Introduction
Owners of this headset are most likely aware of the rattling it makes when you move around. This is one of the biggest complaints of this headset and it can be easily fixed.
  1. Remove the foam speaker cover. Locate (4) T5 Torx screws and remove.
    • Remove the foam speaker cover. Locate (4) T5 Torx screws and remove.
  2. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  3. Remove (3) Phillips #000 screws.
    • Remove (3) Phillips #000 screws.
    • Remove circuit board
  4. Optional, remove media buttons section by removing (3) Phillips #000 screws. Cut a circular piece of foam and stuff it under the center section.
    • Optional, remove media buttons section by removing (3) Phillips #000 screws.
    • Cut a circular piece of foam and stuff it under the center section.
    • You are now finished! Just reassemble
5 autre(s) ont terminé cette réparation.
SYN1ST3R
Membre depuis le 06/03/2010
273 Réputation
1 tutoriel rédigé
Please, can you help with silencing the low battery sound?
Houssam - Réponse
OMG.. Best tutorial! I was looking at completing this and then stumbled upon your post.
The button rattle was driving me nuts!
TropiKalSTORM - Réponse
Warning: this is a huge pain! I can confirm it does work though, so thank you!
Some tips:
- After removing the 4 Torx, fully extend the adjustable arm of the right earpiece/headband, it will make it easier to remove the cover
- There are very thin delicate wires connecting the PCB to the earpiece, making everything more difficult
- I could not generate enough torque with my thin stainless jewelers screwdrivers, trying as hard as I could. I recommend a large handle screwdriver. I ended up putting my jewelers screwdriver in my drill, this worked perfectly.
- I used a cut up earplug for the foam, works well, but was hard to shove into place
- Remember to put the sliding switch back into place before putting the screws in for the PCB when putting back together
Joey - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 26
Total : 4,617
