Aller au contenu principal
Replacing a Casio Exilim EX-Z850 Speaker
Ce dont vous avez besoin
  1. Replacing a Casio Exilim EX-Z850 Speaker, Speaker: étape 1, image 1 de 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: étape 1, image 2 de 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: étape 1, image 3 de 3
    • Remove the screws on both sides and the bottom of the camera with the Phillips #00 screwdriver.
    • The bottom screws are longer than the side screw.
  2. Replacing a Casio Exilim EX-Z850 Speaker: étape 2, image 1 de 1
    • Gently pry apart the rear casing from the body of the camera.
    • Do not pull the casing completely away from the camera or you will damage the ribbon securing the rear casing to the contents inside the camera.
  3. Replacing a Casio Exilim EX-Z850 Speaker: étape 3, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to gently peel the ribbon from the contents inside of the camera, leaving it connected to the rear casing.
    • Set aside rear casing.
  4. Replacing a Casio Exilim EX-Z850 Speaker: étape 4, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 4, image 2 de 2
    • Use the tweezers to pry the LCD screen from the frame.
    • The bottom of the LCD screen is attached to the frame by black tape.
  5. Replacing a Casio Exilim EX-Z850 Speaker: étape 5, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 5, image 2 de 2
    • Use the tweezers to flip the LCD screen to the other side.
    • The LCD screen has a ribbon on the bottom of it that is connected to the contents inside of the camera, do not pull it apart.
  6. Replacing a Casio Exilim EX-Z850 Speaker: étape 6, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 6, image 2 de 2
    • Pry the LCD casing from the tape that is underneath it and then flip it to the opposite side to expose the contents under it.
  7. Replacing a Casio Exilim EX-Z850 Speaker: étape 7, image 1 de 3 Replacing a Casio Exilim EX-Z850 Speaker: étape 7, image 2 de 3 Replacing a Casio Exilim EX-Z850 Speaker: étape 7, image 3 de 3
    • Use the tweezers to flip open the connector that is holding the ribbon connected to the LCD screen in place.
    • Remove the LCD screen with the ribbon from the camera.
  8. Replacing a Casio Exilim EX-Z850 Speaker: étape 8, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 8, image 2 de 2
    • Remove the front casing from the body of the camera.
  9. Replacing a Casio Exilim EX-Z850 Speaker: étape 9, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 9, image 2 de 2
    • Remove two screws on the side where the battery is located using the Phillips #00 screwdriver.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  10. Replacing a Casio Exilim EX-Z850 Speaker: étape 10, image 1 de 2 Replacing a Casio Exilim EX-Z850 Speaker: étape 10, image 2 de 2
    • On the front of the camera, near the flash flip, there is a connector holding a ribbon. Remove the ribbon from the connector.
  11. Replacing a Casio Exilim EX-Z850 Speaker: étape 11, image 1 de 3 Replacing a Casio Exilim EX-Z850 Speaker: étape 11, image 2 de 3 Replacing a Casio Exilim EX-Z850 Speaker: étape 11, image 3 de 3
    • Carefully remove the L shaped frame from the camera by popping the frame off the bumps and tabs located at the bottom of the camera.
    • There is a yellow and orange wire soldered onto the camera. Be careful not to disconnect them.
    • The blue box is the speaker.
  12. Replacing a Casio Exilim EX-Z850 Speaker: étape 12, image 1 de 1
    • Use the tweezers to remove the speaker.
Christian
Membre depuis le 01/28/11
320 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-38, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 2,678
