Introduction
If your RX100 camera is showing the error, "Turn power off and then on" and the lens will not retract completely, see below for the simple fix.
My RX-100 started showing this error message, and initially was able to turn off/on and shoot photos, but after a few days it was constantly showing the error and would not work any more. The lens barrel remained partially retracted and would not fully extend. There is no reset button.
I found a simple fix via an internet search, partly in German I believe. This little fix saved me $300 and a lot of hassle.
Ce dont vous avez besoin
26 autres ont terminé cette réparation.
95 commentaires
It actually works, but only as long as I keep the camera disassembled. Once I put it back together again, the same problem re-occurs. It looks clean, but is there something in particular I should look for? Something that I should try to avoid "squeezing" when assembling?
Hi Niklas,
had the same issue. I remove the panel at the bottom and it works for a while - but - as you can read, a workaround is less as a fix ( ;
Cherry -
Did you find a resolution? I just started receiving this error message and before I start removing screws and panels, I'd like to know if you had success. Thanks so much.
