Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector
Ce dont vous avez besoin
  1. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Prepare your Game Boy for disassembly: étape 1, image 1 de 3 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Prepare your Game Boy for disassembly: étape 1, image 2 de 3 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Prepare your Game Boy for disassembly: étape 1, image 3 de 3
    • Slide the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge in, remove it.
    Demander à FixBot
    Ajouter un commentaire
  2. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the battery cover: étape 2, image 1 de 2 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the battery cover: étape 2, image 2 de 2
    • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
    Demander à FixBot
  3. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: étape 3, image 1 de 3 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: étape 3, image 2 de 3 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: étape 3, image 3 de 3
    • Lift the edge of the cover near the screw and remove the cover.
    • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
    Demander à FixBot
  4. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the battery: étape 4, image 1 de 3 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the battery: étape 4, image 2 de 3 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the battery: étape 4, image 3 de 3
    • Use your finger to lift the battery by the tab on its left edge, then remove it.
    • During reassembly:
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Your replacement battery may come with a plastic enclosure that slides over the battery.
    • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
    Demander à FixBot
  5. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the bottom shell: étape 5, image 1 de 2 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Remove the bottom shell: étape 5, image 2 de 2
    • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
    • Four 6.3 mm‑long recessed screws
    • Two 4.6 mm‑long screws
    Demander à FixBot
  6. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: étape 6, image 1 de 2 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: étape 6, image 2 de 2
    • Lift the bottom shell straight up and remove it.
    Demander à FixBot
    • Remove the back cover of your gameboy advance sp. When you have the internals exposed and the battery removed you'll need to grab some kind of narrow pointy tool like a bent safety pin or (thin) paper clip. Also make sure you have good light.
    Demander à FixBot
    • Look inside the cartridge connector at the metal pins. See how they're all contained within a plastic housing? Each pin has its own little square. You're going to take that safety pin and pop each pin out of its hole and towards where the game cartridge's metal contacts would sit if it were inserted.
    Demander à FixBot
    • Understand that doing this to the cartridge connector will make inserting and removing game cartridges quite difficult. It is doable, but it will hurt your thumbs. Alternatively, you could try bending the pins up or out without displacing them from their plastic housing. I was not able to make this work.
    Demander à FixBot
    • When you've completed breaking--I mean--repairing the cartridge connector, examine the pins and make sure they are all up against the outside edge of their respective plastic squares. If they're bent too far towards where the cartridge's contacts insert, the pins will get mashed when you jam the first game cart in.
    Demander à FixBot
    • Now put your gameboy back together and push a game cartridge in--hard. When it goes in, flip the switch on and hope for the best. Be prepared for sore thumbs when it comes time to switch cartridges. Removing them is harder than inserting.
    Demander à FixBot
6 autres ont terminé cette réparation.
denova
Membre depuis le 10/06/13
349 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
My beloved Game Boy had developed a bit of a "twitch". It would reset itself at completely random moments, leaving me staring in horror at the start up screen of Pokemon Blue. I had cleaned the contacts of the Game Boy and the game cartridge several times but that wasn't helping. It was clear that the pins weren't tight enough.
I followed this guide, using a thumb tack as my tool to bend the pins down. It worked well. I experienced a momentary panic when the first pin popped out of place, thinking I had pressed too hard and damaged it but a quick look told me I was fine.
I put it back together and have played for an hour or so. The Game Boy is working wonderfully again. The pins are very tight, as the guide said they would be. Getting the game in or out requires a lot more force than it used to but not so much that it requires a bodybuilder to accomplish.
carljarms - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 25
30 derniers jours : 134
Total : 23,035
