Aller au contenu principal
Repairing nose pads on eyeglasses
Ce dont vous avez besoin
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: étape 1, image 1 de 2 Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: étape 1, image 2 de 2
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: étape 2, image 1 de 2 Repairing nose pads on eyeglasses: étape 2, image 2 de 2
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: étape 3, image 1 de 1
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: étape 4, image 1 de 2 Repairing nose pads on eyeglasses: étape 4, image 2 de 2
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: étape 5, image 1 de 2 Repairing nose pads on eyeglasses: étape 5, image 2 de 2
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
3 autres ont terminé cette réparation.
Vivi Chou
Membre depuis le 04/28/17
151 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S3-G4, Coad Spring 2017 Membre de l'équipe UC Davis, Team S3-G4, Coad Spring 2017
UCD-COAD-S17S3G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 88
30 derniers jours : 356
Total : 47,303
