Aller au contenu principal
Repairing Tire Hole/Puncture
Ce dont vous avez besoin
  1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: étape 1, image 1 de 1
    • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
  2. Repairing Tire Hole/Puncture: étape 2, image 1 de 1
    • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
    • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
  3. Repairing Tire Hole/Puncture: étape 3, image 1 de 2 Repairing Tire Hole/Puncture: étape 3, image 2 de 2
    • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
  4. Repairing Tire Hole/Puncture: étape 4, image 1 de 1
    • Spray the surface of the tire completely with the soapy water.
  5. Repairing Tire Hole/Puncture: étape 5, image 1 de 1
    • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
  6. Repairing Tire Hole/Puncture: étape 6, image 1 de 3 Repairing Tire Hole/Puncture: étape 6, image 2 de 3 Repairing Tire Hole/Puncture: étape 6, image 3 de 3
    • Once the hole is located, remove any foreign objects with the pliers if present.
    • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
  7. Repairing Tire Hole/Puncture: étape 7, image 1 de 1
    • Insert the reamer into the puncture.
    • Work the reamer in and out while twisting to clean and prep the puncture.
  8. Repairing Tire Hole/Puncture: étape 8, image 1 de 1
    • Put the plug into the insertion tool.
  9. Repairing Tire Hole/Puncture: étape 9, image 1 de 1
    • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
    • Yank the insertion tool so the plug remains in the tire, but the tool releases.
    • Cut the remaining plug so it is flush with the tire.
  10. Repairing Tire Hole/Puncture: étape 10, image 1 de 1
    • Refill the tire to the proper pressure.
  11. Repairing Tire Hole/Puncture: étape 11, image 1 de 2 Repairing Tire Hole/Puncture: étape 11, image 2 de 2
    • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
4 autres ont terminé cette réparation.
Jaylynn Hoffman
Membre depuis le 10/27/15
266 Réputation
1 tutoriel rédigé
Équipe
Missouri Western, Team 1-5, Adkins Fall 2015 Membre de l'équipe Missouri Western, Team 1-5, Adkins Fall 2015
MWSU-ADKINS-F15S1G5
1 membre
1 tutoriel rédigé
Un commentaire
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 78
Total : 5,605
