents and Cracks guide and Hand Painting guide to make the bumper truly look like new!
3 autres ont terminé cette réparation.
