Aller au contenu principal
Replace defective capacitor in a power supply
Ce dont vous avez besoin
    • ATTENTION: 230V are processed in the monitor. So take the necessary care. And a little experience with electronics and soldering should be available.
  1. Replace defective capacitor in a power supply: étape 2, image 1 de 1
    • The main focus here is on troubleshooting. First disconnect all plugs and then loosen the housing screws.
    • Now check whether an electrolytic capacitor has "blown up". Most electrolytic capacitors have a notched cross at the top and are flat there. If this surface is curved upwards, the electrolytic capacitor is defective.
    • When this top has burst open or liquid has leaked out of the electrolytic capacitor at the bottom, it is defective.
    • The liquid can also cause damage to the circuit board. In this case, the circuit board should be cleaned with isopropanol and any damaged lines must be repaired before installing a new electrolytic capacitor.
    • Now remove the circuit board. To do this, loosen all connections and remove the corresponding screws.
    • Next, the defective electrolytic capacitor must be desoldered (desoldering pump or desoldering wire help).
    • Now replace the defective electrolytic capacitor. The new electrolytic capacitor must have the same capacitance and voltage. The connection wires and height should also be the same.
    • Now reinsert the circuit board and make all connections again.
    • Then screw the cover back on.
Work through the steps in reverse order to reassemble your device.
Merci à ces traducteurs :
de en
100%
oldturkey03 nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
HRi
Membre depuis le 01/24/22
133 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 41
30 derniers jours : 208
Total : 3,788
