Introduction
Thorough knowledge of disassembling the camera is necessary for replacing the motherboard.
Ce dont vous avez besoin
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Gently pull the LCD and its casing away from the motherboard as shown.
Turn the camera so the back is facing you.
Remove the 2.5mm Philips #0 screw at the top of the camera.
2 autres ont terminé cette réparation.
