Introduction
VOIP had Failed, after researching on the internet I found a forum page which gave a fix for a similar model. Replacing 2 capacitors fixed the VOIP
Turning the Router over you find 4 rubber feet hiding 4 Philips head screws.
  • Turning the Router over you find 4 rubber feet hiding 4 Philips head screws.
  • Remove the screws and turn the router back upright.
  • The top of the case should now lift off.
Ajouter un commentaire
The C928 Capacitor 100uF 25v is the one talked about in the forum mentioned in the intro.
  • The C928 Capacitor 100uF 25v is the one talked about in the forum mentioned in the intro.
  • While I was checking the solder side of the board I noticed there was a bad solder joint on this cap. You cant see it at this resolution though.
  • While checking the state of the other caps on the board I noticed that this one 1000uF 10v was also showing signs of heat stress.
  • Both capacitors were replaced.
  • You can see the new caps in position on the right.
  • For the princely sum AU $1.20 in parts, 20 mins setting up, 5 mins to fix, 5 mins to put it all away I have saved myself aprox $200 for a new VOIP router :)
2 autre(s) ont terminé cette réparation.
mikejgrantham
Membre depuis le 29/05/2012
146 Réputation
1 tutoriel rédigé
Champion!
Thanks for this.
$1.30 in parts saved me going out buying a new VOIP adapter.
Nick Gustafsson - Réponse
No worries, Glad it helped :)
mikejgrantham - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 1,179
