Aller au contenu principal
Introduction
This is a quick guide on replacing a faulty joystick on an N64. If you have a controller with a wobbly joystick, this is the way to resolve your issue.
This can also be considered a mod if you are upgrading the joystick to a redesigned replacement. Upgrading is recommended because the Nintendo 64 has a poorly designed joystick that is prone to breaking and because the redesigned joystick has better control.
  1. Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown. Remove the 2 #00 Phillips screws from the expansion slot Remove the rear housing and set aside.
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly. Remove the 3 #00 Phillips screws holding the joystick assembly in place. Remove the 3 #00 Phillips screws holding the joystick assembly in place.
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Disconnect the joystick data cable and remove the old joystick. To install your new joystick, simply follow these instructions in reverse. To install your new joystick, simply follow these instructions in reverse.
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
Test out your controller! It should be feeling like new.
30 autres ont terminé cette réparation.
Zillatron
Membre depuis le 28/08/2012
1 415 Réputation
1 tutoriel rédigé
2 commentaires
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - Réponse
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 51
30 derniers jours : 217
Total : 36,736
