Aller au contenu principal
Repairing HTC Droid Incredible Logic Board
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Repairing HTC Droid Incredible Logic Board, Battery: étape 1, image 1 de 3 Repairing HTC Droid Incredible Logic Board, Battery: étape 1, image 2 de 3 Repairing HTC Droid Incredible Logic Board, Battery: étape 1, image 3 de 3
    • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
  2. Repairing HTC Droid Incredible Logic Board: étape 2, image 1 de 2 Repairing HTC Droid Incredible Logic Board: étape 2, image 2 de 2
    • Remove battery, prying from the provided gap at the upper-right corner of the battery
  3. Repairing HTC Droid Incredible Logic Board, Back Panel: étape 3, image 1 de 2 Repairing HTC Droid Incredible Logic Board, Back Panel: étape 3, image 2 de 2
    • Depress MicroSD to eject it from the side of the case.
  4. Repairing HTC Droid Incredible Logic Board: étape 4, image 1 de 3 Repairing HTC Droid Incredible Logic Board: étape 4, image 2 de 3 Repairing HTC Droid Incredible Logic Board: étape 4, image 3 de 3
    • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
  5. Repairing HTC Droid Incredible Logic Board: étape 5, image 1 de 3 Repairing HTC Droid Incredible Logic Board: étape 5, image 2 de 3 Repairing HTC Droid Incredible Logic Board: étape 5, image 3 de 3
    • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
    • Start at the top, and work clockwise, being careful not to break the clips.
    • There are, 1, 3, 2, and 3 clips on each side, respectively.
    • After the clips are disengaged, there are no cables holding the back panel in place.
  6. Repairing HTC Droid Incredible Logic Board, Logic Board: étape 6, image 1 de 1
    • Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
  7. Repairing HTC Droid Incredible Logic Board: étape 7, image 1 de 2 Repairing HTC Droid Incredible Logic Board: étape 7, image 2 de 2
    • Remove 2 Phillips Screws holding the logic board to the front panel.
    • Gently lift the logic board off the front panel.
6 autres ont terminé cette réparation.
Mobile Rapid Response Unit
Membre depuis le 05/07/12
1 941 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 4,002
