Aller au contenu principal
Repairing Nokia 6500 Slide LCD
Ce dont vous avez besoin
  1. Repairing Nokia 6500 Slide LCD, LCD: étape 1, image 1 de 3 Repairing Nokia 6500 Slide LCD, LCD: étape 1, image 2 de 3 Repairing Nokia 6500 Slide LCD, LCD: étape 1, image 3 de 3
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Repairing Nokia 6500 Slide LCD: étape 2, image 1 de 1
    • Remove four screws using torx 5 screwdriver.
  3. Repairing Nokia 6500 Slide LCD: étape 3, image 1 de 3 Repairing Nokia 6500 Slide LCD: étape 3, image 2 de 3 Repairing Nokia 6500 Slide LCD: étape 3, image 3 de 3
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. Repairing Nokia 6500 Slide LCD: étape 4, image 1 de 2 Repairing Nokia 6500 Slide LCD: étape 4, image 2 de 2
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Repairing Nokia 6500 Slide LCD: étape 5, image 1 de 1
    • Make sure all components stay on each side (see picture).
  6. Repairing Nokia 6500 Slide LCD: étape 6, image 1 de 2 Repairing Nokia 6500 Slide LCD: étape 6, image 2 de 2
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Repairing Nokia 6500 Slide LCD: étape 7, image 1 de 2 Repairing Nokia 6500 Slide LCD: étape 7, image 2 de 2
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Repairing Nokia 6500 Slide LCD: étape 8, image 1 de 3 Repairing Nokia 6500 Slide LCD: étape 8, image 2 de 3 Repairing Nokia 6500 Slide LCD: étape 8, image 3 de 3
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
dwi
Membre depuis le 07/02/13
163 Réputation
1 tutoriel rédigé
2 commentaires
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - Réponse
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 35
Total : 4,146
