Aller au contenu principal
Introduction
Make sure to try these methods before using this guide:
1. Reset Network settings
2. Restart iPhone
3. Restore iPhone to factory settings
4. Go to Settings, Date and Time, change date and time to manual, and restart iPhone
5. Disconnect and reconnect the battery
If these procedures fail, proceed to the next section.
To make this guide, I tried to repair a common problem with the iPhone 4S. After using the freezer method and hairdryer method, the WiFi began working for briefly. I disassembled my iPhone, removed mother board, and used aluminium foil to protect it. I left only the WiFi chip unprotected. I used a heat-gun at 300 degrees to heat up the chip for 5 to 10 seconds and left it to cool down. I reassembled the iPhone and voila, it works.
  1. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  2. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
36 autre(s) ont terminé cette réparation.
Mario
Membre depuis le 15/09/2015
858 Réputation
1 tutoriel rédigé
10 commentaires
My iPhone is disabled
JeNai Jackson - Réponse
How can I get it unlocked if I don't have a computer
JeNai Jackson -
Without using an computer to connect to iTunes
JeNai Jackson -
So how do I fix an iPhone that is completely disabled and you connect to iTunes but you can't turn off the Find my Iphone
Alexking - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 26
30 derniers jours : 102
Total : 28,237
