Aller au contenu principal
Repairing Paint Brush Bristles
Ce dont vous avez besoin
  1. Repairing Paint Brush Bristles, Repairing Paint Brush Bristles: étape 1, image 1 de 2 Repairing Paint Brush Bristles, Repairing Paint Brush Bristles: étape 1, image 2 de 2
    • Identify the brush type and the level of damage:
    • If the brush hairs are inflexible due to hardened paint coats, proceed to Step 2.
    • If the brush hairs are synthetic (fraying bristles), proceed to Step 5.
  2. Repairing Paint Brush Bristles: étape 2, image 1 de 2 Repairing Paint Brush Bristles: étape 2, image 2 de 2
    • Fill a small cup half way with turpentine.
    • Soak the brush in the turpentine for 2 days.
    • CAUTION: Do this in a well-ventilated area. The fumes from turpentine are toxic.
  3. Repairing Paint Brush Bristles: étape 3, image 1 de 1
    • Remove any amount of paint that may remain on the brush by moving the brush in a circular motion.
  4. Repairing Paint Brush Bristles: étape 4, image 1 de 2 Repairing Paint Brush Bristles: étape 4, image 2 de 2
    • To remove remnants of turpentine on the bristles, wash the brush thoroughly in water.
    • After the turpentine has been completely removed, proceed to Step 7.
  5. Repairing Paint Brush Bristles: étape 5, image 1 de 1
    • For synthetic brushes, boil a pot of water.
    • CAUTION: Avoid any contact with hot objects.
  6. Repairing Paint Brush Bristles: étape 6, image 1 de 2 Repairing Paint Brush Bristles: étape 6, image 2 de 2
    • Place the brush in the boiling water.
    • Rotate the brush in the water for approximately 5 minutes.
    • You should begin to notice that the bristles will start to come back together from the heat and water.
  7. Repairing Paint Brush Bristles: étape 7, image 1 de 2 Repairing Paint Brush Bristles: étape 7, image 2 de 2
    • Gently dry off the brushes using a soft towel.
    • Stroke the brush in an upward motion and be careful not to dig the towel through the bristles.
  8. Repairing Paint Brush Bristles: étape 8, image 1 de 3 Repairing Paint Brush Bristles: étape 8, image 2 de 3 Repairing Paint Brush Bristles: étape 8, image 3 de 3
    • In order to retain the brush shape, use a brush tube or wrap the bristles in aluminum foil.
    • Within approximately three hours, the brush bristles will be back to normal.
  9. Repairing Paint Brush Bristles: étape 9, image 1 de 2 Repairing Paint Brush Bristles: étape 9, image 2 de 2
    • Cut off excess frayed bristles (optional).
    • There may be a few fraying bristles left. These are harmless and will cling to the brush shape when dipped in paint.
    • If preferred, you may use a nail clipper to cut these hairs off.
Your brushes should now be usable again. Unfortunately this cannot be done too many times because the turpentine will start to damage the bristles, so make sure to regularly wash your brushes.
23 autres ont terminé cette réparation.
Ankita Bhowmik
Membre depuis le 09/29/15
659 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-7, Green Fall 2015 Membre de l'équipe Cal Poly, Team 15-7, Green Fall 2015
CPSU-GREEN-F15S15G7
3 membres
7 tutoriels rédigés
6 commentaires
Is this only for synthetic brushes? What about natural hair brushes which are frayed?
radhikacr999 - Réponse
Hey! Can you tell me what is the use of wrapping the bristles in aluminium foil?
Santwana Verma - Réponse
The article literally says “to retain the brush shape”
Paul Peddie -
I’ve seen other tutorials say to mix vinegar with the boiled water, would you recommend it?
John Ippoliti - Réponse
Awesome guide, By the way, this guide "Can You Spray Stain With An Airless Sprayer" also contain useful information.
Muhammad Usman Bhatti - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 189
30 derniers jours : 734
Total : 139,306
