Aller au contenu principal
Repairing an FJ-3LED Globe Electric Push Light
Ce dont vous avez besoin
  1. Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: étape 1, image 1 de 3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: étape 1, image 2 de 3 Repairing an FJ-3LED Globe Electric Push Light, Repairing an FJ-3LED Globe Electric Push Light: étape 1, image 3 de 3
    • Lift the black lid off of the battery slot and remove the batteries.
  2. Repairing an FJ-3LED Globe Electric Push Light: étape 2, image 1 de 3 Repairing an FJ-3LED Globe Electric Push Light: étape 2, image 2 de 3 Repairing an FJ-3LED Globe Electric Push Light: étape 2, image 3 de 3
    • Use the Phillips #1 screwdriver to remove four 1.4 mm screws from the back of the light.
    • Take the black part out and separate it from the white case.
  3. Repairing an FJ-3LED Globe Electric Push Light: étape 3, image 1 de 1
    • Identify which part of the lamp is broken.
    • in this case, one of the connections in the circuit had been disconnected.
  4. Repairing an FJ-3LED Globe Electric Push Light: étape 4, image 1 de 1
    • For tips on Soldering, see How to Solder and Desolder Connections.
    • Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
    • Melt enough solder onto the solder pad.
    • Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
    • Don't forget to use gloves.
  5. Repairing an FJ-3LED Globe Electric Push Light: étape 5, image 1 de 2 Repairing an FJ-3LED Globe Electric Push Light: étape 5, image 2 de 2
    • Push the circuit into its place.
    • Click the button to see if the wires are connected .
  6. Repairing an FJ-3LED Globe Electric Push Light: étape 6, image 1 de 2 Repairing an FJ-3LED Globe Electric Push Light: étape 6, image 2 de 2
    • If the lights turn on, the connection is perfect in the circuit and the disconnected joint is now connected.
    • Place the white case on top of the circuit and close it with the Phillips #1 screwdriver.
Rojina Saberi
Membre depuis le 05/11/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G23, O'Regan Summer 2021 Membre de l'équipe York University, Team S1-G23, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G23
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 18
Total : 342
