Aller au contenu principal
Repairing a Wobbly Piano Bench
Ce dont vous avez besoin
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: étape 1, image 1 de 1
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: étape 2, image 1 de 1
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: étape 3, image 1 de 3 Repairing a Wobbly Piano Bench: étape 3, image 2 de 3 Repairing a Wobbly Piano Bench: étape 3, image 3 de 3
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: étape 4, image 1 de 3 Repairing a Wobbly Piano Bench: étape 4, image 2 de 3 Repairing a Wobbly Piano Bench: étape 4, image 3 de 3
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: étape 5, image 1 de 1
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: étape 6, image 1 de 2 Repairing a Wobbly Piano Bench: étape 6, image 2 de 2
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: étape 7, image 1 de 2 Repairing a Wobbly Piano Bench: étape 7, image 2 de 2
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
You can redo this process every 6 months to make sure your bench is always stable.
Équipe
York University, Team S1-G7, Woodhouse Winter 2021 Membre de l'équipe York University, Team S1-G7, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G7
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 1,165
